Hello Guys,
I'm trying to compile Grass5 on a FreeBSD-3.4 system... Markus already
pointed me to the libncurses problem, but I'm still getting some compile
errors... check it out:
GISGEN: src/mapdev/v.autocorr - Wed May 17 11:25:26 EST 2000
/3/gis/grass5.0beta/src/mapdev/v.autocorr
mkdir OBJ.i386-unknown-freebsd3.4
make -f OBJ.i386-unknown-freebsd3.4/make.rules
rm -f OBJ.i386-unknown-freebsd3.4/main.o
gcc -g -O2 -I/3/gis/grass5.0beta/src/libes/vect32/Vlib -I/3/gis/grass5.0beta/src /libes/vect32/diglib -I/3/gis/grass5.0beta/src/include -c main.c
main.c: In function `main':
main.c:156: too many arguments to function `c_matrix'
*** Error code 1
Stop.
GISGEN failure at STEP: src/mapdev/v.autocorr
*** Error code 1
Stop.
[root@aline grass5.0beta]#
Any ideas?
Thanks!
Eduardo.
subject 'unsubscribe grass5'
Hi Eduardo,
On Wed, May 17, 2000 at 11:30:39AM -0300, Eduardo B. Fonseca wrote:
Hello Guys,
I fear you do not have the latest version...
*** Error code 1
Edit line 156 (?)
src/mapdev/v.autocorr/main.c:
from
n = c_matrix (&Map, &Plus, c);
to
n = c_matrix (&Map, &Plus);
Then it compiles. Note that the GRASS/CVS version contains further
fixes from David Gray.
oooopppsss....
I will download the CVS version...
thanks..
Eduardo.
On Wed, 17 May 2000, Markus Neteler wrote:
Hi Eduardo,
> Hello Guys,
> *** Error code 1
Edit line 156 (?)
from
to
