[GRASS5] [GRASS-bugs] Bugreport GRASS 5
On Debian, XFree3.x read XF86Config and XFree4.x reads XF86Config-4, so I'm
not sure this is a distribution problem. Isn't just a question of what version
of XFree you use ?
Moritz
On Tue, Dec 19, 2000 at 04:38:43PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > > bugreport: I have the repaint problem listed in the FAQ that X won't repaint the monitor when I drag a window over the monitor. I did the steps in the FAQ and my XF86Config file has the following:
> > which Xfree are you using? Which windows Manager?
> > Myself, the problem also persists on Xfree 4.0.1 and KDE 1/2.
> > Xfree 4.0.1 with fvwm2 is fine.
> > Time to investigate!
> If you hadn't noticed, the person who reported this bug is one of my
> colleagues.
Hi Justin,
yes, I have seen that.
> We found that the problem was that Red Hat does not use the
> XF86Config file but one named XF86Config-4 instead. Once we put the
> backingstore fix in the other file, the problem was fixed. Perhaps your
> system is similar?
Aha! Please describe the Redhat version, that I can add such a note
on the FAQ page.
However, I have:
xdpyinfo |grep -i back
  options: backing-store YES, save-unders YES
Do it is activated. But still this is causing problems on KDE2 (KDE1 as
well).
SuSe reads the /etc/X11/XF86Config.
Yours
subject 'unsubscribe grass5'
On Tue, Dec 19, 2000 at 01:00:57PM +0100, mlennert@club.worldonline.be wrote:
of XFree you use ?
Hi Moritz,
the Suse7 with Xfree4.0.1 reads /etc/X11/XF86Config,
the Suse6 with Xfree3.6.6 reads /etc/XF86Config
So it *is* dependent on the distro (welcome to the standardized
world of UNIX).
PS: I'll add a note onto the FAQ.
> > Hi Markus
> > colleagues.
> Hi Justin,
> > system is similar?
> on the FAQ page.
> However, I have:
> well).
> Yours
> Markus
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
