The value range should be:
min=176.945400
max=284.015600
And it is the case when 'r.in.arc type=DCELL' is used for importing.
However, if 'r.in.gdal' or 'r.in.arc type=FCELL' is used then:
min=176.945404
max=284.015594
I suppose there should be no difference. What is the reason?
Maciek,
Well, the obvious conclusion is that a FCELL, which I presume reads as a
4byte float gives
slightly less precision than DCELL which is an 8byte float. The change
in the seventh digit would
seem to be what we would expect from floating point precision limitations.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
min=176.945400
max=284.015600
min=176.945404
max=284.015594
4byte float gives
in the seventh digit would seem to be what we would expect from floating point precision limitations.
Ok, so why doesn't r.in.gdal recognize what precission the input requires? Actually, all floating point AI ASCII GRIDs I met were DCELL, no matter where they came from. So maybe the default for the r.in.gdal in case of the AI ASCII GRID should be DCELL instead of FCELL?
GRASS DEVELOPERS - I couldn't find a GUI entry for the 'r.in.arc' in the File->Import->Raster. Shouldn't it be there?
Maciek
I need to know that it has been added to the available modules in order to
add it to the menus. Thanks for letting me know. I'll add it to the CVS
version soon.
On 11/27/04 2:03 PM, "Maciek Sieczka" <werchowyna@pf.pl> wrote:
grass57_exp_2004_11_13
When I choose the "v.surf.rst" from the GUI it doesn't pop up but prints in
the terminal:
ERROR: Required parameter <input> not set:
(Name of the vector file with input data)
Anybody having the same? Give it a bug report?
Maciek Sieczka
I just tried this this weekend and noticed the same behavior. Seems like
I've changed the menu entry for this command a couple of times to deal with
odd behavior. Maybe I can now change it back to the original 'execute'
version.
Michael Barton
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
I just had a moment to check on r.in.arc and it is already in the GRASS 5.7
menus (25 Nov. release), under file>import>raster>ESRI Arc/Info ASCII grid
Maciek
Michael Barton
PO Box 872402
USA
> Maciek
version soon.
I wasn't aware that it is present in 5.7.
Still I vote for removal of 'r.in.arc' as 'r.in.gdal' should do the same
(right?).
Replicated functionality should be minimized IMHO.
I haven’t had a chance to test this to see if r.in.gdal is the same as r.in.arc. If it is, I agree completely that we need eliminate redundancy where possible. Perhaps Maciek can test it as he seems to have a set of AI ASCII grid files he is working with now. Let me know if it is redundant and I’ll take it off the input menu.
It would be nice on both GDAL and OGR to hit a button and get a list of readable formats. Since GDAL at least generates such a list, this should be doable.
Michael
GRASS DEVELOPERS - I couldn’t find a GUI entry for the ‘r.in.arc’ in the
File->Import->Raster. Shouldn’t it be there?
Maciek
add it to the menus. Thanks for letting me know. I’ll add it to the CVS
version soon.
I wasn’t aware that it is present in 5.7.
Still I vote for removal of ‘r.in.arc’ as ‘r.in.gdal’ should do the same
(right?).
School of Human, Evolution and Social Change
USA
Sent: Monday, November 29, 2004 5:56 PM
Subject: Re: [GRASS5] floating AI ASCII GRID import
I haven¹t had a chance to test this to see if r.in.gdal is the same as
and
I¹ll take it off the input menu.
The problem is that GDAL may round the floating AI ASCII GRID to integer.
Below is what Frank Warmerdam once wrote on the gdal-list. Frank, is it
still not fixed? BTW - what is the chance that GDAL could be thought to recognize if the AI AGRID is FCELL or DCELL?
Sent: Tuesday, June 01, 2004 2:59 PM
Subject: Re: [Gdal-dev] floating point bug
This is already a known issue in bug: http://bugzilla.remotesensing.org/show_bug.cgi?id=313
Basically I scan the first 1K or so of the file to look for floating point
values.
If I don't find any I assume the whole coverage is integer.
I have been hesitant to "fix" this as a proper fix would seem to require
scanning the whole file on open which is pretty expensive.
and
values.
Maciek,
This is still an open issue.
Best regards,
I happen to work with ascii grid files right now and I have a situation
where I have both integer and FP values, the integer being -9999 for no data.
I tried it with r.in.gdal and indeed it imported it as integer (which for DEMs
can be a serious problem). I would guess that this may be the most common
situation when users get it imported as integer rather than FP (besides manually
changing some of the data) - I think that this could be fixed relatively
easily if the integer value for nodata defined in the header is skipped.
If this cannot be fixed we should keep r.in.arc
Helena.
and
values.
should be doable.
A year ago I added support (locally) to r.in.gdal for a -l flag to list
available formats and exit. This was mostly just cut-and-paste C code
from 'gdalinfo --formats'. I never put it in CVS, can do if people want.
v.in.ogr should be a similar exercise. 'gdal-config --formats' is another
flavour.
v.in.ogr already has a -l flag for listing available layers.
should be doable.
flavour.
Maybe -f for both? (for "list Formats")
it would be very nice if you could add such a flag,I miss it too.
-f looks good to me,
Personally, I think it is a very useful idea and would like to see it
implemented.
Michael
should be doable.
flavour.
comments?
Hamish
PO Box 872402
USA
>>should be doable.
> list available formats and exit. This was mostly just cut-and-paste
> C code from 'gdalinfo --formats'. I never put it in CVS, can do if
> people want. v.in.ogr should be a similar exercise. 'gdal-config
> --formats' is another flavour.
ok, done for both r.in.gdal and v.in.ogr.
r.in.gdal: code follows GDAL 1.2.5 gcore/gdal_misc.cpp
Frank is the author of all this code, but this may mix licenses:
-> I assume this does not constitute a "substantial portion" of
gdal_misc.cpp and therefore it is ok? Frank?
v.in.ogr: not sure how to do the read/write check.
[as these are both reading functions, reporting 'write' support
doesn't really matter, but is interesting..]
Both modules have non-optional options (eg output=). You have to provide
dummy values to get past the parser. Is there a better way?
Hamish,
Cool, good work! I am happy to allow portions of gdal_misc.cpp
to be relicensed under the GPL when copied into GRASS. In
fact, I am happy to allow any amount of code from GDAL that I
hold the copyright on to be relicensed under the GPL if it would
be useful in GRASS, as long as the original copy in GDAL remains
under it's original license.
In C++ you would do a test like this to see if a driver supports
creating new datasources. I thnk the C equivelent is to call
OGR_Dr_TestCapability().
if( !poDriver->TestCapability( ODrCCreateDataSource ) )
printf( "%s driver does not support data source creation.\n",
pszFormat );
exit( 1 );
Ugg, this really sucks doesn't it?
Best regards,
creation.\n",
pszFormat );
exit( 1 );
What I don't understand is what *pszCap string to give
int CPL_DLL OGR_Dr_TestCapability( OGRSFDriverH, const char * );
as a test. (if that works at all)
