[GRASS5] grass and lock files
On Thu, Dec 07, 2000 at 05:11:51PM -0800, Eric G . Miller wrote:
On Thu, Dec 07, 2000 at 10:42:19AM -0700, Roger S. Miller wrote:
> Folks,
> I've been running on grass5 beta7 and will be upgrading soon to beta 9
> (er.. beta 10 now, I guess). I was wondering how other people have fit
> grass into their Linux file systems.
> For the beta7 installation I put the source distribution under
> /usr/local/src and installed the compiled binaries under /usr/grass5b7.
> I also placed the database under /usr/grass5b7. I want to change that for
> the new distribution.
Under FHS, /usr is reserved for the "distribution". User installed
binaries, libes, etc... go in /usr/local or /opt. Only major problem
with GRASS regarding /usr/local is the creation/deletion of lock files
which should be in /var/lock or /var/local/ or some such (I've created a
symlink in the past from /usr/local/grass5/lock =>
/var/local/grass5/lock in order for lock files to be created under /var
which is was mounted "rw", while /usr was mounted "ro" most of the time.
I now have /usr/local on a separate partition, so I don't worry about
that too much...
Hi developers,
what about changing the location of GRASS' lock files?
What about
/var/grass5/locks?
subject 'unsubscribe grass5'
What about
/var/grass5/locks?
Why not /var/lock/grass or /var/lock/grass5 ? At least RH already has a
/var/lock directory for this purpose.
MHu
> What about
> /var/grass5/locks?
Thanks, Morten.
SuSe7 also has /var/lock. So I would agree to use
/var/lock/grass5
> What about
> /var/grass5/locks?
This will work also for all AT&T SVR4 compliant OS (HP-UX, OSF/1, etc.)
MHu
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace@grr.ulaval.ca
Using the standard autoconf options, this should be
overridable with the --localstatedir option:
  --localstatedir=DIR modifiable single-machine data in DIR [PREFIX/var]
Teaching the Gmakefiles to recognize this option,
however, may take some hacking.
> > What about
> > /var/grass5/locks?
| Eric B. Mitchell mailto:emitchell@altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
              ,___
          /"\ / o=\ /"""---===/
         / \_/ \__/ ---===/
         | //\ || /""TT""/ //\ || ||""\
         | // \ || || // \ || ||__/
         | //--==\ |L--/ || //--==\ || || "=,
           \____---===/
Hi Markus
> > What about
> > /var/grass5/locks?
> has a /var/lock directory for this purpose.
Thanks, Morten.
/var/lock/grass5
As usual, nothing seems to be standard Unix. :frowning: IRIX doesn't have a
/var/lock but I have no idea what to do for IRIX.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
