Hi Markus
Regarding the use of -fwritable-strings, the gcc man page has the following:
-fwritable-strings
Store string constants in the writable data segment
and don't uniquize them. This is for compatibility
with old programs which assume they can write into
string constants. `-traditional' also has this ef<AD>
fect.
Writing into string constants is a very bad idea;
"constants" should be constant.
So why do we want to use this feature if it is bad and obsolete?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
from a SuSe developer I got this recommentation (perhaps he
did not think about).
Well, only ps.map on Linux need the -fwritable-strings.
Maybe Radim has improved it already in his current version?
I am not shure. The old ps.map did not work without
-fwritable-strings.
I will take it out of configure. Maybe it could be selectably
added to ps.map on Linux, if required.
Further suggestions are required...
Thanks
On Wed, Jul 26, 2000 at 01:08:36PM +0000, Justin Hickey wrote:
Hi Markus
-fwritable-strings
fect.
Sincerely,
Bangkok, Thailand
GRASS developers,
please update
cvs update Makefile.in
to avoid a severe "rm" call which might kill your
/usr/local/bin/.
I have got this experience
and fixed it.
Only the "clean" targets have been affected.
Hope you did not try it yet...
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
Hello Markus
-fwritable-strings.
How about writing a script to be run after is64bit.sh that will check if the
machine is Linux (the ${SYSTEM} variable in Makefile.in maybe) and then add
-fwritable-strings to the compile lines of the Gmakefiles of ps.map? At least
it would be a quick fix until someone can fix the problem in ps.map. Just a
suggestion.
Sincerely,
Bangkok, Thailand
> -fwritable-strings.
suggestion.
It has nothing to do with GNU/Linux.
Only with old programs doing stuff like:
char * x="Heino";
x[2]='o';
Because the compiler with place &x in protected memory which is not
writable usually.
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
char * x="Heino";
x[2]='o';
writable usually.
Yes, the correct declaration should be :
char x="Heino";
because the variable you can modify is yet the character table, and
not the pointer to a static chain.
It should be easy to upgrade, unless you do something like
x = "another chain";
further in the program... In this case, x must be a pointer and the
first declaration should be used (char *x;) !
Michel Wurtz ENGEES - CEREG
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
> char * x="Heino";
> x[2]='o';
> writable usually.
char x="Heino";
.. as the problem seems to be identified:
Is anyone willing to check src/ps.map/ps.map/ for this?
Hi awk friends,
finally I got it (aem, in between I used a wrong variable
name...). It seems that my system likes the combination of
export VARIABLE
... awk ...
... printf ... "'$VARIABLE'" ...
END...
I have checked it into CVS now.
Many thanks for your patience and suggestions.
