Hi, upon 'make mix' for GRASS 5.1 I get the following errors, all seem to
be due to missing recursed subdirectories in the 5.1 tree.
Hamish
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/bmf.b' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/bmf.b': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/bmf_to_cll.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/bmf_to_cll.c': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/do_dots.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/do_dots.c': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/do_line.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/do_line.c': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/find_area.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/find_area.c': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/ply_t_bmif.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/ply_t_bmif.c': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/ply_to_cll.h' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/ply_to_cll.h': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/save_area.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/save_area.c': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/wrte_recrd.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/wrte_recrd.c': No such file or directory
ln: creating symbolic link `.//raster/r.le/r.le.setup/polytocell/yadjust.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/r.le/r.le.setup/polytocell/yadjust.c': No such file or directory
ln: creating symbolic link `.//raster/wildfire/r.spread/prob_invsqr/prob_invsqr.c' to `/usr/src/grass_src/grass50_CVS_HEAD/src/raster/wildfire/src/r.spread/prob_invsqr/prob_invsqr.c': No such file or directory
Hamish,
the subdirectory is present in CVS. I guess you forgot to use '-dP':
cd raster/r.le/r.le.setup
cvs up -dP
cd ../../../
make mix
Hamish
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hamish,
cvs up -dP
cd ../../../
make mix
Ah, now I got it. The -P is the *problem* in this case
as it deletes empty directories (it's empty initially
so I'll add a small README there).
Try
cvs up -d
cd ../../../
make mix
Then it should work. In some minutes also with -dP when the file
is arrived in CVS.
