I've modified the loops in s.vol.idw and r3.out.v5d to follow the same pattern:
all loop counters increment.
easting starts in the west and increments.
northing starts in the north and decrements.
level starts at the top and decrements.
When I regrid a 3d site file, and then export it to v5d format, the data loads into vis5d with all the axes orientationed correctly! I guess that shouldn't be too suprising
I'm getting on to the other modules as time permits.
Does someone want me send you files, or is that so trivial you can just make the change?
John Harrop
pattern:
By "decrements", do you mean that an increasing index corresponds to a
decreasing geographical coordinate (i.e. south/down)?
as time permits.
make the change?
Can you send diffs?
The preferred mechanism is to run "cvs diff -u <dir>" from the
top-level directory of the GRASS source tree, where <dir> is the
deepest common directory of the changed files. E.g.:
cd /usr/src/grass
cvs diff src.contrib/GMSL/g3d/src3d
If you don't have CVS access configured, the next best approach is to
use "diff -ru <dir1> <dir2>", where <dir1> is the path to an
unmodified version of the source and <dir2> is the path to the
modified version of the source.
In the last resort, you can send any changed files to me (preferably
as a .tar.gz file, with the relative paths preserved) and I'll look
into it.
