Markus,
You can use the -ansi flag to force gcc to support full ANSI
features and to disable non-ANSI features. If you then use
-pedantic the compiler will reject any code that is not ANSI
standard. The error.log will contain a list of uncompiled
code.
If you redirect stderr to a file during compilation then
that file will give more details about the violations.
It would be nice if there were some way to get gcc to
convert non-ansi code to ansi code. World peace and an end
to all famine and pestilence would be nice too.
Roger Miller
Hi developers,
Prof Giulio Antoniol (who published the clone detection
for GRASS:
http://mpa.itc.it/markus/grass_clones/index.html
) is also interested to perform some profiling analysis on
the GRASS code.
This helps to find out where/if time is spent/wasted in
loops etc. E.g. the
'gprof' tool calculates the amount of time spent in each
routine.Later we'll probably add some code (locally at IRST) to
our GRASS version
and check for several days/weeks, which functions are used
and how time
consuming they are (to find potential areas for code
improvement).But: For the analysis the GRASS code must be ANSI C. It
seems that
there is still some K&R code existing....
Since Giulio Antoniol is busy at time he asked me to
'stimulate' some
code conversionAs I am not too confident with that, I would like to ask
- how we can identify K&R C coding style (any gcc
tricks?)
- how we can (partially automated) update to ANSI C (ok,
newbie question)?Thanks,
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
