On Friday 04 October 2002 03:32 pm, Helena Mitasova wrote:
Radim,
Jaro got the v.surf.rst running and results look good, but for more
complete testing we need a little bit more info.
On the grass51 web site you have a list of modules that need to be updated,
do you also have a list
of modules that are already done and that you are currently working on (so
that we are not asking you too many questions?)
It is the same site:
http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/v.modules.html
Y = yes = updated, "Working on" = working on. May be is not clear from that
page, let me know what is confusing?
So far I have found the following
v.ascii v.category v.convert v.surf.rst v.build v.clean
v.mapcalc
Just a note: I have here some other modules not yet commited:
v.distance, v.salesman, v.net, v.steiner
and I am writing draft man pages for them (you may expect more questions
from me).
Thank you a lot.
Now, what command should I use to find the names of zcol and scol? With
v.category report I get only field 1
which is category, how do I get the info about elevation?
'zcol' and 'scol' are names of columns in the database table, so you need
first some table with at least 2 columns like:
cat(int) - some identifier used as link beteen vector and DB table
zcol(double) - z values
then the connection must be defined in 'DB' file, see:
http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/vector.html#attr
Do you plan to
write something like v.info that would
give a comprehensive information about what is in the vector file?
(something like s.info?)
v.info must be updated, but it is not on the top of my list.
Any chance for v.surf.rst to read directly shape files (not really
important, but if it is easy to do it would be great,
most of the data that we get are either nasty mixed-up CAD data or shape
files).
Of course, you need just to define the vector as shapefile, see
g51test/test/vector/lake.shp/frmt in thr demo package. 3D shapefiles are not
yet supported, but it will be trivial as such files are supported by shapelib.
(BTW: may be, that there is some bug in shapefile support (v.build), but
currently I don't have time to fix it.)
It is still kind of adventure to use grass51 because there is so little
info about it
and we still haven't figured out how to call grass5 commands from grass51,
but we will get there eventually.
I don't know what is the correct way if any exists, you can run grass51 and
grass50 at the same time (carefully) or I use the script g50 which just sets
some variables and runs the command:
export PATH=/amd/ssi0/ssi/blazek/grass/dist.i686-pc-linux-gnu/bin:$PATH;
export GISBASE=/amd/ssi0/ssi/blazek/grass/dist.i686-pc-linux-gnu;
so that I can run in g51 shell g50 commands, for example:
g50 d.sites
Radim
