Hello,
Using the latest CVS versions of GRASS5.0, GRASS5.1 and GDAL, I have
trouble compiling GRASS5.1. I get the error message below when the
compilation process reaches v.out.ogr. GDAL's files are installed in
/usr/local/lib/ and /usr/local/include/.
Can someone help me with this ?
Moritz
configure command:
CFLAGS="-g -Wall" ./configure --with-grass50=/data/GRASSCVS/grass
--with-tcltk-includes=/usr/include/tcl8.3/
--with-postgres-includes="/usr/include/postgresql/
/usr/include/postgresql/internal/" --with-readline --with-dbm
--with-includes="/usr/include/ /usr/local/include/" --with-libs="/usr/lib/
/usr/local/lib"
make output:
v.out.ogr
make[2]: Entering directory `/data/GRASSCVS/grass51/vector/v.out.ogr'
gcc -I/usr/include/ -I/usr/local/include/ -g -Wall -Wall -I/usr/include/
-I/usr/local/include/ -I/data/GRASSCVS/grass51/include
-I/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/include
-I/usr/include/postgresql/ -I/usr/include/postgresql/internal/
-I/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/include \
-o OBJ.i686-pc-linux-gnu/main.o -c main.c
/data/GRASSCVS/grass51/include/gis.h:36: warning: `GRASS_copyright'
defined but not used
gcc -L/usr/lib/ -L/usr/local/lib
-L/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib -L/usr/lib/
-L/usr/local/lib -o
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/etc/bin/cmd/v.out.ogr
in.o /data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_vect.a
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dig2.a
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_shape.a -lpq
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_btree.a
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_rtree.a
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_linkm.a
/data
/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dbmi.a
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_dbmi.a
/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib/libgrass_gis.a -ldl
-lm -lz
OBJ.i686-pc-linux-gnu/main.o(.text+0x296): In function `main':
/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:145: référence indéfinie
vers « OGRRegisterAll »
OBJ.i686-pc-linux-gnu/main.o(.text+0x2a1):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:146:
référence indéfinie vers « OGRGetDriverCount »
OBJ.i686-pc-linux-gnu/main.o(.text+0x2ca):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:148:
OBJ.i686-pc-linux-gnu/main.o(.text+0x2df):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:149:
référence indéfinie vers « OGRGetDriver »
OBJ.i686-pc-linux-gnu/main.o(.text+0x2f6):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:150:
référence indéfinie vers « OGR_Dr_GetName »
OBJ.i686-pc-linux-gnu/main.o(.text+0x31d):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:151:
OBJ.i686-pc-linux-gnu/main.o(.text+0x382):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:157:
OBJ.i686-pc-linux-gnu/main.o(.text+0x3a1):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:158:
référence indéfinie vers « OGR_Dr_CreateDataSource »
OBJ.i686-pc-linux-gnu/main.o(.text+0x3e1):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:161:
référence indéfinie vers « OGR_DS_CreateLayer »
OBJ.i686-pc-linux-gnu/main.o(.text+0x441):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:170:
référence indéfinie vers « OGR_Fld_Create »
OBJ.i686-pc-linux-gnu/main.o(.text+0x460):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:171:
référence indéfinie vers « OGR_L_CreateField »
OBJ.i686-pc-linux-gnu/main.o(.text+0x7aa):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:220:
OBJ.i686-pc-linux-gnu/main.o(.text+0x7c9):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:221:
OBJ.i686-pc-linux-gnu/main.o(.text+0x803):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:228:
référence indéfinie vers « OGR_L_GetLayerDefn »
OBJ.i686-pc-linux-gnu/main.o(.text+0x81a):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:229:
référence indéfinie vers « OGR_F_Create »
OBJ.i686-pc-linux-gnu/main.o(.text+0x972):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:253:
référence indéfinie vers « OGR_G_CreateGeometry »
OBJ.i686-pc-linux-gnu/main.o(.text+0x9ed):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:255:
référence indéfinie vers « OGR_G_AddPoint »
OBJ.i686-pc-linux-gnu/main.o(.text+0xa0b):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:257:
référence indéfinie vers « OGR_F_SetGeometry »
OBJ.i686-pc-linux-gnu/main.o(.text+0xa22):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:258:
référence indéfinie vers « OGR_L_CreateFeature »
OBJ.i686-pc-linux-gnu/main.o(.text+0xa33):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:259:
référence indéfinie vers « OGR_G_DestroyGeometry »
OBJ.i686-pc-linux-gnu/main.o(.text+0xb58):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:284:
OBJ.i686-pc-linux-gnu/main.o(.text+0xbed):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:288:
OBJ.i686-pc-linux-gnu/main.o(.text+0xd74):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:299:
OBJ.i686-pc-linux-gnu/main.o(.text+0xe8e):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:310:
référence indéfinie vers « OGR_G_CreateFromWkt »
OBJ.i686-pc-linux-gnu/main.o(.text+0xea5):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:311:
OBJ.i686-pc-linux-gnu/main.o(.text+0xebc):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:313:
OBJ.i686-pc-linux-gnu/main.o(.text+0xecd):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:314:
OBJ.i686-pc-linux-gnu/main.o(.text+0xee8):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:318:
référence indéfinie vers « OGR_F_Destroy »
OBJ.i686-pc-linux-gnu/main.o(.text+0xef9):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:319:
référence indéfinie vers « OGR_DS_Destroy »
OBJ.i686-pc-linux-gnu/main.o(.text+0x1011): In function `mk_att':
/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:363: référence indéfinie
vers « OGR_F_UnsetField »
OBJ.i686-pc-linux-gnu/main.o(.text+0x1028):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:365:
référence indéfinie vers « OGR_F_UnsetField »
OBJ.i686-pc-linux-gnu/main.o(.text+0x110c):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:381:
référence indéfinie vers « OGR_F_SetFieldInteger »
OBJ.i686-pc-linux-gnu/main.o(.text+0x125d):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:396:
OBJ.i686-pc-linux-gnu/main.o(.text+0x1288):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:399:
référence indéfinie vers « OGR_F_SetFieldDouble »
OBJ.i686-pc-linux-gnu/main.o(.text+0x12ad):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:402:
référence indéfinie vers « OGR_F_SetFieldString »
OBJ.i686-pc-linux-gnu/main.o(.text+0x12eb):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:406:
OBJ.i686-pc-linux-gnu/main.o(.text+0x1308):/data/GRASSCVS/grass51/vector/v.out.ogr/main.c:414:
collect2: ld returned 1 exit status
make[2]: ***
[/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/etc/bin/cmd/v.out.ogr]
Erreur 1
make[2]: Leaving directory `/data/GRASSCVS/grass51/vector/v.out.ogr'
make[1]: *** [subdirs] Erreur 1
make[1]: Leaving directory `/data/GRASSCVS/grass51/vector'
make: *** [default] Erreur 1
