Below is the result of your feedback form. It was submitted by
(aaime@comune.modena.it) on Monday, November 20, 2000 at 11:07:02
subject: Bugreport GRASS 5
platform: Linux/Intel
vendor: RedHat
cputype: Intel (i486, i586, pentium ...)
grassversion: Linux/Intel binaries
cvsyesno: -- select --
module: r.mapcalc
bugreport: r.mapcalc exit status is always the same (0) even if it found some errors in the expression. That's not good if you use it in a script!
I guess it should at least report an error status if the last expression wasn't correct or it found any other run time problem.
If you want to unsubscribe from grass-bugs
mailing list write to:
subject 'unsubscribe grass-bugs'
subject 'unsubscribe grass5'
this is fixed now.
Only a missing else statement.
But only the status of the _last_ expression is returned. Else the
module must exit on any error, what is not desirable.
Andreas
vendor: RedHat
module: r.mapcalc
