[GRASS5] Gmakefile question
I am trying to write a Gmakefile that creates two executables, A and B.
A and B are identical, except that they should be compiled with different
flags.
CFLAGS += ...
all: A B
#OBJ should be compiled with -DELEV_FLOAT
A: $(OBJ)
   $(CC) $(LDFLAGS) -o $@ $(OBJ) $(LIBS)
#OBJ should be compiled with -DELEV_SHORT
B: $(OBJ)
the .o files in OBJ are compiled using CFLAGS. Anybody knows how to change
the CFLAGS inside a rule? or how to get around this?
thanks,
-Laura
flags.
CFLAGS += ...
all: A B
A: $(OBJ)
B: $(OBJ)
This is something which the GRASS5 build system doesn't support. The
only solution is to use separate directories with separate Gmakefiles.
