Dear list,
copying maps from PERMANENT to current mapset fails using the same name:
g.copy vect=roads,roads
map roads already exist in mapset PERMANENT
if this is intended, maybe the error message could be extended to sth, like:
map roads already exist in mapset PERMANENT, please add target mapset to map
or sth. else.
thanks
Otto
GMX im TV ... Die Gedanken sind frei ... Schon gesehen?
Jetzt Spot online ansehen: http://www.gmx.net/de/go/tv-spot
