[GRASS5] g.html2man: perl location problem
as the path to "perl" is hardcoded in
src/scripts/contrib/g.html2man/g.html2man
the command:
gmake5 html
fails on several platforms (like CRAY where it is in
/opt/gnu/bin/perl
Today I have added the missding
PERL = @PERL@
into src/CMD/head/head.in
Can we utilize this? Maybe similar to the wrapper
line used for tcltkgrass?
subject 'unsubscribe grass5'
Hi Markus
Markus Neteler wrote:
the command:
gmake5 html
/opt/gnu/bin/perl
PERL = @PERL@
Yes, perl has a similar method. The following is from the "Programming
Perl" book:
#!/bin/sh -- #perl, to stop looping
eval 'exec /usr/bin/perl -S $0 ${1+"$@"}'
    if 0;
.. rest of perl script ...
It's strange but it seems to work for me. In this case you simply
substitute maybe $GRASS_PERL for /usr/bin/perl.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
Hi Justin,
thanks for your suggestion:
Perl" book:
    if 0;
Looks funny! However, the "--" is not supported here:
g.html2man
sh: -- #perl, to stop looping: unrecognized option
Usage: sh [GNU long option] [option] ...
        sh [GNU long option] [option] script-file ...
And also not the -S:
export GRASS_PERL=/usr/bin/perl
g.html2man
/bin/sh: -S: unrecognized option
Shall I simply remove these flags?
Hi Markus
> Hi all,
> the command:
> gmake5 html
> /opt/gnu/bin/perl
> PERL = @PERL@
Perl" book:
    if 0;
s@/usr/bin/perl@perl@ in the above "eval 'exec ...'", then it shouldn't
matter where perl lives as long as it's in $PATH. Some other techniques
are in "man perlrun". One other, which may not always exist:
#! /usr/bin/env perl
Eric G. Miller <egm2@jps.net>
Hi Markus
> "Programming Perl" book:
> if 0;
g.html2man
This is strange. -- is definitely a valid option for sh on Linux. You
can try it on the command line. In fact, I could not use *any* option
after #! /bin/sh, strange. So, I checked the perl newsgroup archive and
there was a post similar to this and the reply was that it was probably
a bug in the GNU sh. However, I found a workaround. Simply call
g.html2man with sh. That is:
sh g.html2man.
This should work, at least my test cases worked here on both Linux and
SGI.
g.html2man
The -S option is an option to perl, not sh, so please do not remove it.
Sincerely,
Bangkok, Thailand
On Fri, Mar 02, 2001 at 11:12:55AM +0700, Justin Hickey wrote:
Hi Markus
> > if 0;
Simply call
sh g.html2man.
SGI.
Yes, now it's o.k.
> g.html2man
Accepted now :slight_smile:
Final question: How can we set
GRASS_PERL (from src/CMD/head/head.$ARCH)? I just get no idea,
Yours
Hi Markus
We can handle it just like we do GISBASE in src/general/grass.src. That
is, we put something like
GRASS_PERL=PERL_COMMAND
in grass.src and then add the appropriate substitution to the sed
command in the Gmakefile. Do you want me to make the change, or wait on
it?
Sincerely,
Bangkok, Thailand
On Fri, Mar 02, 2001 at 05:14:30PM +0700, Justin Hickey wrote:
Hi Markus
it?
Justin,
please go ahead...
Thanks
Hi Markus
> That is, we put something like
> wait on it?
Justin,
please go ahead...
Done and it seems to substitute fine for me.
Sincerely,
Bangkok, Thailand
Hi Justin,
> > wait on it?
> Justin,
> please go ahead...
I have updated html/Gmakefile and
but it seems that GRASS_PERL is not sent to g.html2man. Do I have
to add it as parameter in above html/Gmakefile?
Hi Justin,
Hi Markus
it?
unfortunately I don't get g.html2man working properly. It seems not
to recognize the parameters given in html/Gmakefile
If anyone could look into this...
Thanks!
Hi Markus
Fixed. The environment variable is defined in make.mid, but it was not
being passed to the html2man script. Please let me know of any other
problems.
Sincerely,
Bangkok, Thailand
On Mon, Mar 05, 2001 at 12:13:00PM +0700, Justin Hickey wrote:
Hi Markus
problems.
Great, works perfectly now!
Thanks, Justin,
