[GRASS5] GRASS 5.0.0stable to be released soonish
Hi developers,
since all release critical bugs are fixed, we should release
GRASS 5.0.0stable now.
For that we can use the existing pre4 branch. Maybe Glynn could
check if any important change was not submitted to (post-)pre4
branch?
Let's go ahead, we had a long testing phase for pre4 and discovered
only a few (fixed) bugs.
The plan is to do this around the 13th, which is about one
month after we have released pre4.
Thus yes, we should start preparing the 5.0.0 release.
(no need to add "stable" as a prefix.)
branch?
If we have changes, we could make a pre5 from this release branch
and then rerelease this a few weeks later.
Okay, if you think that this is the case
as a release assistant I'm agreeing with you and think that
5.0.0 would be fine somewhere next week.
  Bernhard
Are we sure that all of the PROJ issues are now fixed?
> branch?
However, we have to take care not to run into a never-ending story here.
It will never be bug-free, so one day (very soon) it must be the final
5.0.0 release. Radim needs urgently help for 5.1 (and many of you do not
want to miss the new features already implemented).
:slight_smile:
  Bernhard
So far I have tested many hours (and posted a lot). I kindly invite
others to test the current HEAD. To me it looks functional again.
The r.proj version I got from the CVS has a lot of anonymous changes since
last time I looked (april_11_release). Basically the bordwalk.c calls have
beeen disabled, which nullifies almost all of the changes made in August
2000. The whole input map will now be loaded into memory, region
sensitivity is no longer there etc
Comments at the beginning of main.c are now misleading, most of the
improvements from Aug 2000 are gone ...
Morten Hulden
branch?
OK, I'll look into it. However, 257 files differ between pre4 and the
head, so it may take a while to check everything.
> branch?
Fortunately, many of them correspond to bulk changes.
The following is a brief summary of the differences between pre4 and
the current state of the head. Files or changes which are preceded by
an asterisk have already been committed to the release branch.
For the remaining changes, I would appreciate opinions as to which
should be included in the next release. I'll submit my opinions in a
follow-up.
Also, if any fundamental changes are to be included (e.g. the libgis
I18N), we should consider labelling the next release as "pre5" rather
than "final".
Added directories
locale/ru/tcltkgrass
src/display/d.text.freetype/vflib
Added Files
locale/ru/LC_MESSAGES/libgis.po
  libgis I18N
locale/ru/grass_intro.txt
locale/ru/license.txt
src/general/init/license.txt
  Init.sh I18N
src/libes/proj/PJ_krovak.c
src/libes/proj/PJ_krovakgis.c
  krovak[gis] addition
src/display/d.text.freetype/test.input
  d.text.freetype command mode
Changed Files
AUTHORS
  re-format long lines
NEWS.html
  updated
documents/debugging.txt
  comment re: -W[error-]implicit-function-declaration
  add section 6: Debugging with 'core' file
documents/release_rules.txt
  updated
handheld/babyGRASS_compile.sh
handheld/babyGRASS_packagingsrc.sh
  add g.mapsets
SUBMITTING
  header ordering
Makefile.in
  handling of "locale" subdirectory
configure
configure.in
  readline
  Darwin iconv check
  Darwin PostgreSQL (-lssl -lcrypto)
* documents/cygwin_grass50bininstall.html
  sunrpc library
html/Gmakefile
  [ -> test
  mkdir -> mkdir -p
html/html/d.his.html
  -n flag
* html/html/d.rast.pg.html
* html/html/d.site.pg.html
* html/html/d.what.r.pg.html
* html/html/d.what.s.pg.html
* html/html/d.what.v.pg.html
* html/html/g.column.pg.html
* html/html/g.select.pg.html
* html/html/g.stats.pg.html
* html/html/g.table.pg.html
* html/html/pg.in.dbf.html
  koi8-r -> iso-8859-1
html/html/d.vect.pg.html
* koi8-r -> iso-8859-1
  -e flag
* html/html/v.reclass.pg.html
  fix postgresql.org URL
* html/html/v.to.pg.html
  -p flag
  change xrefs
html/html/d.text.freetype.html
  -rpsc flags
  align=, rotation=
  Command mode
html/html/dcorrelate.sh.html
  mention "scattergram"
html/html/i.rectify.html
  comment regarding write errors
html/html/i.in.erdas.html
  r.in.gdal xref
  authors
* html/html/m.datum.shift.html
html/html/s.in.garmin.sh.html
  change xrefs
html/html/pngdriver.html
  default background is black
html/html/r.his.html
  -n flag
* html/html/r.runoff.html
  G-language -> GRASS raster command
html/html/s.in.ascii.html
  Time as String Attributes
* html/html/s.vol.rst.html
  references
html/html/s.what.html
  Add mailto: link
html/html/v.in.garmin.sh.html
* gps -> GPS
  change xrefs
html/html/v.in.shape.html
  -d flag
html/index.html
* update search URL
  update mailto: link
html/projections.html
  add URLs
html/raster.html
  remove xrefs
* html/searchhtml.html
  update search URL
html/tips_and_tricks.html
  Add comment re: .cshrc
locale/Gmakefile
  process all locales, not $LANG
  add tcltkgrass, textintro targets
locale/ru/LC_MESSAGES/d.vect.pg.po
locale/ru/LC_MESSAGES/v.to.pg.po
mk/Makefile.in
  add "locale" subdirectory to "dirs" target
  generate more complex "gmake5" script
mk/mid.mk
mk/mid.mk.shlib
  add LOCALE definition
mk/mkmakefiles
  optional directory argument
src.contrib/GMSL/SG3d/README
src.contrib/GMSL/sg4d/README
  mention Ygl
src.garden/grass.hdf/hdf5/r.in.hdf/README
  mention HDF-EOS
src.garden/grass.hdf/hdf5/r.in.hdf/r.in.hdf.c
src.garden/grass.postgresql/d.vect.pg/dbvect.h
src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
src.garden/grass.postgresql/d.vect.pg/getSopts.c
src.garden/grass.postgresql/d.vect.pg/main.c
src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
  -e (extract) flag
src.garden/grass.postgresql/v.to.pg/dbvect.h
src.garden/grass.postgresql/v.to.pg/getAllOpts.c
src.garden/grass.postgresql/v.to.pg/getSopts.c
src.garden/grass.postgresql/v.to.pg/main.c
src.garden/grass.postgresql/v.to.pg/plotCat.c
src.garden/grass.postgresql/v.to.pg/runInfxFile.c
  -p (postgis) flag
* src/CMD/generic/GISGEN.sh
src/CMD/generic/make.mid
  define LOCALE (currently unused)
src/CMD/head/head.in
  readline variables
src/display/d.3d/Dmain.c
src/display/d.3d/check_opt.c
src/display/d.3d/command.c
src/display/d.area/main.c
src/display/d.area/screenpoly.c
src/display/d.barscale/cmd/main.c
src/display/d.barscale/cmd/mouse.c
src/display/d.colormode/cmd/main.c
src/display/d.colors/get_info.c
src/display/d.colortable/cmd/main.c
src/display/d.db/main.c
src/display/d.extend/cmd/main.c
src/display/d.font/cmd/main.c
src/display/d.frame/cmd/create.c
src/display/d.frame/cmd/dumper.c
src/display/d.frame/cmd/select.c
src/display/d.geodesic/cmd/main.c
src/display/d.graph/cmd/allocation.c
src/display/d.graph/cmd/main.c
src/display/d.grid/cmd/main.c
src/display/d.histogram/cmd/get_stats.c
src/display/d.icons/cmd/main.c
src/display/d.label/cmd/main.c
src/display/d.leg.thin/main.c
src/display/d.mapgraph/cmd/main.c
src/display/d.menu/cmd/main.c
src/display/d.mon/pgms/release.c
src/display/d.mon/pgms/start.c
src/display/d.mon/pgms/stop.c
src/display/d.mouse/main.c
src/display/d.pan/main.c
src/display/d.points/cmd/main.c
src/display/d.profile/What.c
src/display/d.profile/main.c
src/display/d.rast/cmd/display.c
src/display/d.rast/cmd/main.c
src/display/d.rhumbline/cmd/main.c
src/display/d.sites.qual/cmd/main.c
src/display/d.sites/cmd/main.c
src/display/d.title/cmd/main.c
src/display/d.vect.labels/main.c
src/display/d.vect/cmd/main.c
src/display/d.what.db/main.c
src/display/d.what.vect/cmd/attr.c
src/display/d.what.vect/cmd/main.c
src/display/d.where/cmd/main.c
src/display/d.zoom/cmd/main.c
src/general/g.gisenv/main.c
src/general/g.help/main.c
src/general/g.help/menu.c
src/general/g.manual/cmd/main.c
src/general/g.manual/inter/main.c
src/general/g.mapsets/dsply_path.c
src/general/g.mapsets/main_cmd.c
src/general/g.parser/main.c
src/general/g.region/cmd/main.c
src/general/g.region/cmd/printwindow.c
src/general/g.region/cmd/zoom.c
src/general/g.region/inter/main.c
src/general/g.setproj/main.c
src/general/init/lock.c
src/general/manage/cmd/copy.c
src/general/manage/cmd/rename.c
src/general/manage/lib/read_list.c
src/libes/dbmi/lib/dbmscap.c
* src/raster/r.sun/main.c
  various tidying:
    include necessary headers
    remove unused variables
    error handling changes
    use $GRASS_PAGER instead of $PAGER
    remove $Log$
src/display/d.his/cmd/main.c
src/raster/r.his/cmd/main.c
  -n flag
src/display/d.text.freetype/Gmakefile
src/display/d.text.freetype/freetypecap
src/display/d.text.freetype/main.c
  add align=, rotation= options
  command mode
src/display/devices/PNGdriver/Graph_Set.c
  Fix GRASS_BACKGROUNDCOLOR processing
src/display/devices/PNGdriver/README
src/display/devices/XDRIVER/XDRIVER24/Graph_Set.c
  add "GRASS" to monitor title (tcltkgrass bug workaround)
src/general/init/Gmakefile
  generate $GISBASE/etc/license
  link $GISBASE/etc/lock against libgis
src/general/init/init.sh
* add "savehist" setting to .cshrc
  i18n
  licence notice moved to separate file
* src/imagery/i.points/ask_mag.c
* src/imagery/i.points3/inter/graph_askmag.c
* src/imagery/i.vpoints/ask_mag.c
  add R_flush()
* src/imagery/i.vpoints/cell.c
* src/imagery/i.vpoints/colors.c
src/imagery/i.vpoints/debug.c
* src/imagery/i.vpoints/drawcell.c
* src/imagery/i.vpoints/drawvect.c
* src/imagery/i.vpoints/driver.c
src/imagery/i.vpoints/globals.h
src/imagery/i.vpoints/main.c
src/imagery/i.vpoints/zoom_box.c
  various changes
src/include/config.h.in
  HAVE_READLINE_READLINE_H
src/include/geo.h
src/libes/gis/geo_init.c
src/libes/gis/projections
src/libes/proj/Gmakefile
src/libes/proj/pj_list.h
  krovak[gis] added
src/libes/edit/edit_cellhd.c
  fix rounding of negative values
src/libes/gis/datum.table
src/libes/proj/pj_datums.c
  Hermannskogel added
src/libes/gis/env.c
  check for empty string in set_env()
  I18N
src/libes/gis/reclass.c
  disable reclassed_to warning
  I18N
src/libes/gis/Gmakefile
src/libes/gis/G_dump.c
src/libes/gis/adj_cellhd.c
src/libes/gis/ask.c
src/libes/gis/ask_cell.c
src/libes/gis/auto_mask.c
src/libes/gis/cats.c
src/libes/gis/closecell.c
src/libes/gis/color_read.c
src/libes/gis/datum.c
src/libes/gis/done_msg.c
src/libes/gis/error.c
src/libes/gis/format.c
src/libes/gis/get_cellhd.c
src/libes/gis/get_datum.c
src/libes/gis/get_datum_name.c
src/libes/gis/get_ell_name.c
src/libes/gis/get_ellipse.c
src/libes/gis/get_projinfo.c
src/libes/gis/get_projname.c
src/libes/gis/get_row.c
src/libes/gis/get_window.c
src/libes/gis/gishelp.c
src/libes/gis/gisinit.c
src/libes/gis/histogram.c
src/libes/gis/history.c
src/libes/gis/home.c
src/libes/gis/legal_name.c
src/libes/gis/list.c
src/libes/gis/location.c
src/libes/gis/make_colr.c
src/libes/gis/mapset.c
src/libes/gis/mapset_msc.c
src/libes/gis/mask_info.c
src/libes/gis/myname.c
src/libes/gis/null_val.c
src/libes/gis/opencell.c
src/libes/gis/parser.c
src/libes/gis/proj2.c
src/libes/gis/proj3.c
src/libes/gis/put_cellhd.c
src/libes/gis/put_row.c
src/libes/gis/put_title.c
src/libes/gis/quant_io.c
src/libes/gis/quant_rw.c
src/libes/gis/range.c
src/libes/gis/rd_cellhd.c
src/libes/gis/readsites.c
src/libes/gis/readsites_xyz.c
src/libes/gis/set_window.c
src/libes/gis/system.c
src/libes/gis/timestamp.c
src/libes/gis/view.c
  I18N
* src/libes/proj/datum_shift.c
  check for no datum specified
src/libes/proj/geod.c
  re-order headers to deal with geodesic.h issues
* src/mapdev/v.in.shape/main.c
  -d flag
  error handling
* src/mapdev/v.mkgrid/mkgrid_cmd.c
  fix key_desc field of "box=" option
src/mapdev/v.proj/Gmakefile
* src/mapdev/v.proj/main.c
* src/sites/s.proj/main.c
  datum/ellipse fixes
src/raster/r.in.gdal/main.c
  convert ellipsoid name to lower case (bug #1047)
src/raster/r.mapcalc3/Gmakefile
src/raster/r.mapcalc3/mapcalc.l
  readline support
  fix bug with quoted map names
src/raster/r.mapcalc3/evaluate.c
src/raster/r.mapcalc3/map.c
src/raster/r.mapcalc3/mapcalc.h
  copy cats/colr/hist
src/raster/r.mapcalc3/main.c
  allow expression to be split into multiple arguments
src/raster/r.mapcalc3/xexp.c
  allow two-argument form
src/raster/r.proj/cmd/bordwalk.c
  ignore invalid points
src/raster/r.proj/cmd/main.c
src/raster/r.proj/cmd/r.proj.h
* datum/ellipse fixes
  tidy
  add -n (nocrop) flag
  move "menu" array from r.proj.h to main.c
* src/raster/r.tiff/r.out.tiff.c
  fix allocation bug
* src/scripts/contrib/d.rast.rescale/d.rast.rescale
  add "help" option
  fix r.stats invocation (-z -> -n)
src/scripts/contrib/grassmirrorsmap/grass.sites.mirror
  add Canada, Venezuela
src/scripts/contrib/grassmirrorsmap/grass_sites.gif
src/scripts/contrib/grassmirrorsmap/grass_sites.htmlmap
src/scripts/contrib/grassmirrorsmap/grassmap.html
  updated
src/scripts/contrib/grassmirrorsmap/list_countries.sh
  add g.gisenv call
src/scripts/contrib/grassmirrorsmap/mkgrassmap.sh
  add more colors
src/scripts/contrib/r.univar/r.univar
  /bin/bash -> /bin/sh
  change Markus' email address
src/sites/s.in.mif/Gmakefile
  fix lex invocation
src/tcltkgrass/main/gis_set.tcl
src/tcltkgrass/tcltkgrass
  I18N
* src/tcltkgrass/module/d.his
  -n switch
src/tcltkgrass/module/d.zoom
  more options
Bogus Diffs
src/libes/gis/sites.c
src.contrib/GMSL/NVIZ2.2/src/togl.c
follow-up.
I recommend including these:
Makefile.in
configure
configure.in
  Darwin iconv check
locale/Gmakefile
mk/Makefile.in
src/libes/gis/env.c
  tidy
  fix lex invocation
These are harmless, so may as well be included:
mk/Makefile.in
mk/mid.mk
mk/mid.mk.shlib
mk/mkmakefiles
These are worth considering:
configure
configure.in
  readline
  readline variables
  readline support
  copy cats/colr/hist
> > branch?
We will not include them.
I strongly advise against merging now.
We should run checks for the release branch code and then release it
as 5.0.0 or pre5.
than "final".
No fundamental changes. Only critical bug fixes.
And everybody should have committed them already to the release branch.
> follow-up.
> Makefile.in
yes - important fix.
> configure
> configure.in
> Darwin iconv check
yes, as needed for Darwin MACOSX.
ok
ok
> locale/Gmakefile
ok
> mk/Makefile.in
important fix
no idea above upper two. If you recommend, why not.
ok
> src/libes/gis/env.c
important
ok (for Darwin and friends)
ok
ok
ok
ok
no idea - is the bordwalk issue clarified now? Morten?
> tidy
> fix lex invocation
ok
> mk/Makefile.in
> mk/mid.mk
> mk/mid.mk.shlib
> mk/mkmakefiles
all ok
> configure
> configure.in
> readline
> readline variables
> readline support
should be quite harmless as it is 1 optional
function only (have tested o.k)
> copy cats/colr/hist
please yes.
also yes.
Thanks for the investigation, Glynn!
> > > branch?
Did you really read the mail of Glynn? There are several important
fixes mentioned. GRASS cannot even installed without at least the
Makefile fix etc.
as 5.0.0 or pre5.
> than "final".
.. which didn't happen...
Also a bugfix from David for v.in.shape is in the queue (he wrote to
me personally since he is currently no subscriber).
> > follow-up.
Note: the absence of a change from that list doesn't mean that I'm
advising against including it; it means that I would like input as to
whether or not the change should be included in the next release.
I really need comments on the changes which are on the original list
but not on my "approved" list.
Makefile fix etc.
We should make these of course.
AFAIK mostly Glynn postponed the checkin of his code changes.
Most of the other changes does not seem to be release critical.
It may be too late for 5.0.0 then...
or is it release critical?
We should be as close to 5.0.0pre4 as we can,
because this was tested a lot.
Any change we make might introduce other bugs.
> > branch?
follow-up.
than "final".
Added directories
no recommendation here
Added Files
  libgis I18N
  Init.sh I18N
This is pretty safe. It should appear in PROJ4 soon (hi Frank).
Of course it can also be skipped.
no idea
Changed Files
AUTHORS
yes
NEWS.html
  updated
yes
yes
  updated
yes
  add g.mapsets
yes
SUBMITTING
  header ordering
yes
Makefile.in
yes, very important
configure
configure.in
  readline
  Darwin iconv check
yes
  sunrpc library
yes
html/Gmakefile
  [ -> test
  mkdir -> mkdir -p
yes, needed
  -n flag
yes (it restores the former functionality)
yes
yes
  -e flag
depends
yes
depends
yes
  -p flag
depends
  change xrefs
yes
  -rpsc flags
  align=, rotation=
  Command mode
no idea
yes
yes
  r.in.gdal xref
  authors
yes
  change xrefs
yes
yes
  -n flag
yes, restored former functionality
yes
yes
  references
yes
  Add mailto: link
yes
* gps -> GPS
  change xrefs
yes
  -d flag
yes, restored former functionality accidentally removed by last submission
html/index.html
* update search URL
  update mailto: link
yes
  add URLs
yes
html/raster.html
  remove xrefs
yes
  update search URL
yes
yes
locale/Gmakefile
yes
depends
depends
mk/Makefile.in
yes
mk/mid.mk
mk/mid.mk.shlib
yes/depends ?
mk/mkmakefiles
yes
  mention Ygl
yes
  mention HDF-EOS
yes
yes (it's not compiled by default).
The program now supports ASTER, MODIS (not yet 2Q) without
geocoding. More work needed.
  -e (extract) flag
no idea
  -p (postgis) flag
no idea
depends
depends
  readline variables
yes, don't see a problem (tested)
  various tidying:
    remove $Log$
yes
  -n flag
yes, restored original functionality, otherwise NULL problems
  command mode
no idea: new feature
seems to be needed?
yes if above
seems to be needed?
yes
yes (trivial fix)
  i18n
no idea
mhh, if it helps
  add R_flush()
yes, needed
  various changes
not changes but bugfixes. Now usable, before broken
src/include/geo.h
  krovak[gis] added
harmless, see above
yes
  Hermannskogel added
yes if krovak added
src/libes/gis/env.c
yes
  I18N
no idea
yes
  I18N
no idea
src/libes/gis/ask.c
  I18N
no idea
yes
yes (Darwin)
  -d flag
  error handling
yes, restores former flag accidentally deleted
yes (was typo)
  datum/ellipse fixes
I suggest that then also m.proj[2] must be updated to
avoid inconsistencies
yes
  readline support
yes
  copy cats/colr/hist
yes (harmless, restores functionality of old r.mapcalc with fix)
yes
yes
no idea (Morten?)
  tidy
maybe yes?
  fix allocation bug
yes
  add "help" option
yes
yes
  updated
yes
  add g.gisenv call
yes
  add more colors
yes
yes
  fix lex invocation
yes
  I18N
no idea
  -n switch
yes
  more options
yes (otherwise not consistent)
Bogus Diffs
What means Bogus here?
Thanks for this comparison, Glynn!
So far my comments.
> Makefile fix etc.
... see my other mail...
I don't know, he wasn't very detailed.
That's why we have to fix more than above Makefile.in. Otherwise
several modules either won't work or behave different from pre3
(flags etc). See the other mail.
That's a point especially for I18N and the PG modules.
> > follow-up.
Ignoring invalid points is a separate issue from the bordwalk() topic. It
can happen in any PROJ routine. For raster projections I think it's OK to
ignore invalid points in bordwalk(), and set cells to NULL if we hit them
in the main() (even if this may result in NULL holes in the map, but it's
better than aborting r.proj completely).
> > tidy
My view is:
  -the new flag -n (nocrop) should inhibit both of the two calls to
bordwalk() from main. without -n, both calls to boardwalk() should be
enabled.
  -r.proj should honour current region settings, not
unconditionally project into default region.
Morten Hulden
libgis/Init.sh I18N:
I suggest no for final, but maybe if we decide to do a pre5. The problem
is that, however trivial the changes might appear, if something does go
wrong, the whole of GRASS may be completely unusable.
I can't see any way in which this can break anything.
> html/Gmakefile
> [ -> test
> mkdir -> mkdir -p
yes, needed
The autoconf docs specifically warn against using "mkdir -p", as it
isn't supported on all platforms. However, GRASS already relies upon
it in a number of places.
depends
On what? The actual change is:
-This program requires the <a href="www.postgresql.org">PostgreSQL</a> database
+This program requires the <a href="http://www.postgresql.org">PostgreSQL</a> database
Although, it should really be:
  http://www.postgresql.org/
URLs which refer to directories (i.e. an implicit "index.html") should
always have a trailing slash. Otherwise, the HTTP server has to reply
with a redirect (301/302) response rather than the actual file. This
is so that relative URLs work correctly.
However, I suspect that the browser will fix this automatically in the
case of a "top level" URL such as the above.
> -rpsc flags
> align=, rotation=
> Command mode
no idea
> command mode
These are enhancements rather than bug fixes. However, d.text.freetype
is relatively new, so backward compatibility isn't really an issue yet.
> mk/mid.mk
> mk/mid.mk.shlib
yes/depends ?
These aren't used by anything presently, so it doesn't really matter
either way.
depends
This is a definite yes. This was the primary cause of the "make install"
problem in pre5.
[long list of files snipped]
> various tidying:
> remove $Log$
yes
Then the next version should be labelled "pre5".
seems to be needed?
Yes.
yes if above
Yes regardless; the default background *is* black, but the documentation
said it was white. This just fixes the documentation to match the actual
behaviour.
seems to be needed?
The tcltkgrass "stop all X monitors" option relies upon the XDRIVER
window title containing the string "GRASS". The tcltkgrass code is an
ugly hack, which should ultimately be fixed; but this should suffice for
now.
yes
The first of these is part of the Init.sh I18N.
The second of these relates to the error handling changes. etc/lock now
uses G_fatal_error(), so it has to be linked against libgis.
However, I have no idea how this interacts with the fact that etc/lock
is run during GRASS initialisation. etc/lock doesn't call G_gisinit()
(which may not even work at that point); I don't know whether that
presents a problem for the use of G_fatal_error().
yes (trivial fix)
> i18n
no idea
mhh, if it helps
Part of Init.sh I18N. The idea is that the licence and introductory
message are read from separate (localised) files.
> datum/ellipse fixes
OK; I'll look into it.
no idea (Morten?)
This part is definitely recommended.
> tidy
maybe yes?
I'm fairly sure about the "-n" switch, but we should probably re-enable
the other call to bordwalk(), also on that switch. But:
1. This needs to be tested, preferably with a wide variety of
projections
2. We need to consider whether cropping should be on or off by default;
enabling cropping saves memory, but could result in the output being
incomplete.
3. At some point, we should consider how to handle latitudinal wrapping.
> I18N
no idea
This could still do with some more work (e.g. checking LC_MESSAGES,
LC_ALL). Not as critical as libgis or Init.sh, but still fairly
important to get right.
> Bogus Diffs
It means that these files only differ due to the comments inserted by
$Log$, so they aren't really different.
Summary: even if we omit any changes which are enhancements rather than
bug fixes, there are still enough changes that we should seriously
consider releasing a pre5 version for testing.
I've merged most of the recent changes into the release branch. A
summary of the outstanding differences follows.
The outstanding differences fall into two categories:
1. Substantial changes to individual modules; for these, I'd just like
confirmation that the result is stable enough for inclusion in the
pre5 release.
2. I18N-related changes to key components (GRASS startup, libgis,
tcltkgrass). For these, I would really like confirmation that building
without NLS (i.e. no "--with-nls" option) has been tested by as many
people as possible.
If any portability issues (e.g. assumptions regarding bash, GNU make,
Tcl/Tk version, head.<arch> settings etc) have slipped in, the result
could be completely unusable for some users.
I'm not concerned about it breaking if --with-nls is used; this *will*
fail on systems where dgettext() etc are in libintl rather than in
libc (e.g. Cygwin).
[Lines beginning with "+" indicate added files or directories; the
rest are changed files.]
tcltkgrass I18N (alex)
+ locale/ru/tcltkgrass/
  locale/Gmakefile
libgis I18N (alex)
+ locale/ru/LC_MESSAGES/libgis.po
  src/libes/gis/*.c
Startup I18N (alex)
+ locale/ru/grass_intro.txt
+ locale/ru/license.txt
+ src/general/init/license.txt
  locale/Gmakefile
d.text.freetype update (cho): alignment, rotation, command mode
+ src/display/d.text.freetype/vflib/
+ src/display/d.text.freetype/test.input
d.vect.pg update (alex): -e flag [*]
v.to.pg update (alex): -p flag (PostGIS)
v.in.shape update (david)
  src/tcltkgrass/module/v.in.shape
  src/mapdev/v.in.shape/basename.c
  src/mapdev/v.in.shape/lines.c
  src/mapdev/v.in.shape/polygon.c
  src/mapdev/v.in.shape/vmap_import.c
[*] html/html/d.vect.pg.html has already been updated on the release
branch, but the actual code changes haven't been committed yet.
Okay. So be it.
I would have preferred to just release it as 5.0.0 with
the critical bug fixes only.
Important now is to get 5.0.0pre5 out of the door
as we are within the schedule.
pre5 release.
If you did not have this information, it is most likely that this
were not important bug fixes. Thus default should be to leave it out.
people as possible.
In my view: Not an important bug fix, leave it out.
Again this is just my opinion.
I hope that Markus will manage to bring a pre5 out soon.
