[GRASS5] Grass 6 screenshots link broken
The link http://grass.itc.it/grass60/screenshots/index.php
...produces...
Warning: Failed opening '../menu_top.inc' for inclusion (include_path='.:/usr/share/pear') in /hardmnt/grass1/html/grass60/screenshots/index.php on line 60
...(at least for me).
Jack Varga
Boulder, CO
...produces...
sorry, that was my fault.
I tried to fix the broken links in the top menu
in .../grass/60/screenshots/index.php by setting the ../../menu_top.inc
to ../menu_top.inc but this probably caused the problem you just reported.
I fixed it in cvs and reset the line 60 of index.php in ..grass60/screenshots
to the previous settings, hence broken links in top menu will be present
again but better than this error message.
Martin
Jack Varga
Boulder, CO
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
> ...produces...
This doesn't work. Relative links are only implemented for
the first subdirectory level. Since grass60/screenshots/* live
in at subsubdirectory level, it crashes. Currentl, instead of
using the include() function, stuff must be hardcoded in the
file.
As I don't know much about PHP, is there a way to fix this
with a PHP function? A sort of on-the-fly update for PHP files
at subsubdirectory level?
Have a look at
http://grass.itc.it/grass60/screenshots/gui.php
which is correct. From this you can derive the fixes for the
other php pages in that directory.
On Friday 11 March 2005 08:05, Markus Neteler wrote:
Have a look at
hmm, the structure looks totally different to me index.php does have this
entry for the top menu
      include("../../menu_search.inc");
   </td>
   <td valign="top">
     <?php
       include("../../menu_top.inc");
where gui.php does has a entry for each link:
<!-- TOP MENU INCLUDE FOR SUBDIRECTORIES -->
    <table class="topmenu" bgcolor="#008000" cellspacing="0" cellpadding="0"
border="0" width="100%">
    <tbody>
     <tr>
     <td><!-- TOP MENU -->
      <table cellspacing="1" cellpadding="3" border="0" width="100%">
      <tbody>
        <tr bgcolor="#c5e2ca">
        <td nowrap="nowrap" align="center">
<font size="-1"><a href="../../index.php">Home</a></font>
        </td>
<font size="-1"><a href="../../intro/index.php">Introduction</a></font>
        </td>
I have no clue how to change it (where to insert the gui.php subdirectory
part) and try&error approaches wouldn't be the best because I cannot look at
the result unless I upload it to cvs and wait a couple of hours (is there a
way to see the final result on my computer like on the web?)
Martin
> Have a look at
   </td>
   <td valign="top">
     <?php
You got it! The structure is different (as I tried to explain).
The include() stuff only works in subdirectories, but not yet in
subsubdirectories as grass60/screenshots/* is.
the result
the trick is for the screenshot stuff:
- instead of using the include function actually *include* the code pieces
  and fix the links
- or write a nifty PHP function to automatically fix ../ to ../../ (or vice verse,
  can't remember)
Sure: launch a web server on your local machine and copy the
stuff into the local web space. Then run from
http://localhost/index.php
Thanks
