[GRASS5] gis.m as default GUI
Is gis.m ready to be the default GUI?
"grass6 -gui"
"If required, restart the graphical user interface with: d.m &"
Hamish
IMHO, it is ready to be default if
1.v.digit is working again (it IS working on my Mac, but I don't know about
anyone else) and
2. a weird start up bug that just cropped up is fixed (the one I emailed
about last week on Cygwin). Again, I can't duplicate it so I'm having a
hard time knowing if it's just a fluke, a real bug, a bug that is now fixed,
or what.
I don't know of any other problematic bugs (I'm using it all the time
now)--but I'm SURE that some will crop up if we make it default. :wink:
I also managed to do an upgrade on the GRASS intro screen. It's not exactly
what I had in mind, but it is heading in that direction and the best I can
do before I leave for San Juan and we hit the end of April feature freeze. I
redid the appearance, organization, and some of the explanatory text. I also
added a new button to create a location from a georeferenced raster or
vector file using g.proj. I'll commit it tomorrow morning.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Mon, 24 Apr 2006 15:00:16 +1200
To: grass5 <grass5@grass.itc.it>
Subject: [GRASS5] gis.m as default GUI
"grass6 -gui"
Hamish
about anyone else) and
it is working for me on Debian/Stable i386. (I never saw it broken)
Hamish
oh that's from the command line, from gis.m draw icon:
child process exited abnormally
    while executing
"exec -- d.mon select=x1 >& /dev/null"
    ("eval" body line 1)
    invoked from within
"eval exec -- $cmd $args >& /dev/null"
    (procedure "run" line 6)
    invoked from within
"run d.mon select=x1"
    invoked from within
"eval run $cmd $args"
    (procedure "runcmd" line 6)
    invoked from within
"runcmd "d.mon select=x$xmon""
    invoked from within
"if ![catch {open "|d.mon -L" r} input] {
      while {[gets $input line] >= 0} {
              if {[regexp -nocase "$xmon.*not running" $line]} {
          run..."
    (procedure "GmVector::WorkOnVector" line 28)
    invoked from within
"GmVector::WorkOnVector $sel 0"
    ("vector" arm line 2)
    invoked from within
"switch $type {
        raster {
        Gm::xmon term r.digit
            return
        vector {
    (procedure "GmTree::vedit" line 16)
    invoked from within
"GmTree::vedit"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .mainframe.topf.tb1.bbox5.b0"
    (command bound to event)
H.
anyone else) and
In the users list you mentioned that v.digit and i.points still use an X window display. Are you working on the v.digit? When will it be non-X? I was going to try building GRASS an Mac OS X without any X, using Apple's Tcl/Tk (Aqua on Tiger), and start using the new GUI. (I know I'll lose NVIZ, but I haven't had time to look at it yet)
What combination of X or Aqua Tcl/Tk and X/no-X are you using to develop gis.m? Maybe I'll try leaving in X for now but try using Tcl/Tk Aqua.
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
> know about
> anyone else) and
be non-X?
AFAIK, no-one is actively working on a Tcl/Tk replacement for v.digit
at the moment.
The main issue is that we need some way to get vector maps out of and
back into GRASS without loss of information, and with the external
format containing the topology information (the last part is why
v.out.ascii doesn't suffice).
Rats. I didn't realize. I guess Mac users will be stuck with an X Tcl/Tk for a while. I suppose I could give it a try - run it in the Aqua Tcl/Tk and see if it opens an X window for v.digit display. Unless someone knows definitely that this won't work...
know about
anyone else) and
be non-X?
at the moment.
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
It shouldn't make any difference which version of Tcl/Tk you use
(there might be some compatibility issues, but there isn't any
inherent reason why gis.m can't be made to work with OSX or Windows
versions of Tcl/Tk).
The point is that v.digit still relies upon XDRIVER, which requires an
X display.
I've successfully tried starting GRASS without OSX using Lorenzo Moretti's
binaries. This uses TclTk aqua and the Mac terminal. It works fine.
Obviously, it's missing those pieces that still require x11. I don't think
these will be replaced before the rapidly approaching version 6.2 release.
But I (and hopefully others??) will be working on them.
For TclTk, I think replacing d.profile will be pretty straightforward. I'm
have some ideas at least about how do to i.points and r.digit.
v.digit will take someone that can understand the vector architecture and do
some C programming too.
It seems to me that nviz doesn't really need x11, but this is an opinion
that is pretty ignorant of how it works internally (I've looked at the TclTk
part but don't understand how it interacts with the C part or X11 part).
There may be a few more commands that need x11, but not many and the number
is shrinking.
Michael
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
Reply-To: William Kyngesburye <kyngchaos@kyngchaos.com>
Date: Mon, 24 Apr 2006 09:02:00 -0500
To: <grass5@grass.itc.it>
Cc: Michael Barton <michael.barton@asu.edu>
Subject: Re: [GRASS5] gis.m as default GUI
know about
anyone else) and
Tk Aqua.
I'm building this weekend's snapshot as I write, linked to Tiger's trimmed down Aqua Tcl/Tk, with only X11 support in GRASS (no lesstif or glw). I'll see how that goes. (Panther users would have to download and install the full Tcl/Tk Aqua, since Apple's Tcl is missing wish on Panther)
r.digit would be good - I actually have been using that one regularly recently.
I don't have any great need for v.digit now, but I'm sure others do. In the future I hope to start using it more. Qgis is an alternative, but I'm holding off for 0.8.
I poked around in that once - tried to get it to build with Apple stuff, GL, Tcltk. Really, NVIZ needs X11 only indirectly.
First, it needs a Tcl extension, Togl, that until recently didn't work on Mac OS X Aqua, only with OSX X11. v1.7.x now works on OS X Aqua, but the old 1.5 source is still what's in the NVIZ source.
There is the GL stuff - adjusting link flags, using AGL, tcltk flags, ...
I got as far as updating togl, and fiddling with the GL stuff, and got a lot of multiple defs errors between Apple's GL and X11's GL. Even without X11 support in GRASS, I couldn't figure out what was still trying to link to X11 libraries.
Then the new GUI discussion and development started, and I gave up. Someone else would be better off figuring all this out. Tho I should probably add a bug report to add the new togl to NVIZ.
is shrinking.
From my notes, I have r3.showdspf as needing glw and mo/less-tif, indirectly needing X11. But the funtionality looks like it's in NVIZ.
And xganim needs mo/less-tif.
And of course the NVIZ beast.
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
is shrinking.
have you tried xganim.tcl that Glynn has sent some time ago?
Helena
- Marvin
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Helena Mitasova
Department of Marine, Earth and Atmospheric Sciences
North Carolina State University
1125 Jordan Hall
NCSU Box 8208
Raleigh, NC 27695-8208
http://skagit.meas.ncsu.edu/~helena/
email: hmitaso@unity.ncsu.edu
ph: 919-513-1327 (no voicemail)
fax 919 515-7802
I have that, but never got around to trying it, what with the wall I ran into with NVIZ and GL. And it's not a very high priority, yet, no need for it right now.
If my current gis.m/Aqua Tcl test works well, I may give it a try.
is shrinking.
Helena
GRASS 6.1 CVS 4/22 with Tcl/Tk Aqua (Tiger)
On initial startup of gis.m: (seems to come from starting a display monitor - I get the same thing when opening a second display minotor)
can't read "_data(.gronsole.gronsole,1,donecmd)": no such element in array
     while executing
"set donecmd $_data($path,$ci,donecmd)"
     (procedure "Gronsole::done_command" line 3)
     invoked from within
"Gronsole::done_command $path $ci"
     (procedure "Gronsole::execout" line 19)
     invoked from within
"Gronsole::execout $path $cmd $ci Gronsole::execwait"
     (procedure "Gronsole::run_wait" line 6)
     invoked from within
"Gronsole::run_wait .gronsole.gronsole {g.region -u save=mon_1 --o} gism"
     invoked from within
"eval Gronsole::$cmd .gronsole.gronsole $args"
     (procedure ".gronsole.gronsole" line 1)
     invoked from within
"$gronsole run_wait $cmd gism"
     (procedure "run_panel" line 4)
     invoked from within
"run_panel $cmd"
     (procedure "MapCanvas::mapsettings" line 26)
     invoked from within
"MapCanvas::mapsettings $mon"
     (procedure "MapCanvas::do_resize" line 11)
     invoked from within
"MapCanvas::do_resize 1"
     ("after" script)
Add a raster layer, then Display Active Layers:
     while executing
"exec -- d.font romans >& /dev/null"
     invoked from within
     invoked from within
"run d.font romans"
     invoked from within
     invoked from within
"runcmd "d.font romans""
     (procedure "MapCanvas::drawmap" line 33)
     invoked from within
"MapCanvas::drawmap 1 0"
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
"Button::_release .mapcan(1).mf.topf.tb0.bbox1.b0"
Second display monitor opens with above errors, then when closing it:
     while executing
"exec -- g.mremove -f region=mon_2 >& /dev/null"
     invoked from within
     invoked from within
"run g.mremove -f region=mon_2"
     invoked from within
     invoked from within
"runcmd "g.mremove -f region=mon_$mon ""
     (procedure "MapCanvas::cleanup" line 6)
     invoked from within
"MapCanvas::cleanup $mon $destroywin"
Restarted GRASS with X11 Tcl/Tk (GRASS still built with Tcl/Tk Aqua) and it ran fine.
Is there maybe some GRASS environment settings that are not getting passed over to Aqua Tcl? It's like it's having problems when it gets to running the grass commands.
Or did I miss something in the build and install? CVS snapshot 4/22, I'm assuming everything is there for gis.m in the source.
Other than that, in Aqua, all GUI widgets are bigger. Kinda expected. The buttons are at their width limits to show all the text of the button - are button widths fixed, or variable to let Tcl size to fit the text (if that's possible)?
I like having a normal Mac-style menu in the menubar instead of per window. Do you know if there is a way to rename the wish application shell at runtime so it shows up as GRASS (or GRASS 6.1CVS or similar) instead of wish in the menu and the Dock?
The new startup screen is great Michael.
on main screen and define new proj loc:
"Path to location" [nee database] -> "Path containing location(s)" ?
"Define new projection location" -> Define new projected location" ?
It'll be even better when we can simply double click a mapset name :wink:
I'm have some ideas at least about how do to i.points and r.digit.
r.digit should be easy. The C version is already just a frontend that
writes to an ASCII file, which in the final step is fed to r.in.poly
creating the raster.
opinion that is pretty ignorant of how it works internally (I've
looked at the TclTk part but don't understand how it interacts with
$ grep -rI '#include' visualization/nviz/ | grep X11 | wc -l
33
$ grep -rI '#include' visualization/nviz/ | grep X11 | cut -f1 -d: | uniq
visualization/nviz/src/do_zoom.c
visualization/nviz/src/interface.h
visualization/nviz/src/interface_old.h
visualization/nviz/src/tkInt4.0.h
visualization/nviz/src/tkUnixPort.h
visualization/nviz/src/tkWinPort.h
visualization/nviz/src/togl.c
visualization/nviz/src/togl.h
visualization/nviz/src/togl_cb.c
visualization/nviz/src/togl_flythrough.c
.. NVIZ needs X11, although it is full of:
#ifdef X11
#endif
which indicates that it could be possible to use if compiled without X11
support, perhaps with diminished functionality. I would guess NVIZ on
OSX without X11 would be doable, but might take some minor adjustments.
It probably needs to be made with:
./configure --without-x
Hamish
export GRASS_WISH=/path/to/wish
http://grass.ibiblio.org/grass61/manuals/html61_user/variables.html
Hamish
Michael sent me the code & now it is in CVS. Nice one!
Hamish
The version of the Togl widget in the GRASS source tree only has X11
and Windows implementations. Version 1.7 of Togl supports OSX; someone
may wish to try merging that.
The image-dump code in do_zoom.c also uses X11-specific functions, but
that could be disabled without affecting the rest of NVIZ.
The OGSF library responsible for the actual rendering doesn't use any
platform-specific functions.
That's not what I mean - I know about using GRASS_WISH to set the particular wish binary to use, that's how I force GRASS to use my X11 Tcl/Tk instead of Apple's default. It's just that when I use the Tk Aqua wish, it's a separate Mac OS X application, not run inside of X11, and the system just knows it as 'wish' (in the menubar, the Dock, and CLI ps command).
I know in Java applications, there is a way to rename the application so it doesn't run as 'Java'. Is there something similar for wish?
Hamish
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
New gui is powerful for all platforms.
There are some modules that require X11 like v.digit, nviz, r.le.* and others.
v.digit has a bug in Mac OS X: it doesn't load toolbox.tcl. Jesse Hamner <jhamner@emory.edu> has a temporary solution that work in Mac OS X 10.4.x: he has built v.digit like wish application inside Mac OS X 10.4.x and it works (the size is 184 kb versus 80 kb): it's included inside last Grass cvs OS X binary.
You can find more info at: http://userwww.service.emory.edu/~jhamner/grass.html
Nviz requires some changes linked to Togl library (yes togl 1.7 works in Mac OS X).
It also need a good d.out.file script for high resolution output.
In the future Grass can be built without-x (e.g. stand-alone mode) or with-x (network mode).
If someone has Mac OS X can test last cvs in OS X menu (TclTk Aqua): if you close X11 and enter "gis.m &" in Terminal, Grass works in TclTk Aqua only but NVIZ, v.digit and others.
New GUI is fantastic !!
__________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it ||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/ || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
ENEA - The Italian Agency for New Technologies, Energy and the Environment
Try "wish -name <name>", or putting "tk appname <name>" at the
beginning of the script.
