Question for Radim and me is if the need both HAVE_POSTGRES and
HAVE_POSTGRES_H or not? If not, as configure[.in] now suggests
we had to update all the spreaded HAVE_POSTGRES in 5.1 code to
HAVE_POSTGRES_H. No problem of course, but we are not sure what's
correct.
(so at time the POSTGRES cannot be properly enabled)
correct.
I suspect that both are necessary.
HAVE_POSTGRES_H indicates that the header file <postgres.h> was found;
older versions of PostgreSQL have <postgres_fe.h> instead (although
config.h.in doesn't include an entry for HAVE_POSTGRES_FE_H).
Note that GRASS probably shouldn't be using either of these headers;
they concern server internals and, AFAICT, are only meant for use by
extensions to the server. Clients should normally only need
<libpq-fe.h>. In 5.0.0, those headers are only used by g.column.pg to
obtain the value of VARHDRSZ (and that dependendency has been removed
from the CVS head).
Presumably HAVE_POSTGRES was meant to reflect whether PostgreSQL
support was enabled (i.e. --with-postgres, which is the default). In
which case, I appear to have overlooked it when I updated
configure[.in].
> correct.
from the CVS head).
A quick search shows that 5.1 only uses the libpq-fe.h.
find . -type f -name "*.[ch]" -exec grep -l postgres {} \;
./include/config.h
--> not relevant
configure[.in].
