H_B
1
If you use v.external to connect to a shape file, then remove the shape
file it no longer works. That's ok.
When you try to remove the zombie vector file with 'g.remove vect=foo'
it says:
REMOVE [foo]
ERROR: Cannot open layer 'foo_shp'
and it doesn't remove anything....
thanks,
Hamish
Fixed.
Radim
it says:
REMOVE [foo]
thanks,
Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
