I can help out a little, having just gone through this myself with the help of other list members, especially Glynn Clements.
The 'E_edit' problem is similar to the 'round' problem in that there is a conflict in names between grass and the system libraries. Until we can figure out an option to force the grass libraries to be searched before the system, the solution in this case is to rename edit to (e.g.) gedit; here's the advice that worked for me and others:
It may be that the linker prefers *.dylib to *.a, regardless of
location. In which case, the only solution would be to change the
name. Try changing the corresponding lines in src/CMD/generic/make.mid
EDITLIB = -ledit
to:
DEPEDITLIB = $(LIBDIR)/libgedit.a
EDITLIB = -lgeditThen re-compile (you might need to run "make clean" first).
I think this will fix all your errors with respect to "E_edit". I haven't found a solution to the gdal problem.
cheers,
Scott
On Tuesday, October 8, 2002, at 11:26 PM, Jeshua Lacock wrote:
Greetings,
Here is my full report of my attempt to get the failed modules compiled on Mac OS X 10.2.1 (Jaguar, Darwin 6.0) using gcc 3.1.
The module g.region fails with E_edit_cellhd as an undefined symbol.
The v.reclass, r.weight and r.reclass modules all fail with _E_edit_cats as an undefined symbol.
While building "src/raster/r.support", in addition to missing _E_edit_cats, I get another undefined symbol:
/usr/bin/ld: Undefined symbols:
_E_edit_cats
_E_edit_fp_catsE_edit_cellhd, E_edit_cats and E_edit_fp_cats are all defined in src/include/edit.h. Suspicious?
While attempting to build r.in.gdal I get some strange undefined symbols:
Scott W. Mitchell smitch@geog.utoronto.ca
Department of Geography Phone: (613) 730-5375
University of Toronto at Mississauga UTM fax: (905) 828-5273
3359 Mississauga Road Local fax (613) 822-5143
Mississauga, ON L5L 1C6 Canada
