[GRASS5] follow-up nviz defaults
Bob and Helena,
Was looking at the problem that I was experiencing with the default setting of which surface to display vectors on in nviz. I have resolved the issue as best as I can…I am not sure if this wants to be added to the CVS list (hopefully not, since I don’t know how to do it…), but it is a simple fix…
go to $grass/etc/nviz2.2/scripts and look for the widgets.tcl file. Under this, you will find the call procedure:
nv_mksurfacelist (line 423). This is where the building of the surface files list takes place. A few lines down, they set the defaults with:
#Auto-enable all surfaces for drawing
$P.$j select
auto_enable_data $i $type
I have placed pound marks in front of the last two lines, which works. Helena, know you were having problems with this, so helpfully this helps.
        LTJG Kevin Slover,NOAA   GIS Specialist/Meteorologist/Oceanographer
              Tropical Prediction Center/National Hurricane Center
                    11691 SW 17th Street Miami FL 33165
                 Work: (305) 229-4456 Fax : (305) 553-1264
Kevin Slover wrote:
Bob and Helena,
have resolved the issue as best as I can...I am not sure if this wants
to be added to the CVS list (hopefully not, since I don't know how to
do it..), but it is a simple fix...
defaults with:
            $P.$j select
this helps.
Kevin,
The good news is that your fix seems to work. The only side-effect of
removing the auto-select lines is that if you load vectors from the
command line they will not be automatically drawn on any surfaces. For
example
nviz e=dem v=contours
will draw the raster but not the vector.
The bad news is that in testing the fix I uncovered more problems with
the vector drawing routines. The problem I discovered was if you select
more than one vector and try and draw them on different surfaces (ie.
one vector on one surface and one vector on another). What I found was
that the second vector selected drew on both surfaces, not just the
surface that it was selected to draw on. This may be a TCL error or and
internal nviz error.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
