[GRASS5] grass 5.3 CVS - r.in.gdal compilation error
Dear list,
I installed gdal from CVS today, it compiled without problems, but in
GRASS 5.3 CVS from today, r.in.gdal compiles this error message:
gcc -L/daten/software/grass53/src/libes/LIB.i686-pc-linux-gnu
-Wl,--export-dynamic -o
/daten/software/grass53/dist.i686-pc-linux-gnu/etc/bin/cmd/r.in.gdal
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/gbgetsymbol.o
OBJ.i686-pc-linux-gnu/gdalbridge.o \
        /daten/software/gdal/libgdal.la -lgproj -lproj -lgis -lI
-lgmath -lm -lz
/daten/software/gdal/libgdal.la: file not recognized: File format not
recognized
collect2: ld returned 1 exit status
make: ***
[/daten/software/grass53/dist.i686-pc-linux-gnu/etc/bin/cmd/r.in.gdal]
Fehler 1
what can I do to make r.in.gdal compile?
  thank you
    Otto
On Thu, 04 Mar 2004 11:25:01 +0100
  I would say the problem is with gdal, not grass.
  Maybe if you re-compile gdal... (and erase libgdal.la)
  (I had the same problem one time with libz.so,
  and recompiling solved it)
One tree to rule them all,
One tree to find them,
One tree to bring them all,
and to itself bind them.
  -- Gavin Koch <gavin@cygnus.com>
On Thu, 4 Mar 2004, Otto Dassau wrote:
Dear list,
-lgmath -lm -lz
recognized
make: ***
Fehler 1
Maybe install it rather than linking to it from the compile directory (if
that's what you're doing). Or compile it without using libtool
(--without-libtool).
This isn't really a GRASS question.
