[GRASS5] g.region G_usage() commented out?
The inter version of g.region has a call to G_usage() in die()
commented out. Anybody know why this might be? Telling somebody that
something is an "** illegal value **" is almost completely useless to
them. Much better to explain what change is necessary to bring the
value within bounds.
-russ nelson http://russnelson.com | Okay, enough is enough!
Crynwr sells support for free software | PGPok | Can we PLEASE all stop
521 Pleasant Valley Rd. | +1 315 268 1925 voice | using insecure Microsoft
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | email products???
commented out.
die() is in the "cmd" version of g.region, not the "inter" version.
There is seldom any point in calling G_usage() directly. G_usage()
generates a usage message based upon the options and flags which have
been defined by G_define_option() and G_define_flag() respectively.
G_parser() will call G_usage() if it detects an error (a required
option wasn't specified, an unknown option was specified, etc), or if
the "help" option was given. If G_parser() indicates success, the
nature of any remaining errors is such that G_usage() is unlikely to
provide any meaningful clues.
If die() is called, the error is that one of the values isn't in a
suitable format; G_usage() won't help here. The set of supported
variations is sufficiently large that it probably isn't sensible to
document them within the usage message.
However, the manual page should mention the fact that, for lat/lon
locations, values have to be in DMS. But it doesn't.
Glynn Clements writes:
> > commented out.
Quite right, yes I meant the cmd version.
What about changing die() so that it also prints the ->description
string? Like the diff below? It's not perfect, but it's an
improvement.
diff -u -r1.8 main.c
--- src/general/g.region/cmd/main.c 22 Jan 2002 04:51:04 -0000 1.8
+++ src/general/g.region/cmd/main.c 15 May 2002 04:34:35 -0000
@@ -704,7 +704,7 @@
static void die(struct Option *parm)
- fprintf(stderr,"<%s=%s> ** illegal value **\n\n", parm->key, parm->answer);
+ fprintf(stderr,"<%s=%s> not recognized, expecting:\n%s\n", parm->key, parm->answer, parm->description);
     G_usage();
On Wed, May 15, 2002 at 12:38:18AM -0400, Russell Nelson wrote:
[snip]
improvement.
@@ -704,7 +704,7 @@
     G_usage();
I'm not sure that adds anything to the error report.
On a general note, would it be desirable to have G_{lat|lon|llres}_scan
fall back to reading doubles and then range check the value?
Nitpick: I dislike "illegal value". IMHO, "invalid input" is more
"correct" since the law has nothing to do with the matter. Also, no
good reason not to use G_fatal_error() here. Technically, exit(1) is
not well defined either (exit(EXIT_FAILURE) is).
Eric G. Miller <egm2@jps.net>
> improvement.
> @@ -704,7 +704,7 @@
> G_usage();
Well, the description field will indicate that the format has to be
dd:mm:ss for lat/lon locations.
However, the mechanism which is used involves calling library
functions before G_parser() has returned, which would stop working if
we were implement "standard" options such as "location=".
I would say so.
At least exit(1) is an improvement over exit(-1); the latter is all
too common. Also, while exit(1) may not be defined by ANSI C, the
various Unix specifications all dictate that zero indicates success
and non-zero indicates failure.
I can't imagine it hurts to give a user more information.
So, you're saying that the entire die() function is not wisely implemented?
> I would say so.
Speaking of which, what's this MARKER stuff in those functions? Is
that a holder from the FORTRAN implementation? Anybody mind if I add
code to read doubles and delete the MARKER stuff at the same time?
No, I'm saying that the way in which the "description" fields are
initialised isn't a good idea.
Basically, I'm opposed to main() calling anything other than a few
specific functions[1] before G_parser() has returned.
The main reason is to allow the parser to support some "built in"
options (e.g. location=, mapset=, monitor=), in the same way that all
Xt-based programs support -display, -bg, -fg, -font etc.
A secondary reason is that, when the "help" or "--interface-description"
switches are used, the output depends upon the context (current
location, mapset, region, monitor etc), but with no indication that this
is the case.
[1] G_gisinit, G_define_module, G_define_{option,flag}.
Ahhhh, I see. Okay, then I'll leave that alone and add double
scanning/bounds-checking to G_{lat,lon,llres}_scan, and remove the
MARKER code (if it is indeed silly).
> I would say so.
Doh! Actually, no, it wouldn't be desirable. Why? Because the only
place those functions are called is from G_scan_{northing,easting,resolution},
and if those functions fail, then they fall back to simply scanning a double.
But while I was looking at the code, I spotted two ways to simplify
the code. Patch below:
Are you sure about the removal of the "marker" code? I would guess
that it's there for a reason (although I have no idea what that reason
might be).
> might be).
Reasonably. I tracked down all the subroutines called to make sure
they are happy with a null string. Perhaps it's something left over
from the Fortran code? I seem to recall needing to put such things
into Fortran prorgams.
-russ nelson http://russnelson.com | Nelson's principle: when
Crynwr sells support for free software | PGPok | someone proposes a solution,
521 Pleasant Valley Rd. | +1 315 268 1925 voice | always ask for a definition
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | of the problem it solves.
> might be).
I'm not sure that this has anything to do with Fortran.
AFAICT, the code appears to be ensuring that the code processes the
entire string, and not just some initial portion of it.
But tbuf is filled by copying characters from buf up to the first
null. Therefore, buf cannot contain any embedded nulls, and
strlen(buf) is going to be equal to strchr(tbuf, MARKER) - tbuf every
time. So why not just run up to the null? The only reason I can see
to have MARKER would be if you wanted to safely look at buf[i] and
buf[i+1] without first checking to see if buf[i] is a '\0'. The
original code didn't do that, but ahhhh, I see that I have introduced
a potential segfault. Revised patch, which actually is simpler and
easier to understand:
Index: src/libes/gis/ll_scan.c
RCS file: /home/grass/grassrepository/grass/src/libes/gis/ll_scan.c,v
retrieving revision 1.1.1.1
diff -u -r1.1.1.1 ll_scan.c
--- src/libes/gis/ll_scan.c 29 Dec 1999 15:10:30 -0000 1.1.1.1
+++ src/libes/gis/ll_scan.c 20 May 2002 13:49:13 -0000
@@ -53,13 +53,9 @@
int G_llres_scan ( char *buf, double *res)
- char tbuf[100];
- sprintf (tbuf, "%se", buf);
- return scan_ll (tbuf, "we", res, 0);
+ return scan_ll (buf, NULL, res, 0);
-#define MARKER 1
static int scan_ll (
     char *buf,
     char *dir,
@@ -70,10 +66,6 @@
     int d,m,s;
     char ps[20], *pps;
     double p, f;
- char tbuf[100];
- sprintf (tbuf, "%s%c", buf, MARKER); /* add a marker at end of string */
- buf = tbuf;
     if (sscanf (buf, "%d:%d:%d.%[0123456789]%[^\n]", &d, &m, &s, ps, h) == 5)
@@ -117,13 +109,16 @@
     G_strip (h);
- if (*result == 0.0 && *h == MARKER)
+ if (*result == 0.0 && *h == '\0')
   return (1);
+ if (dir == NULL)
+ return *h == '\0';
     if (*h >= 'A' && *h <= 'Z') *h += 'a' - 'A';
     if (*h != dir[0] && *h != dir[1])
   return 0;
- if (h[1] != MARKER)
+ if (h[1] != '\0')
   return 0;
     if (*h == dir[0] && *result != 0.0)
It still changes the semantics of the function. The existing version
will reject strings which contain trailing whitespace, due to:
    if (h[1] != MARKER)
  return 0;
If the marker is removed, G_strip() will strip any trailing whitespace
before the test is performed.
I'm not suggesting that I have a personal preference for the existing
behaviour; I'm just asking you (or, for that matter, anyone else)
whether you are sure that it's safe to change it.
My *suspicion* is that it *probably* is safe.
> if (h[1] != MARKER)
> return 0;
True enough. Is this behavior anybody wishes to preserve?
