re. GRASS Bug # 2877 (Debian Bug # 287651)
Insecure use of the '/tmp/' directory.
I'm getting through the instances; pretty much done actually.
g.tempfile didn't have to change.
There's one that goes deeper than I want to mess with, ie the locking
mechanism..
/tmp/grass6-$USER-$GIS_LOCK/gisrc
referenced by
lib/init/init.sh
lib/gis/unix_socks.c
(changing this might mean lib/gis/win32_pipes.c needs to be changed too)
The "/tmp/grass6-$USER-$GIS_LOCK/gisrc" file is predictable, leaving the
system open to symlink attacks...
can someone who understands the internals look into this please?
The startup should create the /tmp/grass6-$USER-$GIS_LOCK directory
such that it is only accessible to the current user. If the directory
already exists, the startup should abort.
If no-one else can write to that directory, it doesn't matter how
files are created within it.
> mechanism..
> mechanism..
> referenced by
> lib/init/init.sh
Clarification: by "should", I mean that it ought to work this way; I
don't think that it does at present.
> > leaving the system open to symlink attacks...
> directory already exists, the startup should abort.
