GRASS 5.0.3 release candidate 5 (RC5) is available for testing:
http://mpa.itc.it/markus/grass50/
Good.
It is nice to see that in got smaler in this RC cycle.
I'm wondering if we should also announce this to the user list
and other lists.
More testing means we could find showstopper bugs more easily.
Also with more annoucements like this coming,
what about a GRASS announce list?
> http://mpa.itc.it/markus/grass50/Good.
and other lists.
More testing means we could find showstopper bugs more easily.Also with more annoucements like this coming,
Date: Tue, 21 Oct 2003 11:16:51 +0200
http://article.gmane.org/gmane.comp.gis.grass.user/2921/match=rc5
So far we had once response ("ok").
After that the r.bilinear bugfix went in (tested, ok.).
I suggest to release now.
> Good.
> and other lists.
What about Hamish's tcltk comment?
Debian/testing:
Compiles, starts
NVIZ works as long as you compile with TclTk 8.3 includes
d.text.freetype works
Redhat 7.3:
Compiles, starts
NVIZ works
Redhat 9:
Compiles, starts
NIVZ works
Is there a list of important things we should test?
(I know.. see ChangeLog/NEWS)
NEWS.html, insert date:
[GRASS 5.0.3 released XX October 2003]
regards,
Hamish
> Good.
> and other lists.
http://article.gmane.org/gmane.comp.gis.grass.user/2921/match=rc5So far we had once response ("ok").
I've just noticed a bug which appears to have been introduced when the
bulk of the grass5 script was moved to etc/Init.sh (and hence is
present in 5.0.2). src/general/init/Gmakefile has this:
$(SHELL) -c "sed -e \"s#GISBASE_VALUE#$(GISBASE)#\" -e \"s#PERL_COMMAND#$(PERL)#\" grass.src > $(GRASS_BIN)/$(START_UP) 2>/dev/null ; true"
However, the line which this is fixing:
GRASS_PERL=PERL_COMMAND
has moved from grass.src to init.sh.
BTW, the GRASS_WISH bug still hasn't been fixed. I'll commit a fix for
that to the HEAD, but it definitely needs testing before inclusion in
the release branch.
> I suggest to release now.I've just noticed a bug which appears to have been introduced when the
present in 5.0.2). src/general/init/Gmakefile has this:$(SHELL) -c "sed -e \"s#GISBASE_VALUE#$(GISBASE)#\" -e \"s#PERL_COMMAND#$(PERL)#\" grass.src > $(GRASS_BIN)/$(START_UP) 2>/dev/null ; true"
the release branch.
I really tend to release today, since there is no bugfix activity any more.
In favour of our users, we should not postpone releases forever, but be a
bit more reliable (not to offend anyone here, just a general statement).
The 5.0.3 release I have started in August:
2003-08-20 10:10 markus
Now we have November and it is still not published.
IMHO we should revise our release strategy.
