Currently I try to compile GRASS 5.1 on Mac OSX.
Thanks to the recent update of 'aclocal.m4' by Paul the
'configure' runs well now, using following parameters:
http://grass.itc.it/grass51/source/conf_scripts/macosx/
-> conf51_macOSX.sh
All libraries compile as well, but there is a problem
compiling modules (as well as some 'test' programs within
the libraries and the 'form' program). The compiler line
for linking modules seems to be wrong:
Example:
[timonchiotwin:~/grass51exp/raster/r.average] markus% make
gcc -I/Users/markus/grass51exp/include -I/Users/markus/grass51exp/dist.powerpc-apple-darwin6.6/include -I/usr/X11R6/include -I/sw/include -g -O2 -Wall -Wconversion -Wno-implicit-int -I/usr/X11R6/include -I/sw/include -I/Users/markus/grass51exp/include -I/Users/markus/grass51exp/dist.powerpc-apple-darwin6.6/include \
-o OBJ.powerpc-apple-darwin6.6/main.o -c main.c
main.c: In function `main':
main.c:78: warning: suggest parentheses around assignment used as truth value
main.c:92: warning: suggest parentheses around assignment used as truth value
main.c:108: warning: passing arg 2 of `out' as floating rather than integer due to prototype
main.c:108: warning: passing arg 3 of `out' as floating rather than integer due to prototype
/usr/include/stdio.h: At top level:
/Users/markus/grass51exp/include/gis.h:36: warning: `GRASS_copyright' defined but not used
gcc -L/sw/lib -L/Users/markus/grass51exp/dist.powerpc-apple-darwin6.6/lib -o /Users/markus/grass51exp/dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.average OBJ.powerpc-apple-darwin6.6/main.o -lgrass_gis -lgrass_datetime -lintl -lz
ld: /Users/markus/grass51exp/dist.powerpc-apple-darwin6.6/lib/libgrass_gis.dylib is input for the dynamic link editor, is not relocatable by the static link editor again
ld: /Users/markus/grass51exp/dist.powerpc-apple-darwin6.6/lib/libgrass_datetime.dylib is input for the dynamic link editor, is not relocatable by the static link editor again
make: *** [/Users/markus/grass51exp/dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.average] Error 1
Knowing almost nothing about Mac OSX I would like to ask here for help.
Some 'gcc' flags seem to be missing.
Thanks
