[GRASS5] [GRASS-bugs] Bugreport GRASS 5
Below is the result of your feedback form. It was submitted by
(Wwises@hpcc.nectec.or.th) on Monday, December 18, 2000 at 04:55:08
subject: Bugreport GRASS 5
platform: Linux/Intel
vendor: RedHat
cputype: Intel (i486, i586, pentium ...)
grassversion: Linux/Intel binaries
cvsyesno: -- select --
source_version: 5beta10
module: v.in.arc
bugreport: Both the tcltkgrass version and the interactive command line version seem to fail if the full path is used to define the input .lin or .pol file. This is confusing especially with tcltkgrass since using the "file" pushbutton to find the input file results in a full path definition.
Error message from tcltkgrass version:
v.in.arc: Coverage type = polygon
Illegal filename. character </> not allowed.Cannot find ARC/INFO lines file </home/grass/data/tiwrm/PERMANENT/arc/forest.pol>
Error message from command line interactive:
LINES FILENAME
Enter the name of the file created with the LINES
option of the ARC/INFO Ungenerate command
Hit RETURN to cancel request
WARNING: File could NOT be opened for reading
Result of "pwd" and "ls -l forest.pol"
GRASS:~/data/tiwrm/PERMANENT/arc > pwd
GRASS:~/data/tiwrm/PERMANENT/arc > ls -l forest.pol
-rwxr-xr-x 1 grass users 2351796 Dec 15 10:03 forest.pol
So, the file exists and is readable.
However, specifying the file without the full path in interactive mode seems to work.
PS The code package input field in this form should also be used for binary packages.
compiler: -- select --
name: Wisa Wisesjindawat
REMOTE_HOST: cache1.nectec.or.th
If you want to unsubscribe from grass-bugs
mailing list write to:
subject 'unsubscribe grass-bugs'
subject 'unsubscribe grass5'
