[GRASS5] GRASS 5.7 binary for Cygwin installation problems
Thanks Teague. I'll forward this on to the list.
Michael
On 9/5/04 10:16 AM, "Teague O'Mara" <teague.omara@asu.edu> wrote:
Just an FYI: Deleting the size line made the binary self install work
perfectly.
Teague
-----Original Message-----
From: Paul Kelly [mailto:paul-grass@stjohnspoint.co.uk]
Sent: Sunday, August 29, 2004 3:52 PM
To: Michael Barton
Cc: grass5; teague.omara@asu.edu
Subject: Re: [GRASS5] GRASS 5.7 binary for Cygwin installation problems
On Sat, 28 Aug 2004, Michael Barton wrote:
He's downloaded them several times and tried to install them without
success, getting the error "The size of the binary package is not correct"
However, if we use a separate untar utility (or tar), it seems to
uncompress and expand fine. He is going to go ahead and install it
manually.
Is there perhaps a problem with the shell script? In line 24
TAR_FILE_SIZE=41899191
Change that number to the size of the file in bytes (check with ls -l) if
you're sure it downloaded correctly. Or just delete the lines in the
installation script that check the file size.
Paul
____________________
C. Michael Barton, Professor
School of Human Diversity and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
