Folks,
A couple weeks ago I wrote for help with my problem using freetype. In short, when I tried to display characters using the freetype library the X driver crashed. I later found that the PNG driver had the same behavior.
In the absence of input, I managed to track the problem down to grass-6.0.2/display/drivers/lib/Text3.c (currently renamed to text3.c). The convert_str function calls iconv. The third and fifth parameters in the iconv prototype are pointers to size_t variables. The convert_str function instead passed pointers to int. iconv misinterpreted the values and that lead to a corruption of the code. With the parameters changed to size_t the code works OK.
This is the first problem I recall arising from using int and size_t interchangeably. This may reflect my environment (gcc 4.0.2 prerelease, GNU libc 2.3.5, SuSE Linux 10.0 on AMD64).
The initial fix was pretty easy, but in studying the code I found other problems (e.g., arguments to memset in convert_str are in the wrong order). Also, the approach in the code to be rather indirect. It works by converting UTF-8 codes to UCS-2BE codes and then converting the UCS-2BE codes to FT_ULong for the freetype library. Not all UTF-8 codes can be represented in UCS-2BE.
I wrote a UTF-8 to FT_ULong converter to get a more direct solution and eliminated convert_str from the code. This is a working solution and probably in most respects a better solution than the current text3.c.
I no longer maintain a CVS installation of GRASS but I think these changes need to be made. I can provide the code to someone who can introduce it to CVS. As it stands the code is largely complete. I would like it to be checked by someone who is a more proficient programmer than I. To be formally complete the UTF-8 decoder needs code added to catch malformed UTF-8 2-byte codes in the range of 0xD800 to 0xDFFF. I think other malformations are caught by my existing code, but their efficiency might be improved.
Roger Miller
