[GRASS5] GRASS 5.0.2 released
Moritz Lennert wrote:
Markus Neteler said:
>> > On Fri, Apr 11, 2003 at 11:25:33AM +0200, Markus Neteler wrote:
Moritz, when you are at it, can you also check the r.mapcalc to make
sure that it has all fixes (e.g. it writes the expression to the history
file?) and run nviz just to view some surface, to make sure that nothing
fundamental is broken there?
thank you,
Helena
It installs without a glitch and rapid testing (d.*, r.thin, r.line, d.dm,
nviz, g.select.pg, d.legend, d.what.vect (although I don't see any
"flashing"...)) does not show any problems.
Only found bugs:
- when I launch v.to.db without any arguments, I get:
PROGRAMMER ERROR: first item in gisprompt is <vector>
        Must be either new, old, mapset, or any
- the announced v.in.dgn module does no seem to be available
Moritz
Moritz
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Testing results for GRASS 5.0.2 on SuSe
1) SuSe 8.0:
GRASS 5.0.2 on SuSe 8.0 works fine.
- r.mapcalc writes the expression to the history file
- for NVIZ I needed 2 links to make it work
  ln -s /usr/lib/libtk8.3.so /usr/lib/libtk.so.0
  ln -s /usr/lib/libtcl8.3.so /usr/lib/libtcl.so.0
- PNG Treiber is OK
- Postgres works
- all other modules I was testing do not make any problems
2) SuSe 8.1:
Same as 8.0 but NVIZ does not work at all. I guess it is again
the tcl/tk8.4 problem, since you compiled with 8.3 ...
- everything else seems to be fine.
bye
  Otto
I'd already tested nviz, and everything seems to work fine for basic
operation.
r.mapcalc writes into the history file (as Otto already mentioned).
However, I can't use arrow keys in the interactive session. Is this normal
? (I don't know r.mapcalc that well).
Moritz
thank you,
Helena
d.dm,
Only found bugs:
Moritz
Moritz
grass5 mailing list
grass5@grass.itc.it
operation.
I would say that is a feature as it does not work in the old version of
r.mapcalc (pre3).
I don't think there is need to do anything about it as most people
use r.mapcalc on command line anyway,
thank you for testing
Helena
Moritz
> thank you,
> Helena
>> d.dm,
>> Only found bugs:
>> Moritz
>> Moritz
>> _______________________________________________
>> grass5 mailing list
>> grass5@grass.itc.it
AFAIK this only works if GRASS was compiled with readline support
(which I didn't specify, should I?).
operation.
It's normal; you have to use --with-readline to get history support,
but --with-readline has problems of its own. Readline support was
added in 5.0.0, but isn't enabled by default.
No; that would result in an r.mapcalc binary that only works if you
have the correct version of libreadline.
The Baylor University website still shows 5.0.1 as the current version on
the main page and in the source link. In fact the last news update was in
January announcing 5.0.1.
This is a long term problem, we are aware of it and in regular contact
with Bruce trying to get it automated.
Bernhard, did you make any progress with Bruce on his rsync problem?
thanks,
Helena
grass5 mailing list
grass5@grass.itc.it
Related to the recent 5.0.2 release we need volunteers
to provide binaries for
- SGI/Irix
- winGRASS
      - X11 display driver
      - generic display driver
- Mac OSX
Some RPMs (Linux/x86 and PPC) are probably generated for
the next FreeGIS release?
No.
He still wanted to get back to me.
- SGI/Irix
- winGRASS
- Mac OSX
The next FreeGIS-CD (v1.2.3) is in the test period
and will contain GRASS 5.0.1 to make sure we release stable packages
with basic testing.
We don't produce PPC rpms anymore, the last FreeGIS-CD for PPC was 1.0.4.
This is because of the low demand for it.
If you thing we are doing an important job and you're using the packages.
We appreciate tipping: http://freegis.org/about-paying.en.html :slight_smile:
  Bernhard
> - SGI/Irix
> - winGRASS
> - Mac OSX
with basic testing.
well, this were a pity as 5.0.1 only contains 2 changes. So you better
include 5.0.0 ... :frowning: But why distributing partially oldish code?
I thought the idea of the release branch is to release stable GRASS.
Now FreeGIS doesn't follow the own ideas of it's maintainers (I remember
that you are strongly recommending branches...)?
Ok
> with basic testing.
Of course we are following it.
And the quality of GRASS releases seems to have improved.
To sell a CD like the FreeGIS-CD you need to test it
on different platforms. If at all times improvements are accepted,
testing would start again and you can almost never release.
This why all serious Free Software distributions most of the time
contain older versions. It is a tradeoff decision to make.
Anyway I'm not deeply in the CD releasing process here,
we'll see how far we are and if GRASS 5.0.2 poses problems.
In any case there is going to be a next revision and hopefully
a fast update.
Demand for the CD is not that high that we could affort
more manpower on it.
  Bernhard
> > - SGI/Irix
> > - winGRASS
> > - Mac OSX
> with basic testing.
I have already written to Bernhard a suggestion to distribute 5.0.2
as 5.0.0 and 5.0.1 has some serious deficiencies and 5.0.2 is simply
much better.
Often a small modification in the code can make a big difference for
everyday work
and that is the case for 5.0.2 (compared to 5.0.0 or 5.0.1)
So I would just like to ask whoever can test 5.0.2 please do it so that
we can make 5.0.2 the version of GRASS recommended for wide distribution
as a stable and reliable code.
Helena
Ok
grass5 mailing list
grass5@grass.itc.it
> > with basic testing.
You are always invited to report problems! Using the feedback
of the development team will hopefully enable you to distribute
5.0.2 instead of 5.0.1.
a fast update.
That's why we want to help the FreeGIS project :slight_smile:
with basic testing.
Is there a standard test suite for new releases that users can run after
building on a new platform? That might shorten the testing period.
> with basic testing.
A bit is described in
documents/pretesting_grass.txt
FreeGIS.org
and something more in
documents/release_rules.txt
FreeGIS.org
However, these document should be clarified, shortened etc.
> > > with basic testing.
The problems are more with the way we try to build packages
that run on many GNU/Linux distributions.
Hi Markus.
- winGRASS
I'll do the generic one after the Easter weekend.
Sorry for the delay,
Mike Thomas
