Yes it should be fine to remove the interpretor lines from panel_label.tcl and panel_scale.tcl.
You will have to remove the first three lines from structlib.tcl. But again that should be fine. Everything is called from a running nviz / interprtor, so therefore the interprtor line should not be necessary.
Bob
Markus Neteler wrote:
On Tue, Feb 22, 2005 at 12:19:53PM -0500, Steve Halasz wrote:
AFAIKT glnviz/nvwish doesn't exist. Should these be:
On Mon, Feb 28, 2005 at 11:30:41AM -0400, Bob Covill wrote:
Markus,
Thanks, done in CVS.
Bob
>>Hi,
>>#!/usr/lib/grass/bin/nviz -f
>>instead?
>>W: grass:
>>interpreter-not-absolute
>>./usr/lib/grass/etc/nviz2.2/scripts/panel_mkdspf.tcl #!../glnviz/nvwish
>>W: grass:
>>unusual-interpreter ./usr/lib/grass/etc/nviz2.2/scripts/panel_mkdspf.tcl
>>#!../glnviz/nvwish
>>W: grass:
>>./usr/lib/grass/etc/nviz2.2/scripts/panel_scale.tcl #!../glnviz/nvwish
>>W: grass:
>>unusual-interpreter ./usr/lib/grass/etc/nviz2.2/scripts/panel_scale.tcl
>>#!../glnviz/nvwish
>>W: grass:
>>unusual-interpreter ./usr/lib/grass/etc/nviz2.2/scripts/panel_label.tcl
>>#!/usr/lib/grass/etc/nviz2.2/glnviz/nvwish
>>Thanks,
>>Steve
>What about just removing these ../glnviz/nvwish lines?
>Seems to be a bit messy at time:
>----- panel_label.tcl
>#!../glnviz.new/nvwish -f
>----- panel_scale.tcl
>#!../glnviz/nvwish -f
>----- structlib.tcl
>#!/bin/sh
>The file panel_mkdspf.tcl was removed today (obsolete).
>All the other *.tcl scripts in grass60/visualization/nviz/scripts
>do not contain any "startup" line as reported above.
>Bob, any suggestions?
>Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
