[GRASS5] GRASS 5.0.3 release candidate 4 (RC4) available
... is available for testing:
http://mpa.itc.it/markus/grass50/
TODO: - update NEWS.html for the release
      - else?
      - else?
* The automatically created Changelog is missing the removal
  of the apngs code (because this was no commit).
  I suggest adding a hint manually.
* Unfortunately src.nonGPL got partly packaged,
  this needs to be removed from the tarball.
* I'm unsure if we should package all code that actually is not used
  in the tarball. We still have it in the CVS.
  Like src.garden/grass.java, unused, src.todo and some other stuff
  from src.garden and src.contrib.
  I suggest to not package them.
* It would be good style to create a detached signature for the
  tarball in addition to the useful md5sums.
  I suggest using Gnupg and a key of Markus as packager for the
  time being.
> - else?
OK, we can do that but it will disappear in the next Changelog.
Better to use a commit entry.
Strange:
cat src.nonGPL/CVS/Tag
Treleasebranch_26_april_2002_5_0_0
Why is that tagged? Did you tag it (please remove then)?
I have just updated the tree.
It it should be removed from the release branch.
  time being.
I have no idea how to do that - hints are welcome.
Strange:
src.nonGPL wasn't removed until after the release branch was created
(AFAICT, it was removed the following day).
Did you use "cvs update -dP"? Empty directories will only be removed
if you use the "-P" switch. Similarly, directories which exist in the
repository but not in your local copy will only be added if you use
the "-d" switch.
If you checked out a copy of the release branch on the day it was
created, then updated it without "-P" (or if you made a copy of the
head then updated it to the release branch without "-P"), the
src.nonGPL directory (and its subdirectories) will still exist (with
the appropriate tag), they just won't contain any files.
Personally, I have "update -dP" in my ~/.cvsrc file, so "cvs update"
will always add and remove directories as necessary.
> Strange:
the "-d" switch.
It also comes when using "cvs up -dP".
The problem is that r.agnps50 was already tagged, now the tags are
moved as well.
Does this apply for files moved in CVS server?
Should it be just removed from the branch?
Good idea!
> > - else?
I'd say in general that it is _not_ a good idea to
let the cvs2changelog script overwrite old entries.
The better changelogs I know are at least controlled manually.
Strange:
Yes I haven't thought of that the tag got moved, too.
Also I believed that your packaging script might be actively
selecting the needed source, not just packaging everything. :slight_smile:
Anyway I've removed the subdirectories of src.nonGPL from the branch now.
Do you want to do this (for exercise)?
It is easy enough:
  If you have a fully checked out branch, just
  use something like
    cd unused
    cvs remove -f
    cvs commit
> time being.
www.gnupg.org has good documentation for gnupg.
Steps (briefly):
  Install an uptodate version of gpg.
  Create a key if you don't have one:
  http://www.gnupg.org/(de)/howtos/de/GPGMiniHowto-3.html#ss3.1
    gpg --gen-key
      (1024 bit is sufficient.)
  Sign a file with a detached signature
    gpg --detach-sign grass-5.0.3rc4_src.tar.gz
  ( Later and repeately:
          Get the public key part signed by people to build
    the web of trust. :slight_smile: )
> > > - else?
So you are welcome to do this job :slight_smile: I won't do that.
Since 1/2000 the Changlog is created like this, so we
may live with it further on. Note that there is also
NEWS.html which is maintained manually (developers may add
missing entries directly!).
> Strange:
I am extracting from CVS, adding Changelog (via cvs2cl.pl),
making a tar ball, that's it more or less. There is no magic inside.
If things like src.nonGPL/ are inside, it's a problem of the
release_branch and not an error in packaging.
I think that we want have everything reproducable. So we have to
maintain a *clean* release_branch.
OK, now it's gone.
It is easy enough:
  use something like
    cd unused
    cvs remove -f
    cvs commit
That's fun :slight_smile:
OK, removed
src.todo/
src.garden/grass.hdf/
src.garden/grass.java/
> > time being.
Steps (briefly):
    gpg --gen-key
I'll see if I get this working (too many things at the same time).
> > > > - else?
True, NEWS.html will be sufficient for the time being I guess.
Yes, it was my missconception of how it would work.
Anyway we are constantly improving, I would say. :wink:
> It is easy enough:
> use something like
> cd unused
> cvs remove -f
> cvs commit
OK, removed
src.todo/
What about "unused"?
and informix and oracle2?
> > It is easy enough:
> > use something like
> > cd unused
> > cvs remove -f
> > cvs commit
> OK, removed
> src.todo/
Where is that?
Removed.
I think it's ok now, we don't have to search for a few bytes
to save. Let's finish this endless story (we started in August)
and work on 5.3/5.7. Most users will await a 5.3.0 release to
get datum transformation support and the NVIZ updates...
Where is that?
tar -tvmlzf /download/src/grass-5.0.3rc4_src.tar.gz | grep /unused | tail -1
-rw-r--r-- neteler/ssi 31158 2000-11-11 01:03:44 grass-5.0.3rc4/unused/tcltkgrass/src/view.c
to save.
Yes, I was just wondering.
Yes!
Though we might provide _some_ support for 5.0.x as long
as 5.4.x is not out. Only _grave_ _critical_ bugs of course. :slight_smile:
Let's go towards 5.4 where 5.3.0 is the next step.
> Where is that?
> to save.
Sorry, found unused/ (was looking at the dir with ls -lart).
Deleted now.
Yes!
Right.
Tomorrow I'll package RC5.
Cool!
I'd argue for keeping it in, otherwise new/experimental/inspiration code
never gets tried by anyone but the very adventurous. Having it CVS-only
puts the barrier too high for beginners at GRASS coding. It will only
exist for those compiling from source, the sort of person who'd probably
end up using 'gmake5' for little things anyway. The binaries won't
change size. Let the 5.7 cvs sort out the old & unused code from the
still experimental; pretty much everything in the 5.0.x branch applies
to 5.0.x, no? Is there lots of unported 4.3 left?
Certaintly leave everything in the 5.3 snapshots.
2c,
Hamish
Would that mean grave & critical[*] bugs in *specific modules* or
in the *overall system* (libraries & init.sh/gisenv stuff)?
[*] I take those to mean:
+ non-functional (SegFaults while not doing something weird)
+ data corruption of existing map
+ significantly erroneous data output
+ license issue
+ anything else?
Hamish
r.terraflow should either be updated to the latest or left out.
yes:
src/display/d.text.freetype/main.c
minor:
src/sites/s.random/main.c
html/html/s.random.html
src/tcltkgrass/module/r.what
src/tcltkgrass/module/d.what.rast
src/tcltkgrass/module/v.what
src/tcltkgrass/module/d.what.vect
src/display/d.text.freetype/test.input
html/html/d.text.freetype.html
src/display/d.label/cmd/label.c
src/display/d.title/cmd/main.c
html/html/d.title.html
src/display/d.geodesic/cmd/main.c
INSTALL
thanks,
Hamish
The situation with most of the mentioned code above is
that most of it has problems that will significantly confuse beginners.
They might not be updated or even have subtle licensing issues.
If we want source code for GRASS developers or beginners to play with,
we should make "experimental" add-on distributions instead I think.
OK, r.terraflow is removed from the release_branch as discussed
earlier. It comes with 5.3-cvs onwards (have added it also to 5.7).
yes:
minor:
INSTALL
Please make updates if desired. I'll wait with RC5 then.
yes:
minor:
What does "yes" and "minor" mean here?
> [important fix]:
> [minor fix]:
> INSTALL
done.
Hamish
