[GRASS5] GRASS 5.7.0 beta1
I have created beta1 source package for 5.7.0 :
http://mpa.itc.it/radim/grass-5.7.0beta1.tar.gz (6.5 MB)
It is full source code (make copymix; make srcdist)
with files copied from 5.3.0. This version is not tagged in CVS.
The purpose of this version is to check if configure, make,
make bindist and *-install.sh works on various platforms.
I would appreciate if volunteers could try to
./configure (without --with-grass50 but with --with-postgres if possible)
make
make bindist
install binary package
start grass57 installed from the binary package
I have tested on Red Hat 7.1 and I'll try Read Hat 9.0. Let us know
if you can test another OS/distribution.
I want to release 5.7.0 next week.
Thanks.
Radim
./configure --without-postgres --with-tcltk-includes=/usr/include/tcl8.4
--without-odbc --without-fftw
make
make bindist
it built and installed fine on debian (unstable)
regards, Martin
with files copied from 5.3.0. This version is not tagged in CVS. The purpose of this version is to check if configure, make, make bindist and *-install.sh works on various platforms.
Radim,
Thank you for all your work. It is exciting to see all the progress.
On Gentoo (2004.0, kernel 2.4, gcc 3.3.2)
   works fine
On Cygwin (what version, I do not know)
   builds and installs without error, but nziv and v.digit do not work for me (this has been discussed previously).
Richard Greenwood
www.greenwoodmap.com
Hello Radim,
two erros, probably not primarily due to the installation procedure but
nevertheless an error .. did it happen before?
1. v.digit: error while loading shared libraries: libtk.so.0: cannot open
shared object file: No such file or directory
ln -s to where?
2. the button options->toggle form mode keeps on top of every window until I
select it.
Martin
> make
> make bindist
regards, Martin
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Thanks to all who tested.
On Monday 31 May 2004 17:26, Lorenzo Moretti wrote:
Platform: MAC OS X
Error:
The only problem is in r.mapcalc. The official 5.3 version
(15-05-2004) is wrong. Last cvs version is correct. I have copied
this version in your 5.7beta1 and I have built all modules.
What was wrong? Last change in grass/src/raster/r.mapcalc3 was 3 weeks ago
(May 11) before release_15_05_2004_grass5_3_0.
Another small error: tcltkgrass is old in 5.7beta1. Download last
version from Michael Barton site
(http://www.public.asu.edu/~cmbarton/grass.htm)
Only grass51/gui/tcltkgrass/Makefile has changed? I have updated in cvs.
PROJ support is missing from this final table but it's present in my
configure.
PROJ is requirement, so it is not printed.
ln -s to where?
I have
/usr/lib/libtk8.3.so -> libtk.so.0
/usr/lib/libtk.so -> libtk.so.0
/usr/lib/libtk.so.0
I select it.
Which module, which button?
This I don't know how to fix.
I have also fixed the 'magic' bug in attributes form (update mode did non work).
It was most probably caused by GRASS_FORM_MODE variable which I replaced by
'-e' flag in d.what.vect. d.m global option moved to vector's options.
d.what.vect will from now by default use VIEW mode.
Radim
make
make bindist
Worked OK compiling on an IRIX 6.2 system and installing on IRIX 6.4.
Configure line was
  CFLAGS="-O" LDFLAGS="-s" ./configure --with-libs=/usr/local/lib --with-includes=/usr/local/include --with-dbm=no --with-odbc=no
--with-postgres=no --with-fftw=yes --with-motif=yes --with-blas=yes
--with-cxx=no --with-opendwg
--with-opendwg-includes=/indigo-disk2/grass/opendwg/toolkit --with-opendwg-libs=/indigo-disk2/grass/opendwg/toolkit
and the only modification required before running make was the usual one of commenting out the HAVE_KEYPAD line in include/config.h so it will work with the (buggy) IRIX Winterm.
After installing the message reported
Installation finished. Start GRASS 5.7.0-mips-sgi-irix6.2-01_06_2004 with
     /usr/local/bin/grass-5.7.0-mips-sgi-irix6.2-01_06_2004
which is kind of off-putting! Especially as all that needed to be typed was grass57.
One another annoyance is that all the monitors closed down when exiting. Is this a new feature? I usually just leave monitors running permanently and if just exiting and restarting quickly to change location this could become annoying.
But overall looking good. Very small package and quick to install as well.
Paul
Thanks.
Configure line was
was grass57.
I have changed that now to $BINDIR/$GRASSPRG (= $BINDIR/grass57).
become annoying.
Yes, new feature:
http://grass.itc.it/pipermail/grass5/2004-May/014486.html
http://grass.itc.it/pipermail/grass5/2004-May/014528.html
I know that it is more work now, I was used to do the same. Maybe
it is just question of a habit because now it is possible to start more
sessions at the same time. Anyway, I think that the possibility
to run (without tricks) more sessions (e.g. scripts in one mapset
and interactive work in another) is more important than
this inconvenience.
We can maybe find a way how to reopen monitors when grass is started in X?
Radim
I have created beta2:
http://mpa.itc.it/radim/grass-5.7.0beta2.tar.gz
All bugs found (except nviz/v.digit on Cygwin) hopefully fixed.
This is mixed with 5.3 HEAD from CVS (even if I don't know
why 5.3.0 should not work).
Radim
PS: I have seen new features submitted to 5.3 HEAD after 5.3.0, why that?
that?
I was not aware there was now a feature freeze in place. Is there???
Is this temporary until 5.7.0 is done? or should all new raster changes,
e.g., go only into 5.7? What about minor-bugfixes? Should we hold off on
them until 5.7.0-final?
One of the things I just added[*] was specifically for easing the
transition to 5.7..
[*] 'v.in.ascii -s' to automatically run 'v.support -r' after importing
Hamish
transition to 5.7..
.. but obviously this isn't seen by copymix ..
There were other raster+lib changes though.
H
$ diff SRCPKG MIX
AUTHORS:
"RASTER
see 5.0 authors"
We should probably mix in a copy of AUTHORS_5.0 or something.
the TODO file:
- some are done but still in there
REQUIREMENTS.html:
- GDAL is now not optional?
- copyright at end of file 2003
compiled on Debian/testing (Sarge) on i686:
CFLAGS="-ggdb -march=pentium4 -Wall" ./configure \
     --with-tcltk-includes=/usr/include/tcl8.3 \
     --with-postgres-includes=/usr/include/postgresql \
     --with-motif --with-motif-includes=/usr/X11R6/include \
     --with-readline --with-gdal --with-cxx --with-glw
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /usr/local/src/grass/grass-5.7.0
Build directory: /usr/src/grass/grass-5.7.0
Installation directory: /usr/local/grass57
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -ggdb -march=pentium4 -Wall
C++ compiler: c++ -g -O2
FORTRAN compiler: g77
Building shared libraries: yes
  NVIZ: yes
  X11 support: yes
  JPEG support: yes
  TIFF support: yes
  PNG support: yes
  Tcl/Tk support: yes
  PostgreSQL support: yes
  MySQL support: no
  OpenGL(R) support: yes
  ODBC support: yes
  FFTW support: yes
  BLAS support: no
  LAPACK support: no
  Motif support: yes
  FreeType support: no
  GLw support: yes
  NLS support: no
  Readline support: yes
  C++ support: yes
  openDWG support: no
  GDAL support: yes
  OGR support: yes
builds ok
I ran 'make bindist' but didn't install with it.
'nviz elev=topo' works.
v.digit works.
Tcltkgrass: (looks really nice; some things need to be greyed out?)
[Import|Export] -> Vector -> Import/Export old GRASS vector format
v.convert is import only, are there plans to change that, or is
'v.out.ascii -o' the official way?
Export -> Raster -> GRASS ASCII:
as this does Surfer & Modflow formats as well, maybe just
"Export->ASCII"?
Display -> Display Manager
maybe that should read "[Start|Launch] Display Manager"
Display -> NVIZ visualization tool
maybe that should real "[Start|Launch] NVIZ visualization"
(tool is redundant, or at least not the right word..)
Generic Menu items: is it possible to give the module name (eg d.mon) in
a hint box upon mouseover?
Help -> Authors?
Maybe a flag from g.version?
congrats to all on a really nice job ..
Hamish
Yes, new feature:
more sessions at the same time. Anyway, I think that the possibility
this inconvenience.
in X?
How safe is this for changing mapsets via g.gisenv? I'm doing that all
day long. That works with 5.7.0 (+d.redraw), but I don't want to badly
screw anything up by mistake..
I know it's up to me not to have the same mapset loaded twice, but what
happens if on a bad day I do?
Do I have to add $LOCATION/$MAPSET/.gislock management to my mapset
changing script? I'm already running $GISBASE/etc/clean_temp upon exit..
Or is this tied to the process id that started it? Upon exiting GRASS
5.7.0 I get: ERROR: LOCATION_NAME not set
but it seems to be ok in ~/.grassrc57
thanks,
Hamish
> that?
yes, there is. No new features for 5.3
everything new should go into 5.7
that is all that can go into 5.3 so that 5.4 stable can be released.
Helena
transition to 5.7..
Hamish
grass5 mailing list
grass5@grass.itc.it
Now the display manager pops-up and a "task bar" -- looks great, much
more modules included, looks pretty sophisticated!
Nice, isn't it.
BTW when I do v.digit -> polygon and click right mouse button the
polygon should be closed, shouldn't it? In the display it is still
open.
Hm. That's not working correctly for me either.
Snapping only seems to work with previously established nodes; you can
change the thresholds in the settings menu, the default is 10 screen
pixels. So currently you need to use the "add vertex" tool to close the
area? Or move well away with the "move vertex" tool and then move it
back to get the area to close properly. shrug.
Hamish
$ diff SRCPKG MIX
MIX stores the info about 5.0 version (must be created by make mix),
SRCPKG sais that it is full 5.7 package (must be created by make bindist).
Both are temporary untill 5.0 is merged, not important I think.
AUTHORS:
"RASTER
see 5.0 authors"
Yes.
the TODO file:
Like doc/v.modules.html, my suggestion is to remove files we know
we are not able to keep up-to-date.
REQUIREMENTS.html:
I don't think so.
No.
or is 'v.out.ascii -o' the official way?
Yes.
Radim
> Yes, new feature:
> this inconvenience.
> in X?
This is not affected.
You get wrong outputs. I forgot about this possibility.
Yes.
Not clear to me when did you get this.
What about official
g.mapset/g.chmapset/g.set/g.reset/? gisdbase= location= mapset=
which would check if the mapset is in use, reset variables and run d.erase?
This should be in 5.7.0, I think. Otherwise it is too dangerous.
Radim
Nice, isn't it.
> open.
Yes.
Radim
On Thursday 03 June 2004 11:35, Radim Blazek wrote:
What about official
I have written g.mapset which does that (check mapset permission,
clean temporary files, erase monitors, reset variables).
But I don't know how to change shell settings (rc and history files),
so I hesitate to add it into CVS.
Radim
You cannot write a command to change the shell's environment. This is
the main reason why we have $GISRC and G_getenv() etc instead of just
using environment variables.
Although, GISRC shouldn't need to be changed; it should remain
constant for the duration of a session.
And, environment issues aside, you can't make the shell close the
history file and start writing a new one. You just have to accept the
fact that the history will be stored in the starting mapset.
In bash it is possible to do
export HISTFILE=myhist1
history -w
history -r myhist2
similarly in tcsh it should be possible
history -S myhist1
history -L myhist2
but it must be in a script without #!/bin/, is it a problem?
Radim
