Hi developers,
here a report of Gordon on snprintf problems...
Actually I have no suggestion how to fix this.
On Fri, Mar 02, 2001 at 07:04:12AM -0700, gordon.haverland@gov.ab.ca wrote:
Hello Markus,
Conditions here required me to download GRASS 5 again, and so I set up a
CVS
tree this time. So, the source is current as of Wednesday I believe.
Anyway, this
is running on a UltraSPARC-2, Solaris 2.5.1 and gcc 2.95.2.In compiling src/display/d.db, some function in main.o assumes snprintf is
available. On this old a version of Solaris, it isn't. I must have 2 or 3
versions of snprintf from things like Samba and LPRng around here, so I'll
just use one of those. This error continues in a bunch of other modules
(src/display/d.profile is next).In src/raster/r.in.png, a call for png.h generates an error. I don't
believe I have PNG installed on this machine (yet). Did configure miss
this?
Gordon, the current makefile system doesn't allow to ignore modules
when libs are missing. However, those will be ignored and won't break
the compilation (any more) as you will have seen. We fix this in 5.1.
Have a great day.
Gord
Regards
subject 'unsubscribe grass5'
