[GRASS5] GRASS 5 beta5b internal available
I had some problems compiling 5beta5a on IRIX 5.3. About 1/2 of the
errors were problems with dependencies in Gmakefiles - such as:
don't know how to make -lsun (bu42).
GISGEN failure at STEP: src/sites/s.territory
GISGEN failure at STEP: src/sites/s.sv
don't know how to make -lm (bu42).
GISGEN failure at STEP: src.contrib/CERL/raster/r.water.fea/src
GISGEN failure at STEP: src.contrib/SCS/misc/m.lulc.USGS
GISGEN failure at STEP: src.contrib/SCS/misc/m.strip99s
GISGEN failure at STEP: src.contrib/SCS/raster/r.out.rlc
GISGEN failure at STEP: src.contrib/SCS/raster/r.reclass.scs
I can fix these by changing Gmakefiles like this:
------OLD------
LIBRARIES = $(GISLIB) $(DATETIMELIB) $(XDRLIB)
PGM = $(BIN_CONTRIB_CMD)/s.territory
OFILES = main.o \
  territory.o \
  load.o
$(PGM): $(OFILES) $(LIBRARIES)
  $(CC) -o $@ $(LDFLAGS) $(OFILES) $(LIBRARIES) -lm
  @rm -f a.out
------NEW------
OFILES = main.o \
   territory.o \
         load.o
  $(CC) -o $@ $(LDFLAGS) $(OFILES) $(LIBRARIES) $(XDRLIB) -lm
  @rm -f a.out
There were also failures of various sorts on:
src/general/g.help
src/mapdev/v.digit
src/mapdev/v.geom
src/raster/r.mapcalc
src/raster/r.tiff
src.contrib/CERL/imagery/i.rvi.prediction2
src.contrib/CERL/raster/r.rvi
src.contrib/GMSL/NVIZ2.2
src.contrib/GMSL/SG3d
I haven't had time to look at any of these specifically.
I also had some trouble with make - I had to comment out
INSTALL_DATA_DIR= install -d -m 755
from the Makefile because IRIX install doesn't recognize -d.
What is INSTALL_DATA_DIR used for?
I ran the new grass5.0beta5a and it ran fine, as did tcltkgrass. But
when I went back to use my grass5.0beta2, which is my last stable
version, I get errors when I try to start a monitor - it starts OK,
but cannot lock so I can't "select" it. It was running fine before I
compiled the beta5 grass. Anybody know why this would happen? Or
how to fix it? The beta5 and beta2 binaries are in completely different
directory trees.
Another question: Does the current configuration script still allow
me to compile the same source tree on several different platforms? I
noticed that it still creates arch-specific subdirectories for object files,
but the binary tree no longer has the arch-specific directory.
- Bill
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 3510
max: 0
