[GRASS5] GRASS 5 beta8 tagged! Please build binaries now
Dear GRASS binary builders,
dear all,
the GRASS 5 beta 8 is tagged now:
"release_grass5beta8_26_july_2000"
Please check out the latest version using this tag:
cvs -z3 co -r "release_grass5beta8_26_july_2000" grass
From that please build your binary package.
What we need:
- Solaris_SUN : _______
- Solaris_Intel: _______
- Linux_Intel : Markus
- SGI/Irix : _______
- PPC : _______
- source code : Markus
- WIN/Cygnus : John
.. anything else? We have to keep in mind the limited space
on our mirrors.
Building the binaries *should* be possible using the target:
make bindist
THe tar file will be created within the grass5-bin directory
as expected by grass5_install.sh.
Thanks for your patience, many contributions could be integrated
the last 24hours!
I am grateful to all contributors! GRASS 5 is maturing very quickly
this year.
Kind regards
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
subject 'unsubscribe grass5'
Markus,
Getting Solaris Sun adn Intel built here on this end.
Bruce
dear all,
What we need:
- PPC : _______
- WIN/Cygnus : John
on our mirrors.
make bindist
the last 24hours!
this year.
Kind regards
What we need:
- PPC : _______
- WIN/Cygnus : John
We will create .src.rpms and .rpms for the next version of the
FreeGIS-CD for GNU/Linux/i585 soon and for GNU/Linux/ppc when we
get a machine back from apple. (Apple is quite slow on its
repair. :frowning: )
on our mirrors.
Nobody for GNU/Linux/alpha or OSF1/alpha? :slight_smile:
  Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Me.
I just wish there was a way on this end of my 56k modem to do a CVS
update to a tag revision and still be able to track the changes after
I have done a build. Possible?
James Cameron mailto:quozl@us.netrek.org http://quozl.netrek.org/
If you want to track the HEAD (default) branch, do a:
setenv CVSROOT [whatever goes here]
cvs -z3 co [module]
When you want to update to the latest, change to the
top checked out directory and:
cvs -z3 update -dP
The -z3 flag tells cvs to use compression on the data stream.
-d means create new subdirectories, -P means removed otherwise
empty subdirectories. The update command itself only retrieves
files that have been changed since your last update.
-- ebm
| Eric B. Mitchell mailto:emitchell@altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
              ,___
          /"\ / o=\ /"""---===/
         / \_/ \__/ ---===/
         | //\ || /""TT""/ //\ || ||""\
         | // \ || || // \ || ||__/
         | //--==\ |L--/ || //--==\ || || "=,
           \____---===/
cvs -z3 co [module]
cvs -z3 update -dP
You can try -z6 if your modem line is really slow.
Once you have a CVS checked out, it depends on how much changes.
For small changes you might be able to track and download it
using your modem line. :slight_smile:
  Bernhard
Hi Markus
On Jul 26, 4:01pm, Markus Neteler wrote:
What we need:
- PPC : _______
- WIN/Cygnus : John
I'll see what happens with our SGI Irix 6.5
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
I think Eric and Bernhard missed my point. I'm already maintaining a
current head, I was asking if there was a way to easily, with little
incremental bandwidth, maintain it temporarily as a copy of the tagged
head instead, for the purposes of building the binary distributions.
After building, I'd then want to revert my repository to the current
head version.
head version.
I think you're looking for:
cvs -z3 update -j [tag] .
This would merge changes from what you have to
the specified tag. Perform the binary build, then
cvs -z3 update -j HEAD
to restore to the head revision. You should check
the cvs docs, though instead of relying on what I
vaguely recall... The Per Cederquist manual is
quite good. I recommend reading the chapter on
branches and merging a couple dozen times.
-- ebm
              ,___
         / \_/ \__/ ---===/
           \____---===/
