[GRASS5] GIS Manager for 5.7 - need help with makefile before commit
I am ready to commit the new GIS manager for GRASS 5.7 (merged display manager and tcltkgrass menus). I modified the makefile to include a new file menu.tcl. However, I’m not sure how to do the makefile to make sure that an included subdirectory for scripts gets built and populated as $GISBASE/etc/dm/script. This subdirectory has some scripts that are needed with the menu but not otherwise. For example, it contains r.colors.rules that lets the user enter color table rules in an xterm via the gui.
I’d rather not commit the rest of the changes until I can be sure that this subdirectory gets built. I might be able to modify the makefile appropriately, but I’m not sure enough to do it.
Could someone who knows more about this offer to do this? If so, I will commit the rest of the files and let you know when I’ve done so, so that you can fix the makefile.
Thanks much
Michael
Michael Barton, Professor & Curator
School of Human Diversity and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
menu.tcl. However, I¹m not sure how to do the makefile to make sure that an
If you can determine a pattern (or list of patterns) which will match
all of the files to be copied, but not anything else (e.g. the CVS
subdirectory), the simplest solution is e.g.:
  $(MKDIR) $(GISBASE)/etc/dm/script
  $(INSTALL) -m 644 script/*.* $(GISBASE)/etc/dm/script
[This assumes that all scripts contain at least one dot.]
