hello all:
i decided to try my hand at compiling the grass5pre5 source within the fink structure (a great tool for os x / darwin users to get unix packages; see <http://fink.sourceforge.net/>\). since fink has its own directory (/sw) i decided to put grass5 there (/sw/grass5) with the following:
sudo ./configure --prefix=/sw --with-includes=/sw/include --with-
libs=/sw/lib --with-tiff-includes=/sw/include --with-tiff-libs=/sw/lib --with-tcltk-includes=/sw/include --with-tcltk-libs=/sw/lib/tcl8.3 --with-gd-includes=/sw/include --with-opengl-includes=/usr/X11R6/include --with-fftw-includes=/sw/include --without-odbc --without-postgres
aside from the compilation errors below, this worked. i didn't include odbc or postgres, as they're not (yet) in the stable tree of fink; i'll add dbm, motif, freetype, and readline next ./configure, as i didn't have them fink'ed yet. g77 is also available via fink. as you can see, i've pointed configure to the fink includes and libs, tcltk included.
so my configuration is like this:
GRASS is now configured for powerpc-apple-darwin5.5
Source directory: /sw/src/grass5.0.0pre5
Build directory: /sw/src/grass5.0.0pre5
Installation directory: /sw/grass5
C compiler: gcc -g -O2
FORTRAN compiler:
NVIZ: yes
X11 support: yes
DBM support: no
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: yes
Tcl/Tk support: yes
PostgreSQL support: no
OpenGL(R) support: yes
ODBC support: no
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
only a couple errors:
GRASS GIS compilation log
Start of compilation: Thu Jun 27 08:12:57 CDT 2002
Errors:
Compilation error in module: src/libes/vect32/georef (ignored)
Compilation error in module: src/raster/r.in.gdal (ignored)
Compilation error in module: src/raster/r.sun (ignored)
Compilation error in module: src.contrib/GMSL/g3d/src3d/sites/s.vol.rst (ignored)
End of compilation: Thu Jun 27 08:50:47 CDT 2002
DONE generating GRASS GIS binary code
however, when i try to fire up tcltkgrass&, i get an error that $env(TCLTKGRASSBASE) isn't set, so i check my ~/.grassrc5 and its not there. what is this env variable looking for? can i just point it to the appropriate place via my ~/.grassrc5 file? i already tried the old ' source /etc/csh.cshrc /etc/csh.login ' and it didn't work.
thanks in advance for any suggestions.
take care,
andy a.
p.s. since i'm a digest lister, please write directly or cc me.
