Hi developers, Hi Markus,
is the problem with the void pointer arithmetics in segment lib (file
get_row.c) solved?
What about compiling on IRIX? Has someone succeeded in compiling beta8
from CVS on IRIX? I had no luck and got no response until now.
Sorry, i am busy with other projects right now so that i am not able to
verify my changes for datum support. Everything is ready for release,
but i couldn't run a test with known data/verify against another
implementation.
I would propose to wait some more days so that we can incorporate some
more fixes in beta8.
Another observation: The d.mon -L bug only occurs on Linux, on IRIX
everything is ok. I read the code and experimented with it, but i
couldn't find the problem. This is something for the signal
specialists/system programmers from BSD and SYSV.
cu,
Andreas
Markus Neteler wrote:
Dear developers,
if you agree, we should publish GRASS 5 beta8 by
Wednesday this week.
Is this o.k. with you?
I will prepare the Linux binaries and build them on Wednesday
morning. But we need volunteers for
- SGI
- Solaris
- DEC/Alpha64
If possible, please build the binaries from CVS on Wednesday to
store them on the GRASS web site. You can anonymous ftp to
ftp 130.75.72.14 (that's the WWW here)
cd incoming
Note: This directory is *write* only.
Thanks!
subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
