[GRASS5] GRASS 5.1 conflicting types for `G_ask_datum_name'
thank you Paul - you were right. After updating GRASS 5.0 from CVS the
this 'datum part' of the GRASS 5.1 snapshot compiled properly.
but now occurs another compilation error with v.net.salesman
in GRASS 5.1.
make[2]: Wechsel in das Verzeichnis
»/daten/software/grass51/vector/v.net.salesman«
gcc -g -Wall -Wall -I/daten/software/grass51/include
-I/daten/software/grass51/dist.i686-pc-linux-gnu/include
-I/usr/include/pgsql -I/usr/include/pgsql/server/
-I/daten/software/grass51/dist.i686-pc-linux-gnu/include \
        -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c:23:19: proto.h: Datei oder Verzeichnis nicht gefunden
/daten/software/grass51/include/gis.h:36: warning: `GRASS_copyright'
defined but not used
make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Fehler 1
make[2]: Verlassen des Verzeichnisses
make[1]: *** [subdirs] Fehler 1
make[1]: Verlassen des Verzeichnisses »/daten/software/grass51/vector«
make: *** [default] Fehler 1
maybe another hint ?
Installation now:
GRASS 5.0 and 5.1 from CVS 1 Apr 2003 on Linux
thanks
Otto
Try to remove #include "proto.h" from main.c, the same for Steiner.
Radim
On Tuesday 01 April 2003 10:37 am, Otto Dassau wrote:
in GRASS 5.1.
Installation now:
thanks
Otto
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
OK, thank you
  Otto
