From: Markus Neteler <neteler@geog.uni-hannover.de>
just found (probably) a solution for the problem of parameter/flag
positioning in GRASS scripts (especially tcltkgrass is affected, reported by
Andreas for g.manual):getopts
http://orca.st.usm.edu/~seyfarth/unix/unix-6-11-17.html* getopts gets shell scripts options
* while getopts ivo: op
do
case $op in
i) invert=1 ;;
v) verbose=1 ;;
o) filename=$OPTARG ;;
esac
done
shift 'expr $OPTIND - 1'* After the shift the remaining arguments are in $*
* Script option syntax is flexible:
doit -i -v file1
doit -iv file1 -o file2This might be a way to allow flexible flag/parameters:
man getopts:
"getopts is used by shell procedures to parse positional parameters."Maybe someone is willing to update g.manual script and we update other
scripts later while learning from the g.manual implementation.
Hi developers,
Actually it's another problem. getopts can not understand command line like
the following:
doit this that -i -v file1 # BAD USAGE
getopts assumes that ALL options(like -?) are followed by another arguments.
doit -i -v file1 this that # GOOD USAGE
And tcltkgrass may want bad usage
I think the latter is more standard. isn't it?
Anyway, I changed g.manual to use getopts. This can not work with current
tcltkgrass.
"g.manual entries=d.area -f" should be changed to "g.manual -f entries=d.area".
In addition, -f flag is not implemented by original g.manual script author
and i don't know what it is.
Now, g.manual allows some flexibility. However, each option in g.manual is
exclusive to another. So this may be useless
Yours,
Huidae Cho
subject 'unsubscribe grass5'
