I read all of the newest discussion with interest. First, thanks Markus for making an updated 5.7 available in binary form. I am showing this around and people here in Valencia are very interested.
Second, several people (including Scott, with whom I've corresponded a bit directly) seemed interested in the Mac OSX binaries I compiled for 5.3.
In response to Jens, putting something onto fink is somewhat more involved than simply sending something in. It is not exactly like contributing to a CVS, but is managed to a considerable degree (..and this is a good thing). Also, to put something onto fink, you need to make a fink.info shell script that will set up ./configure, download the source, and compile it. I can read through these and more or less make sense of them, but don't think I could create one that works right without a lot more effort than I have time to contribute right now. There is already a fink maintainer for GRASS who has been pretty helpful in keeping the current stable version available there.
On the other hand, I could simply create a tarball of the user/local/grass5 directory and /user/local/bin grass files (grass5, gmake5 and gmakelink5 I think), gzip them and send them to someone if they want them. Are there any other files I need to include?
Before doing this, I have a question and a suggestion for 5.3 and all versions.
Suggestion: Right now, 5.0.x and 5.3 both create grass5 directories and install themselves into /usr/local/bin as grass5. I much prefer the way Markus has set up 5.7. It installs in /usr/local/grass57 AND in /usr/local/bin as grass57. This way, someone can install a new version without overwriting an older one. Currently, can only avoid this by changing both the /bin/ and /prefix/ directories in ./config. You can also easily choose which version you want to run at a particular time without trying to remember a special path.
Question: After the fact can I change the name of /usr/local/bin/grass5 to /usr/local/bin/grass53? Same for gmake5 and gmakelink5 files, and /usr/local/grass5 directory? Or will this completely confuse GRASS? This way, a tarball I create wouldn't overwrite someone's existing grass 5.0.x files when untarred.
In any case, I think GRASS is a great product and am happy to help with it in the ways I can.
Michael Barton
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
