[GRASS5] GRASS development roadmap proposal
Users regularly ask (me) about the upcoming GRASS
releases and their features. To help them and also us
we should define a roadmap which also solves to some
extent the versioning problem.
Two problems have to be addresses:
- in a 5.0.x version we should not introduce
  datum transformation as the results will be
  different
- we should release datum transformation as soon as
  possible as it is crucial for GIS data processing.
Here a proposal which tries to minimize the version
naming problems:
stable experimental
5.0.2 (current) 5.1.0 (current)
5.0.3 5.3.0 (CVS 5.0 HEAD)
- bugfixes for 5.0.2 - datum transformation
- G3D activated - improved NVIZ
                          - r.terraflow (C++)
5.4.0 [no more exp development]
- bugfixes for 5.3.0
                          5.7.0 (was: 5.1.0 renamed)
                          - new 2D/3D vector
                          - DBMS support
                          - keep sites format [1]
                          - new Makefile system
                          - initial cleanup libs
                          - initial code inline docs
                            (doxygen)
5.8.0 5.9.0
- bugfixes for 5.7.0 - eliminate sites [2]
                          - improve raster format
                          - improve image processing
6.0.0 6.1.0
- bugfixes for 5.9.0
- includes now
   - new vector
   - DBMS support
   - polished libs
   - inline code docs
   - improved raster
   - etc.
[1] to keep the sites modules for a while seems to be
    necessary as we do not have the resources to upgrade
    all sites functionality to vector in short term.
    No efforts should be invested to improve the sites.
[2] point data are treated as vector nodes with following
    advantages:
    - spatial index for speed, DBMS, NULL support
Thanks for the proposal, it is a good idea to work on a roadmap.
We need to think in development lines
or as I often write series.
Your proposal below is not written to show the development lines.
Certainly we should have 5.0.3 as bug-fix releases.
We might also have further 5.0.x releases which IMO
should also be bug fix releases.
  different
I did not follow the datum discussions in detail.
What do you mean with: The results will be different?
Another idea would be to make in an experiemental add-on package
to 5.0.x if the datum transformation support is ready for this.
It is clear that the 5.0.x serious has to transform into the
5.1.x serious which then transforms into 5.2.x at some point
where 5.0.x support hopefully can be discontinued.
The renaming part (5.0 HEAD -> 5.3.0 and 5.1.0 -> 5.7.0) suggested
will cause confusion. I advise against it.
naming problems:
stable experimental
                          - r.terraflow (C++)
                          - new 2D/3D vector
                          - DBMS support
                            (doxygen)
5.8.0 5.9.0
6.0.0 6.1.0
- includes now
   - new vector
   - DBMS support
   - polished libs
   - inline code docs
   - improved raster
   - etc.
    advantages:
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Professional Service for Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (fsfeurope.org)
[Maybe also due to the ASCII limit.]
Line 1: 5.0.x
    -> only bugfixes, no new features, almost completed
Line 2: 5.3.x
    -> introducing datum transformation, few new features
       almost completed, but needs more testing
    --> stable will be 5.4.x
Line 3: 5.7.x
    -> introducing new vector format etc
       work in progress
    --> stable will be 5.8.x, leading to 6.x
This is what I tried to propose.
> different
We should not have 5.0.2 without datum transformation and
5.0.3 with datum transformation as the same commands (*.proj)
will end with different results. This means that the maps
are shifted up to some hundred meters. Subversions must
behave the same.
Yes, but with a different version name. Otherwise there will be
too much confusion in the user community ("why is my map
shifted...").
In general that the idea.
So please make a better proposal.
Yes, I know. That was just agreement. :slight_smile:
> > different
behave the same.
Why would the maps be shifted in particular?
Is it a systematic error in all versions?
Or an additonal feature.
If it is an error, when was it introduced?
shifted...").
Need to know more about the datum transformation situation
before I can suggest something reasonable.
Thinking more about it, renaming in a form close
to your proposal, might be a possible solution.
> > > different
> behave the same.
The datum transformation is an important feature which was
luckily implemented by Paul Kelly recently (using the datum
transformation routines from PROJ4).
Yes. All official GRASS versions are lacking this feature.
In 1984 when GRASS 1.0 was released :slight_smile:
Without the datum transformation routines a map re-projection
is less accurate. See for example:
http://mpa.itc.it/markus/tmp/asterdem_test_geotiff_utm_rivadelgarda.jpg
(the orthophoto was reprojected from Gauss-Boaga to UTM without datum
transformation)
> shifted...").
Sorry, should read:
In general it's the idea that 5.0.x support hopefully can be discontinued
in favor of the new developments.
You may search in the 'grass5' archives, there is a lot of discussion
stored.
Fine, so let's continue the discussion. More comments welcome.
My goal is to get out a new release for bugfixes (5.0.3) and
a new release containing the datum transformation and PROJ4
improvements (5.4.0) and probably a first release of the new
vector developments if Radim agrees.
> > > > different
That seems to be a point which should be easy to agree upon.
The reason is that the proj support would change to much
in the code.
Sorry, should read:
As long as there is no established stable version it certainly cannot
be discontinued and even after this, conservative users might continue it
by themselfs.
One drawback of the renaming would be the higher communication costs
and the further delay of the 5.1.x experimental release.
Also the release with the proj improvements would be more experimental
than the 5.0.3 release, so we'd probably should to release it as 5.y
where y is an odd number.
Renaming this to 5.1.x or 5.2 would bluff people expecting
5.2.x to the be stable version with vectors. Thus we had to rename it to 5.3.x.
Subsequently current 5.1.x can only be renamed to 5.7.x.
That was just writing down a couple of reasons
or thinking loud.
I now believe that Markus proposal is fine and will support it,
given the following remarks:
  It all only makes sense if the 5.3.x cycle is
  compartively very short. In other project we'd wait
  until it is integrated with 5.1.x or have it as an add on
  with a big warning sign.
  Renaming 5.1/5.2 -> 5.7/5.8 has to happen early,
      when communicating the whole plan
  It should be clarified that 5.9.x does not necessarily
  lead to 6.0.0, it can also lead to 5.10.x. :slight_smile:
In that case, it might be better to skip the 5.3.x naming, and just
use 5.4.0-pre1, -pre2 etc.
AFAICT, that branch would just be incremental changes to 5.0.x.
Changes which are significant enought to risk substantially breaking
compatibility with 5.0.x, but not fundamental architectural changes.
E.g.:
1. Datum transformation
2. NVIZ/OGSF updates
3. G3D updates
4. grass.postgresql "purge"
Sure; but I think that it has to be done. The gap between 5.0.x and
grass51 is too great not to have something in between. In many
regards, the changes between those two versions are more substantial
than those between 4.3 and 5.0.0.
> > > > > different
Perfect.
in the code.
Yes, you got it :slight_smile:
> Sorry, should read:
by themselfs.
Well, 5.0.x should be discontinued as soon as possible in terms of
introducing new features. Otherwise we never arrive at a better GRASS
implementation which is really needed and currently only almost
on Radim's shoulders.
It always depends on how many developers participate (hi!).
The higher communication costs seems to be my problem as usual
(updating the web site, changing docs etc). With a clear roadmap
published in a good place (first page?) the users can quickly
understand what's going on.
As I proposed: have another look at the initial mail
http://grass.itc.it/pipermail/grass5/2003-July/005913.html
stable experimental
5.0.3 5.3.0 (was: CVS 5.0 HEAD)
                          - r.terraflow (C++)
Renaming this to 5.1.x or 5.2 would bluff people expecting 5.2.x to the be
or thinking loud.
Also as I proposed :slight_smile:
" 5.7.0 (was: 5.1.0 renamed)
                          - new 2D/3D vector
                          - DBMS support
                            (doxygen)
Thanks.
Well, we'll see, So far I haven't seen any short cycle. It depends
as usual on our "human resources".
Sure, why not. We had 22 version of GRASS 4.2.1 and 11 betas of 5.0.x,
so we can keep the tradition :slight_smile:
Others wrote:
Glynn
Bernhard
Paul
naming problems
I think it's a very good forward looking plan. Especially as small 5.0.2
bug fixes for things like NVIZ are getting mixed in with major code
changes ..
It helps to aviod the current situation happening all over again as
well.
5.8.0 5.9.0
To that list for 5.9.0 I'd like to add a wish for a redesigned $MAPSET/*
directory structure (giving another reason for 6.0 to follow 5.9).
5.3 might exist for the ripping out of old PROJ code etc from CVS HEAD,
but as soon as it builds properly it might become 5.4.0-pre1. As long as
no (other) new major updates are allowed to be added to this branch, I
think CVS HEAD is probably very close to 5.4.0 right now.
With 5.0.x stable the early 5.4.0preX releases can be quicker and do not
have to be perfect.
Does having a 5.3+/5.0 split speed up the process of tagging for a new
release for Glynn & Markus?
An immediate feature freeze on significant changes to 5.3 also keeps
5.1/5.7 as the current experimental branch and avoids possible
stagnation on it and Radim frustration..
we might as well go ahead and remove the internal copy of PROJ that
is in GRASS and make an external PROJ installation an absolute
requirement.
For me it sounds good. There is no much point in maintaining a
partially outdated PROJ4 in a 5.3/5.4 release.
One thing we should have in mind is if Debian/SuSe/Mandrake/Redhat/...
have a RPM package and, if not, if we could suggest to add it.
Debian 'testing' has PROJ 4.4.7 as the 'proj' package already. No
problem on making it a dependency there as any new debian GRASS binary
would end up in 'testing' as well.
(http://packages.debian.org/proj)
There isn't a Debian GDAL package, but there are shapelib and libshp1
packages which are based on GDAL, for what that's worth.
Well, I don't expect any 5.3.x release the next days :slight_smile:
But maybe a 5.0.3, to stop the repeated NVIZ/tcl84 etc questions.
In general I think it would be a good idea to have preliminary releases
announced on the developer's list a week before the proper announcement
on the webpage/grasslist so we have more of a chance of catching future
gotchas like that one.
In any effect I think a firm feature freeze on the 5.0.x CVS branch (now)
would be a very good idea and adding datum transforms as a separate
add-on upgrade to 5.0.x would cause more confusion than good.
Backporting minor bug fixes to 5.0.x until 5.4 is mature shouldn't be
too much extra work.
Hamish
5.1/7.1? Not yet. Missing are still category index (for fast search
in features by category) and feature index (for SF formats (shapefile, OGR)
mapping grass offset to feature id (or probably path to feature in tree
for geometry collection) and part number). Both must be stored in file,
it means a change of the format (but only that part that may be rebuild by v.build).
I think that 5.1/7.1 should not be released until we believe that
the format is stable.
Radim
rom svicen@posta.unizar.es Tue Mar 2 16:34:28 2004
Received: from relay.unizar.es (mesa.unizar.es [155.210.11.66])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i22FYPS04408
  for <wingrass@grass.itc.it>; Tue, 2 Mar 2004 16:34:26 +0100
Received: from sergio.posta.unizar.es ([155.210.62.64])
  (authenticated bits=0)
  by relay.unizar.es (8.12.6/8.12.3) with ESMTP id i22FQ0wS019195
  for <wingrass@grass.itc.it>; Tue, 2 Mar 2004 16:26:00 +0100
Message-Id: <5.1.1.6.0.20040302162519.00b7f918@posta.unizar.es>
X-Sender: svicen@posta.unizar.es
X-Mailer: QUALCOMM Windows Eudora Version 5.1.1
Date: Tue, 02 Mar 2004 16:35:52 +0100
To: wingrass@grass.itc.it
Subject: run grass on cygwin
Mime-Version: 1.0
Content-Type: text/plain; charset="us-ascii"; format=flowed
X-Virus-Scanned: TAMIZ + Clamav en unizar.es
X-Bogosity: No, tests=bogofilter, spamicity=0.000000, version=0.15.13.1
Dear win-grass users.
I am starting in this software and I am trying to run it in windows. I have
installed the software without problems according to instructions indicated
in
http://grass.baylor.edu//grass5/binary/windows_cygnus/cygwin_grass50bininstall.html.
I have started grass on cygwin and the program starts without problems
using the XFree86 desktop mode. Nevertheles, when I want to start the
graphical user interface writing tcltkgrass, a error command line appear
indicating exec: wish: not found.
Does anyone know what can be the problem?.
Many thanks
Sergio Vicente
rom raghavan@media.osaka-cu.ac.jp Thu Apr 8 04:18:47 2004
Received: from isvw2.bb.osaka-cu.ac.jp (isvw2.bb.osaka-cu.ac.jp [160.193.2.62])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i382IgS19192;
  Thu, 8 Apr 2004 04:18:43 +0200
Received: from grape.media.osaka-cu.ac.jp (localhost [127.0.0.1])
  by isvw2.bb.osaka-cu.ac.jp (8.11.6/parse8.359.2.8/8.11.6) with ESMTP id i382IdD26690;
  Thu, 8 Apr 2004 11:18:39 +0900 (JST)
Received: from media.osaka-cu.ac.jp (s3ad181.media.osaka-cu.ac.jp [160.193.3.181])
  by grape.media.osaka-cu.ac.jp (8.12.11/8.12.11) with ESMTP id i382IUnW023202;
  Thu, 8 Apr 2004 11:18:38 +0900 (JST)
  (envelope-from raghavan@media.osaka-cu.ac.jp)
Message-ID: <4074B656.2010508@media.osaka-cu.ac.jp>
Date: Thu, 08 Apr 2004 11:17:58 +0900
From: Venkatesh Raghavan <raghavan@media.osaka-cu.ac.jp>
User-Agent: Mozilla Thunderbird 0.5 (Windows/20040207)
X-Accept-Language: en-us, en
MIME-Version: 1.0
To: grassgui@grass.itc.it, statsgrass@grass.itc.it, nvizlist@grass.itc.it,
   sqlgrass@grass.itc.it, wingrass@grass.itc.it, grass5@grass.itc.it,
   grass-commit@grass.itc.it, weblist@grass.itc.it
Subject: FOSS/GRASS 2004
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Dear All,
With a little over a month left for the deadline for submission
of abstracts (30 April, 2004), I would like to remind the
subscribers of this list to kindly submit their abstracts
through the conference web-page
(http://gisws.media.osaka-cu.ac.jp/grass04/).
The conference is scheduled to be held at Chulalongkorn University,
Bangkok, Thailand from 12-14 September 2004. Details are
available on the conference web-site. Looking forward
to seeing many GRASS users and developers at the conference
and hoping that the conference would be a big success. Would also
like to request you all to pass on the info about the upcoming
conference thru appropriate channels/forum that may be accessible
to you.
Kind regards
Raghavan
Dr. Venkatesh Raghavan
Grass Users Conference 2004
Co-cordinator
rom m.de.gier@gems.nl Wed Apr 14 11:22:28 2004
Received: from ns.ncn.nl (ns.ncn.nl [194.229.20.1])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3E9MMS11751
  for <wingrass@grass.itc.it>; Wed, 14 Apr 2004 11:22:26 +0200
Received: from unspecified.host (dyndialup36.ncn.nl [195.7.159.36])
  by ns.ncn.nl (8.12.6/8.12.6) with ESMTP id i3E9MFBJ027838
  for <wingrass@grass.itc.it>; Wed, 14 Apr 2004 11:22:16 +0200
Received: from 192.168.0.214 ([192.168.0.214]) by 192.168.0.5 (WinRoute Pro 4.2.5) with SMTP; Wed, 14 Apr 2004 11:22:28 +0200
To: <wingrass@grass.itc.it>
Subject: FW: AntiVir ALERT [mail from: wingrass@grass.itc.it]
Date: Wed, 14 Apr 2004 11:21:16 +0200
Message-ID: <000401c42201$d7707680$d600a8c0@g17>
MIME-Version: 1.0
  charset="iso-8859-1"
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
Importance: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2615.200
X-Bogosity: No, tests=bogofilter, spamicity=0.481721, version=0.15.13.1
-----Oorspronkelijk bericht-----
Van: AntiVir@ncn.nl [mailto:AntiVir@ncn.nl]
Verzonden: woensdag 14 april 2004 11:08
Aan: info@gems.nl
Onderwerp: AntiVir ALERT [mail from: wingrass@grass.itc.it]
* * * * * * * * * * * * * * * AntiVir ALERT * * * * * * * * * * * * * * *
This version of AntiVir is licensed and full featured.
AntiVir has detected the following in a mail addressed to you:
        Worm/NetSky.C
The mail was not delivered.
Mail-Info:
--8<--
To: info@gems.nl
Date: Wed, 14 Apr 2004 11:05:50 +0200
Subject: believe me
--8<--
AntiVir for UNIX
Copyright (C) 1994-2003 by H+BEDV Datentechnik GmbH. All rights reserved.
For more information see http://www.antivir.de/ or http://www.hbedv.com/
rom Mike@mikhul1.f2s.com Sat Apr 24 21:42:15 2004
Received: from i-194-106-33-237.freedom2surf.net (i-194-106-33-237.freedom2surf.net [194.106.33.237])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3OJgES12616
  for <wingrass@grass.itc.it>; Sat, 24 Apr 2004 21:42:14 +0200
Received: from MikeWorkstation (i-195-137-102-94.freedom2surf.net [195.137.102.94])
  by i-194-106-33-237.freedom2surf.net (8.12.10/8.12.10) with SMTP id i3OJfxl5019893
  for <wingrass@grass.itc.it>; Sat, 24 Apr 2004 20:42:08 +0100
Message-ID: <004601c42a34$367bde50$5e6689c3@MikeWorkstation>
Subject: tcltkgrass&
Date: Sat, 24 Apr 2004 20:42:01 +0100
MIME-Version: 1.0
X-Security: MIME headers sanitized on grass
  See http://www.impsec.org/email-tools/sanitizer-intro.html
  for details. $Revision: 1.139 $Date: 2003-09-07 10:14:23-07
Content-Type: multipart/alternative;
  boundary="----=_NextPart_000_0043_01C42A3C.9812F4C0"
X-Priority: 3
X-Mailer: Microsoft Outlook Express 6.00.2800.1409
Disposition-Notification-To: "Mike Francis" <Mike@mikhul1.f2s.com>
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
This is a multi-part message in MIME format.
------=_NextPart_000_0043_01C42A3C.9812F4C0
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
As a newbie I'm trying to find my way through the install and first run =
of Grass5. I have arrived at the prompt 'tcltkgrass&' and this generates =
a start-up script error. Could someone tell me how to get the graphical =
user interface working? I am running an up-to-date XP Pro box, and I've =
downloaded all the
components of Cygwin. The version of GRASS I've installed is 5.0.3 i686
cygwin. The error message is generated after grass5 seems to load OK =
then I
type in . tcltkgrass5. The "Error in startup script" box then pops up =
with
"/usr/XIIR6/bin/xwininfo: unable to open display".
Hope this makes sense to you.
Many thanks for your time.
Mike
Content-Type: text/html; charset="iso-8859-1"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<DEFANGED_META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<DEFANGED_META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<!-- <DEFANGED_STYLE> --> </DEFANGED_STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>
<DIV><FONT face=3DArial size=3D2>Hi,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>As a newbie I'm trying to find my way =
through the=20
install and first run of Grass5. I have arrived at the prompt =
'tcltkgrass&amp;'=20
and this generates a start-up script error. Could someone tell me how to =
get the=20
graphical user interface working? I am running an up-to-date XP Pro box, =
and=20
I've downloaded all the<BR>components of Cygwin. The version of GRASS =
I've=20
installed is 5.0.3 i686<BR>cygwin. The error message is generated after =
grass5=20
seems to load OK then I<BR>type in . tcltkgrass5. The "Error in startup =
script"=20
box then pops up with<BR>"/usr/XIIR6/bin/xwininfo: unable to open=20
display".<BR><BR>Hope this makes sense to you.<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Many thanks for your time.</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>Mike</FONT></DIV></FONT></DIV></BODY></HTML>
------=_NextPart_000_0043_01C42A3C.9812F4C0--
rom Mike@mikhul1.f2s.com Tue Apr 27 21:30:48 2004
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3RJPRS15887
  for <wingrass@grass.itc.it>; Tue, 27 Apr 2004 21:30:48 +0200
  by i-194-106-33-237.freedom2surf.net (8.12.10/8.12.10) with SMTP id i3RJOxl5009799;
  Tue, 27 Apr 2004 20:25:00 +0100
Message-ID: <001001c42c8d$5774cda0$5e6689c3@MikeWorkstation>
To: "WINGRASS" <wingrass@grass.itc.it>, <GRASSLIST@baylor.edu>
Subject: Starting Grass 5.0
Date: Tue, 27 Apr 2004 20:25:03 +0100
MIME-Version: 1.0
  boundary="----=_NextPart_000_000D_01C42C95.B8F66040"
X-Priority: 3
------=_NextPart_000_000D_01C42C95.B8F66040
I have written the following batch (grass5start.bat) file to run Grass5 =
inside Cygwin on an XP Pro box:
echo off
echo.
echo This batch program
echo starts GRASS5.
echo written by Mike Francis.
echo.
echo off
:begin
set export DISPLAY=3D127.0.0.1:0
XWin -multiwindow -clipboard &
start C:\cygwin\user\local\bin\grass5
set d.mon x0
start c:\cygwin\user\local\bin\tcltkgrass &
However, my paltry knowledge of batch files has let me down - it stalls =
at 'start ... grass5'
I wonder if anyone can help out with some advice?
Many thanks,
Mike
<HTML><HEAD>
</HEAD>
<DIV><FONT face=3DArial size=3D2>I have written the following batch=20
(grass5start.bat)&nbsp;file to run Grass5 inside Cygwin on an XP Pro=20
box:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>echo off<BR>echo.<BR>echo This batch=20
program<BR>echo starts GRASS5.<BR>echo written by Mike =
Francis.<BR>echo.<BR>echo=20
off<BR>:begin<BR>set export DISPLAY=3D127.0.0.1:0<BR>XWin -multiwindow =
-clipboard=20
&amp;<BR>start C:\cygwin\user\local\bin\grass5<BR>set d.mon x0<BR>start=20
c:\cygwin\user\local\bin\tcltkgrass &amp;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>However, my paltry knowledge of batch =
files has let=20
me down - it stalls at 'start ... grass5'</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I wonder if anyone can help out with =
some=20
advice?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Many thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Mike</FONT></DIV></BODY></HTML>
------=_NextPart_000_000D_01C42C95.B8F66040--
rom Mike@mikhul1.f2s.com Tue Apr 27 22:03:25 2004
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3RJw3S16706
  for <wingrass@grass.itc.it>; Tue, 27 Apr 2004 22:03:24 +0200
  by i-194-106-33-237.freedom2surf.net (8.12.10/8.12.10) with SMTP id i3RJv3l5015545;
  Tue, 27 Apr 2004 20:57:29 +0100
Message-ID: <003301c42c91$e1328100$5e6689c3@MikeWorkstation>
Subject: Wireless Networking and GRASS
Date: Tue, 27 Apr 2004 20:57:07 +0100
MIME-Version: 1.0
  boundary="----=_NextPart_000_002E_01C42C9A.33D6FE10"
X-Priority: 3
X-Bogosity: No, tests=bogofilter, spamicity=0.218751, version=0.15.13.1
------=_NextPart_000_002E_01C42C9A.33D6FE10
Has anyone had any experience of using GRASS as a navigation server in a =
location-based mobile system? I am developing a navigation system for =
the blind based on GRASS5. I would like the navigation server to deliver =
maps and text output to a variety of clients (PDAs or mobile phones) via =
a wireless network. Is this possible?
Mike
Dr. Michael Francis Ph.D (Lancaster); M.Sc (Lancaster); M.Sc (London); =
BA Hons (CNAA) MBCS MCIT MIHT
Senior Lecturer in Information Systems
Director, Merseyside Regional Research Laboratory,
Liverpool John Moores University,
Liverpool,
England
Telephone 079 600 600 72
<HTML><HEAD>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Has anyone had any experience of =
using&nbsp;GRASS=20
as a navigation server in a location-based mobile system? I am =
developing a=20
navigation system for the blind based on GRASS5. I would like the =
navigation=20
server to deliver maps and text output to a variety of clients (PDAs or =
mobile=20
phones) via a wireless network. Is this possible?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards,</FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2>++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++=
++++++++++++++++++++++<BR>Dr.=20
Michael Francis Ph.D (Lancaster); M.Sc (Lancaster); M.Sc (London); BA =
Hons=20
(CNAA) MBCS MCIT MIHT<BR>Senior Lecturer in Information =
Systems<BR>Director,=20
Merseyside Regional Research Laboratory,<BR>Liverpool John Moores=20
University,<BR>Liverpool,<BR>England</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Telephone 079 600 600 =
72</FONT></DIV></BODY></HTML>
------=_NextPart_000_002E_01C42C9A.33D6FE10--
rom Mike@mikhul1.f2s.com Wed Apr 28 14:17:20 2004
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3SCBxS29484
  for <wingrass@grass.itc.it>; Wed, 28 Apr 2004 14:17:20 +0200
  by i-194-106-33-237.freedom2surf.net (8.12.10/8.12.10) with SMTP id i3SCBdl5004788;
  Wed, 28 Apr 2004 13:11:42 +0100
Message-ID: <005e01c42d19$fa698c30$5e6689c3@MikeWorkstation>
To: <GRASSLIST@baylor.edu>, "WINGRASS" <wingrass@grass.itc.it>
Subject: default start files
Date: Wed, 28 Apr 2004 13:11:44 +0100
MIME-Version: 1.0
  boundary="----=_NextPart_000_005B_01C42D22.5AABC100"
X-Priority: 3
------=_NextPart_000_005B_01C42D22.5AABC100
Could someone tell me where on a Cygwin set-up the default location and =
name is for grass5 startup file/s. I need to access it/them from a batch =
file.
Many thanks,
Mike
Liverpool,
England
<HTML><HEAD>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Could someone tell me where on a Cygwin =
set-up the=20
default location and name&nbsp;is for grass5 startup file/s. I need to =
access=20
it/them from a batch file.</FONT></DIV>
Hons=20
<DIV>&nbsp;</DIV>
------=_NextPart_000_005B_01C42D22.5AABC100--
rom paul-grass@stjohnspoint.co.uk Wed Apr 28 17:37:52 2004
Received: from customer-relay-1.mail.uksolutions.net (customer-relay-1.mail.uksolutions.net [217.10.128.165])
  by grass.itc.it (8.11.6/8.11.2) with SMTP id i3SFbqC03099
  for <wingrass@grass.itc.it>; Wed, 28 Apr 2004 17:37:52 +0200
Received: (qmail 28382 invoked from network); 28 Apr 2004 15:34:05 -0000
Received: from agrippa.ukshells.co.uk (217.10.143.90)
  by customer-relay-1.mail.uksolutions.net with SMTP; 28 Apr 2004 15:34:05 -0000
Received: (qmail 30995 invoked from network); 28 Apr 2004 15:37:51 -0000
Received: from services.agrippa.ukshells.co.uk (217.10.143.91)
  by agrippa.ukshells.co.uk with SMTP; 28 Apr 2004 15:37:51 -0000
Date: Wed, 28 Apr 2004 16:37:51 +0100 (BST)
To: Mike Francis <Mike@mikhul1.f2s.com>
cc: GRASSLIST@baylor.edu, WINGRASS <wingrass@grass.itc.it>
Subject: Re: [GRASSLIST:3293] default start files
In-Reply-To: <005e01c42d19$fa698c30$5e6689c3@MikeWorkstation>
Message-ID: <Pine.LNX.4.58.0404281634500.30341@agrippa.ukshells.co.uk>
References: <005e01c42d19$fa698c30$5e6689c3@MikeWorkstation>
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; charset=US-ASCII
Hello
On Wed, 28 Apr 2004, Mike Francis wrote:
Could someone tell me where on a Cygwin set-up the default location and name is for grass5 startup file/s. I need to access it/them from a batch file.
It's not clear to me what/why you are trying to do here. As I understand
it you should start GRASS from the Cygwin bash shell. Is there a good
reason for not doing that? Something like
c:\cygwin\bin\bash -c /usr/local/bin/grass53
might work from the Windows command prompt (or a batch file) but I'm not
sure; maybe you could elaborate on why you need it to be a Windows batch
file and not a Cygwin shell script (if, say you want to do something like
set the DISPLAY variable before starting GRASS)
Paul
rom glynn.clements@virgin.net Wed Apr 28 18:24:30 2004
Received: from n082.sc1.cp.net (h36.rdg.cp.net [209.228.29.85])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3SGOTC04396
  for <wingrass@grass.itc.it>; Wed, 28 Apr 2004 18:24:29 +0200
Received: from cerise.nosuchdomain.co.uk (62.252.68.95) by n082.sc1.cp.net (7.0.027.3-1)
        id 4088A3CB00051261; Wed, 28 Apr 2004 16:24:11 +0000
Received: (from glynn@localhost)
  by cerise.nosuchdomain.co.uk (8.11.6/8.11.6) id i3SFt1U01725;
  Wed, 28 Apr 2004 16:55:01 +0100
MIME-Version: 1.0
Message-ID: <16527.54229.511494.899591@cerise.nosuchdomain.co.uk>
Date: Wed, 28 Apr 2004 16:55:01 +0100
Cc: <GRASSLIST@baylor.edu>, "WINGRASS" <wingrass@grass.itc.it>
X-Mailer: VM 7.07 under 21.4 (patch 15) "Security Through Obscurity" XEmacs Lucid
file.
What do you mean by "startup file/s"? The session file (which contains
the current database, location and mapset) is $HOME/.grassrc5. The
script which is used to start a GRASS session is usually
/usr/local/bin/grass5 (or grass53/grass57 for the development
versions).
rom Mike@mikhul1.f2s.com Thu Apr 29 23:43:21 2004
Received: from outmail.freedom2surf.net (i-194-106-33-237.freedom2surf.net [194.106.33.237])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3TLhKC07951
  for <wingrass@grass.itc.it>; Thu, 29 Apr 2004 23:43:21 +0200
  by outmail.freedom2surf.net (8.12.10/8.12.10) with SMTP id i3TLgeUA011747;
  Thu, 29 Apr 2004 22:42:41 +0100
Message-ID: <001801c42e32$e570bd70$5e6689c3@MikeWorkstation>
Subject: UK Data
Date: Thu, 29 Apr 2004 22:42:40 +0100
MIME-Version: 1.0
  boundary="----=_NextPart_000_0015_01C42E3B.46F00620"
X-Priority: 3
X-Bogosity: No, tests=bogofilter, spamicity=0.000065, version=0.15.13.1
------=_NextPart_000_0015_01C42E3B.46F00620
Does anyone know if GRASS 5.0 can import UK OS Mastermap data?
Mike
<HTML><HEAD>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Does anyone know if GRASS 5.0 can =
import UK OS=20
Mastermap data?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
------=_NextPart_000_0015_01C42E3B.46F00620--
rom lcayuela@sclc.ecosur.mx Fri Apr 30 23:58:56 2004
Received: from master.sclc.ecosur.mx ([200.23.34.2])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i3ULwsC18222
  for <wingrass@grass.itc.it>; Fri, 30 Apr 2004 23:58:55 +0200
Received: from deco4128 ([10.1.2.7]) by master.sclc.ecosur.mx with Microsoft SMTPSVC(5.0.2195.6713);
   Fri, 30 Apr 2004 17:06:34 -0500
Message-ID: <002101c42ec3$bdd2dd70$0702010a@deco4128>
Subject: warning error reading compressed map in mapset
Date: Fri, 30 Apr 2004 16:59:30 +0200
MIME-Version: 1.0
  boundary="----=_NextPart_000_001E_01C42ED4.80F0B6A0"
X-Priority: 3
X-Mailer: Microsoft Outlook Express 6.00.2800.1158
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
X-OriginalArrivalTime: 30 Apr 2004 22:06:34.0203 (UTC) FILETIME=[665B8AB0:01C42EFF]
X-Bogosity: No, tests=bogofilter, spamicity=0.024635, version=0.15.13.1
------=_NextPart_000_001E_01C42ED4.80F0B6A0
Dear all,
I am a new user of wingrass and therefore I am quite unfamiliar with =
this software. I have realised that I get lot of problems running grass =
from my laptop whereas none from other pcs. I wonder why. The first =
problem is in using r.in.gdal to import data from arc to grass. It =
apparently works properly but at the end there is no map imported that =
can be visualised. The same occurs using r.in.arc or r.in.ascii. I have =
tried to import data from another computer and then transfer those files =
to my lap top. But when transferring the files they get corrupted and =
the following message is shown: "warning error reading compressed map =
... in mapset [permanent] row 2222". This happens with all the files I =
have transferred although they display properly in the other pcs. I have =
reinstalled grass several times but it doesn=B4t seem to work out.
Could there be any incompatibility with windows XP? I would appreciate =
any comment that could help to sort out this problem.=20
Thanks in advance,=20
Luis
Luis Cayuela Delgado
Dpto. de Ecolog=EDa, Facultad de Ciencias
Universidad de Alcal=E1
Crta. Madrid-Barcelona km. 33.6
Alcal=E1 de Henares 28871, Madrid
Tlf: (+34) 918856407
Fax: (+34) 918854929
E-mail contacto: luis.cayuela@uah.es=20
E-mail provisional: lcayuela@sclc.ecosur.mx
<HTML><HEAD>
<DEFANGED_META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Dear all,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am a new user of wingrass and =
therefore I am=20
quite unfamiliar with this software. I have realised that I get lot of =
problems=20
running grass from my laptop whereas none&nbsp;from other pcs. I wonder =
why. The=20
first problem is in using r.in.gdal to import data from arc to grass. It =
can be=20
visualised.&nbsp;The same occurs using r.in.arc or r.in.ascii. =
I&nbsp;have tried=20
to import data from another computer and then transfer those files to my =
lap=20
top. But when transferring the files they get corrupted and the =
following=20
message is shown: "warning error reading compressed map ... in mapset=20
[permanent] row 2222". This happens with all the files I have =
transferred=20
although they display properly in the other pcs. I have reinstalled =
grass=20
several times but it doesn=B4t seem to work&nbsp;out.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Could there be any incompatibility with =
windows XP?=20
I would appreciate any comment&nbsp;that could help to sort out this =
problem.=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks in advance,</FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Luis</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Luis Cayuela Delgado<BR>Dpto. de =
Ecolog=EDa, Facultad=20
de Ciencias<BR>Universidad de Alcal=E1<BR>Crta. Madrid-Barcelona km.=20
33.6<BR>Alcal=E1 de Henares 28871, Madrid<BR>Tlf: (+34) =
918856407<BR>Fax: (+34)=20
918854929<BR>E-mail contacto: <A=20
href=3D"mailto:luis.cayuela@uah.es">luis.cayuela@uah.es</A> <BR>E-mail=20
provisional: <A=20
href=3D"mailto:lcayuela@sclc.ecosur.mx">lcayuela@sclc.ecosur.mx</A></FONT=
------=_NextPart_000_001E_01C42ED4.80F0B6A0--
rom Mike@mikhul1.f2s.com Wed May 5 22:12:09 2004
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i45KC8C12917
  for <wingrass@grass.itc.it>; Wed, 5 May 2004 22:12:09 +0200
  by outmail.freedom2surf.net (8.12.10/8.12.10) with SMTP id i45KBbUA005368;
  Wed, 5 May 2004 21:11:38 +0100
Message-ID: <001a01c432dd$2e205a90$5e6689c3@MikeWorkstation>
Subject: Navigation
Date: Wed, 5 May 2004 21:11:41 +0100
MIME-Version: 1.0
  boundary="----=_NextPart_000_0017_01C432E5.8FA91920"
X-Priority: 3
------=_NextPart_000_0017_01C432E5.8FA91920
I am developing a navigation system for the blind. A particular problem =
I need to overcome is to determine the exact bearing a user is facing. =
For example, a person with normal sight knows which direction s/he is =
facing because they are able to use 'line-of-sight' to landmarks. =
However, a blind person, cannot use line-of-sight and s/he have no idea =
in which direction they are facing. Now, a usual navigation system can =
plot the shortest path and offer directions from an origin to a =
destination. However, until we are able to determine the direction faced =
by a user we cannot offer navigation instructions. I was wondering if =
anyone has any ideas how I can use GRASS and a GPS attached to a PDA to =
determine this 'micro-bearing' data?
Thanks for your help.
Mike
Liverpool,
England
<HTML><HEAD>
</HEAD>
<DIV><FONT face=3DArial size=3D2>I am developing a navigation system for =
the blind.=20
A particular problem I need to overcome is to determine the exact =
bearing a user=20
is facing. For example, a person with normal sight knows which direction =
s/he is=20
However, a=20
blind person, cannot use line-of-sight and s/he have no idea in which =
direction=20
they are facing. Now, a usual navigation system can plot the shortest =
path and=20
offer directions from an origin to a destination. However, until we are =
able to=20
determine the direction faced by a user we cannot offer navigation =
instructions.=20
I was wondering if anyone has any ideas how I can use GRASS and a GPS =
attached=20
to a PDA to determine this 'micro-bearing' data?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your help.</FONT></DIV>
Hons=20
<DIV>&nbsp;</DIV>
------=_NextPart_000_0017_01C432E5.8FA91920--
rom Mike@mikhul1.f2s.com Fri May 7 22:40:04 2004
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i47Ke3C27204
  for <wingrass@grass.itc.it>; Fri, 7 May 2004 22:40:03 +0200
  by outmail.freedom2surf.net (8.12.10/8.12.10) with SMTP id i47Ke0UA004454
  for <wingrass@grass.itc.it>; Fri, 7 May 2004 21:40:01 +0100
Message-ID: <005801c43473$787c6c40$5e6689c3@MikeWorkstation>
Subject: subscribe
Date: Fri, 7 May 2004 21:40:01 +0100
MIME-Version: 1.0
  boundary="----=_NextPart_000_0055_01C4347B.DA079BD0"
X-Priority: 3
X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
X-Bogosity: No, tests=bogofilter, spamicity=0.023683, version=0.15.13.1
------=_NextPart_000_0055_01C4347B.DA079BD0
SUBSCRIBE WINGRASS Mike@mikhul1.f2s.com
<HTML><HEAD>
</HEAD>
<DIV>SUBSCRIBE WINGRASS <A=20
href=3D"mailto:Mike@mikhul1.f2s.com">Mike@mikhul1.f2s.com</A><BR></DIV></=
BODY></HTML>
------=_NextPart_000_0055_01C4347B.DA079BD0--
rom zeynep21@ttnet.net.tr Tue May 25 13:53:49 2004
Received: from labris3.ttnet.net.tr ([212.156.4.153])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i4PBrnC08020
  for <wingrass@grass.itc.it>; Tue, 25 May 2004 13:53:49 +0200
Received: from localhost (localhost.localdomain [127.0.0.1])
  by labris3.ttnet.net.tr (Postfix) with ESMTP id 410A42FCA0
  for <wingrass@grass.itc.it>; Tue, 25 May 2004 14:52:49 +0300 (EEST)
Received: from labris3.ttnet.net.tr ([127.0.0.1])
by localhost (labris3.ttnet.net.tr [127.0.0.1]) (amavisd-new, port 10024)
with ESMTP id 23087-02 for <wingrass@grass.itc.it>;
Tue, 25 May 2004 14:52:48 +0300 (EEST)
Received: from epdplan4 (unknown [212.174.165.201])
  by labris3.ttnet.net.tr (Postfix) with ESMTP id 8451D2FB93
  for <wingrass@grass.itc.it>; Tue, 25 May 2004 14:52:43 +0300 (EEST)
Message-ID: <00d501c4424f$8366ab90$4e1310ac@dsibim.local>
Subject: cygwin install error
Date: Tue, 25 May 2004 14:57:49 +0300
MIME-Version: 1.0
  boundary="----=_NextPart_000_00D2_01C44268.A58252B0"
X-Priority: 3
Disposition-Notification-To: "Sezar Ercan" <zeynep21@ttnet.net.tr>
X-Virus-Scanned: by labris-ms-security(http://www.idealteknoloji.com/labris/) at labris.ttnet.net.tr
X-Bogosity: No, tests=bogofilter, spamicity=0.005048, version=0.15.13.1
------=_NextPart_000_00D2_01C44268.A58252B0
Content-Type: text/plain; charset="iso-8859-9"
I am getting error while running install script.
Please help.
Sezar=20
Here is screen dump.
bash-2.05b$ ./grass5_i686-pc-cygwin_install.sh =
grass5.0.3_i686-pc-cygwin_bin.tar.gz
GRASS GIS 5 binary package installation tool
ERROR: You need the GRASS binary package in .tar.gz compression
or .tar.bz2.
bash-2.05b$
Content-Type: text/html; charset="iso-8859-9"
<HTML><HEAD>
charset=3Diso-8859-9">
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi all,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am getting error while running =
install=20
script.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Please help.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sezar </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Here is screen dump.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>bash-2.05b$ =
./grass5_i686-pc-cygwin_install.sh=20
grass5.0.3_i686-pc-cygwin_bin.tar.gz</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>GRASS GIS 5 binary package installation =
tool</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>ERROR: You need the GRASS binary =
package in .tar.gz=20
compression<BR>or .tar.bz2.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>bash-2.05b$</FONT></DIV></BODY></HTML>
------=_NextPart_000_00D2_01C44268.A58252B0--
rom jonas-grass-de@gmx.net Thu May 27 11:18:39 2004
Received: from mail.gmx.net (pop.gmx.de [213.165.64.20])
  by grass.itc.it (8.11.6/8.11.2) with SMTP id i4R9IdC05594
  for <wingrass@grass.itc.it>; Thu, 27 May 2004 11:18:39 +0200
Received: (qmail 30436 invoked by uid 0); 27 May 2004 09:18:33 -0000
Received: from 193.197.158.169 by www6.gmx.net with HTTP;
  Thu, 27 May 2004 11:18:33 +0200 (MEST)
Date: Thu, 27 May 2004 11:18:33 +0200 (MEST)
MIME-Version: 1.0
Subject:
X-Authenticated: #21167757
Message-ID: <14364.1085649513@www6.gmx.net>
X-Mailer: WWW-Mail 1.6 (Global Message Exchange)
X-Flags: 0001
I just installed Cygwin on W2k. Now I wanted to
install GRASS-GIS Software and got the following
message: "You may need login as root for
installation."
I am able to Install Software on W2k. So I should have
this right also withhin Cygwin, or not? I tried to
login as root, but of course I don't have the correct
password. But also our W2k-Admin could'nt login as
root nor as admin. (we use domain logons)
su- said: user root does not exsist
What can I do? Can I create "my own" user root?
CU,
Jo
"Sie haben neue Mails!" - Die GMX Toolbar informiert Sie beim Surfen!
Jetzt aktivieren unter http://www.gmx.net/info
rom mperra@petrelrob.com Fri Jun 4 20:53:49 2004
Received: from mail30.megamailservers.com (mail30.megamailservers.com [216.251.36.30])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i54IrmC03815
  for <wingrass@grass.itc.it>; Fri, 4 Jun 2004 20:53:48 +0200
X-POP-User: davk.petrelrob.com
Received: from martinp4 ([68.145.100.124])
  by mail30.megamailservers.com (8.12.10/8.12.9) with SMTP id i54IrZAV008357
  for <wingrass@grass.itc.it>; Fri, 4 Jun 2004 14:53:47 -0400
Reply-To: <mperra@petrelrob.com>
Subject: problem with tcltkgrass& command
Date: Fri, 4 Jun 2004 12:52:57 -0600
Message-ID: <000301c44a65$27440ce0$2f64a8c0@petrelrob.com>
MIME-Version: 1.0
X-Mailer: Microsoft Outlook CWS, Build 9.0.6604 (9.0.2911.0)
Importance: Normal
I am having trouble getting grass running, and am wondering if anyone can
help. when I try to run tcltkgrass& I get a windows error message for
wish8.3.exe that says This application has failed to start because
cygwinb19.dll was not found.
I had grass 5, 5.3 and 5.7 running on cygwin, and I was having toruble
getting VIS5D running. When I got that working, I found that GRASS no
longer worked. I have tried removing Cygwin several times, and reinstalling
it and grass, but I keep getting the same error. From my understanding,
cygwinb19.dll is outdated anyway. I am notr sure how to get around this, as
I am not very experienced with Linux/Unix.
Any ideas?
Martin Perra
rom geolgrant@hotmail.com Wed Jun 23 01:30:07 2004
Received: from hotmail.com (sea1-f135.sea1.hotmail.com [207.68.163.135])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i5MNU6C01095
  for <wingrass@grass.itc.it>; Wed, 23 Jun 2004 01:30:06 +0200
Received: from mail pickup service by hotmail.com with Microsoft SMTPSVC;
   Tue, 22 Jun 2004 16:29:55 -0700
Received: from 128.111.108.217 by sea1fd.sea1.hotmail.msn.com with HTTP;
  Tue, 22 Jun 2004 23:29:55 GMT
X-Originating-IP: [128.111.108.217]
X-Originating-Email: [geolgrant@hotmail.com]
X-Sender: geolgrant@hotmail.com
Subject: GDAL support
Date: Tue, 22 Jun 2004 16:29:55 -0700
Mime-Version: 1.0
Content-Type: text/plain; format=flowed
Message-ID: <Sea1-F135UW4O53qzwO00031852@hotmail.com>
X-OriginalArrivalTime: 22 Jun 2004 23:29:55.0668 (UTC) FILETIME=[D35B4940:01C458B0]
Hi, i'm a beginner to GRASS. I'm using grass 5.7 on cygwin and i'm trying
to import a USGS dems using r.in.gdal but I'm running into problems. When I
select the file to import, I receive an error message that the *.DDF format
is not recognizsed as a suported file format.
I've tried reinstalling grass57 but still get the same error message. Can
anyone shed some light on this problem? Thanks.
grant
rom White.Denis@epamail.epa.gov Fri Jul 9 17:30:32 2004
Received: from marconi.rtp.epa.gov (marconi.rtp.epa.gov [134.67.208.99])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i69FUTC19560
  for <wingrass@grass.itc.it>; Fri, 9 Jul 2004 17:30:32 +0200
Received: from epahub12.rtp.epa.gov (epahub12.rtp.epa.gov [134.67.213.53])
by epamail.epa.gov (PMDF V5.2-32 #42056)
with ESMTP id <0I0L00HZQC5BPC@epamail.epa.gov> for wingrass@grass.itc.it; Fri,
  9 Jul 2004 11:24:47 -0400 (EDT)
Date: Fri, 09 Jul 2004 08:24:57 -0700
Subject: getting an xterm
Message-id:
<OF37706655.B9E2B93F-ON88256ECC.00545655-88256ECC.0054A958@epamail.epa.gov>
MIME-version: 1.0
X-Mailer: Lotus Notes Release 6.0.2CF1 June 9, 2003
Content-type: text/plain; charset=US-ASCII
X-MIMETrack: Serialize by Router on EPAHUB12/USEPA/US(Release 6.0.2CF1|June 9,
2003) at 07/09/2004 11:24:47 AM
X-Bogosity: No, tests=bogofilter, spamicity=0.001713, version=0.15.13.1
I am trying to start GRASS on windows. I installed Cygwin. I followed
the GRASS 5.7 installation instructions. I got a "startx: command not
found" message. I went back and added xterm and then XFree86 to Cygwin,
but still no xterm. Thanks for any help.
Denis White
   US EPA, 200 SW 35th St, Corvallis, Oregon, 97333 USA
   voice: 541.754.4476, email: white.denis@epa.gov
   web: www.epa.gov/wed/pages/staff/white/
rom bcondon4@hotmail.com Fri Jul 9 19:56:41 2004
Received: from hotmail.com (bay2-f41.bay2.hotmail.com [65.54.247.41])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i69HueC20706
  for <wingrass@grass.itc.it>; Fri, 9 Jul 2004 19:56:41 +0200
   Fri, 9 Jul 2004 10:56:34 -0700
Received: from 209.80.136.4 by by2fd.bay2.hotmail.msn.com with HTTP;
  Fri, 09 Jul 2004 17:56:33 GMT
X-Originating-IP: [209.80.136.4]
X-Originating-Email: [bcondon4@hotmail.com]
X-Sender: bcondon4@hotmail.com
Date: Fri, 09 Jul 2004 17:56:33 +0000
Mime-Version: 1.0
Message-ID: <BAY2-F41mm909gCAOtI000be83a@hotmail.com>
X-OriginalArrivalTime: 09 Jul 2004 17:56:34.0032 (UTC) FILETIME=[12799700:01C465DE]
X-Bogosity: No, tests=bogofilter, spamicity=0.000025, version=0.15.13.1
I am new to grass. I have been having trouble getting started. I get a
message that cyggdal-1.dll was not found try reinstalling. What is the best
way to go about reinstalling grass. Do i need to reinstall cygwin utils as
well. Thanks.
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
rom bcondon4@hotmail.com Sat Jul 10 19:51:58 2004
Received: from hotmail.com (bay2-f21.bay2.hotmail.com [65.54.247.21])
  by grass.itc.it (8.11.6/8.11.2) with ESMTP id i6AHpwC23250
  for <wingrass@grass.itc.it>; Sat, 10 Jul 2004 19:51:58 +0200
   Sat, 10 Jul 2004 10:51:51 -0700
Received: from 68.163.232.42 by by2fd.bay2.hotmail.msn.com with HTTP;
  Sat, 10 Jul 2004 17:51:51 GMT
X-Originating-IP: [68.163.232.42]
Subject: reinstall grass57
Date: Sat, 10 Jul 2004 17:51:51 +0000
Mime-Version: 1.0
Message-ID: <BAY2-F21Q6mBySsxVY6000433da@hotmail.com>
X-OriginalArrivalTime: 10 Jul 2004 17:51:51.0382 (UTC) FILETIME=[946A5F60:01C466A6]
X-Bogosity: No, tests=bogofilter, spamicity=0.000190, version=0.15.13.1
I am new to grass. I have downloaded 5.7 and got an error with the
cyggdal-1.dll file. I see that this file is now in the download install
directory. I have tried downloading the file and still get the error telling
me to reinstall. 1) Hopw do I uninstall only grass 2) When in the install
process do I deAl with the cyggdal-1.dll file?
Thanks for any help
-lost in the grass
MSN 9 Dial-up Internet Access helps fight spam and pop-ups – now 2 months
FREE! http://join.msn.click-url.com/go/onm00200361ave/direct/01/
rom basu_ibm@yahoo.com Sun Jul 18 15:03:45 2004
Received: from web53508.mail.yahoo.com (web53508.mail.yahoo.com [206.190.37.69])
  by grass.itc.it (8.11.6/8.11.2) with SMTP id i6ID3iC13750
  for <wingrass@grass.itc.it>; Sun, 18 Jul 2004 15:03:44 +0200
Message-ID: <20040718130339.85191.qmail@web53508.mail.yahoo.com>
Received: from [202.141.80.20] by web53508.mail.yahoo.com via HTTP; Sun, 18 Jul 2004 06:03:39 PDT
Date: Sun, 18 Jul 2004 06:03:39 -0700 (PDT)
Subject: problem with CELL window option in GRASS 5.7.0
To: wingrass-admin@grass.itc.it
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="0-1628556844-1090155819=:84112"
--0-1628556844-1090155819=:84112
dear sir,
             i am a new user of GRASS 5.7.0 and a naive in cygwin platform. i have installed the GRASS 5.7.0 in my WINDOWS XP operating system.while setting up the
cygwin i selected the following packages:
_update-info-dir
a2ps cygrunsrv ghostscript m4 regex w32api
agetty cygutils gnulogo man sed which
antiword cygwin grace minires sh-utils X11
apache db grep mktemp sunrpc xerces-c
apr diffutils groff ncurses tar zip
apr-util editrights gzip opengl tcsh zlib
ash expat inetutils openssh termcap
base-files file jpeg openssl terminfo
base-passwd fileutils less pcre texinfo
bash findutils libiconv perl textutils
bzip2 gawk libpng popt tiff
clear gdbm libungif postgresql time
crypt gettext login readline unzip
under the x11 package i have downloaded
   cgoban transfig xorg-x11-devel xorg-x11-xwin-gl
   cygwin-x-doc WindowMaker xorg-x11-etc X-start-menu-icons
   ddd x2x xorg-x11-f100 X-startup-scripts
   fontconfig Xaw3d xorg-x11-fcyr xterm
   freetype2 xfig xorg-x11-fenc xwinclip
   fvwm XFree86-lib-compat xorg-x11-fnts xwinwm
   gv xgraph xorg-x11-fscl
   lesstif XmHTML xorg-x11-fsrv
   libXft xorg-x11-base xorg-x11-libs-data
   nedit xorg-x11-bin xorg-x11-man-pages
   openbox xorg-x11-bin-dlls xorg-x11-man-pages-html
   tcm xorg-x11-bin-lndir xorg-x11-xwin
But after installing the grass binaries(cyggdal-1.dll.tar, grass-5.7.0-i686-pc-cygwin-24_06_2004-install.sh, xtcltk-8.3.4-CYGWIN.tar.gz and grass-5.7.0-i686-pc-cygwin-24_06_2004.tar.gz) i was trying to display a raster image (SPOT Vegetation Data).the image is imported successfully, butwhile trying to display it, under the display menu of GUI in the "select monitor" option i am getting only the x0 to x6 windows, but the CELL window option is missing which is a raster display window.from the command mode(d.mon start=CELL-r) also it is showing "unable to find socket to connect monitor".i tried to open the raster image in x0 and x1 window, but it is not coming.actually, the image is a stacked image of 3 bands, GRASS is showing all the three stacks separately in the folder "PERMANENT" after importing is done, but it is not displaying the image in the x-windows.
I will be very much grateful to you if you kindly help me out of this problem so that i can continue with GRASS 5.7.0.
With best regards
Arindam Chattopadhyay
room no.361, hostel kapili,
M.tech student (water resources),
Indian Institute of Technology (IIT) Guwahati,
north Guwahati. Assam,
PIN-781039
India
arindam_99137@yahoo.co.uk
arindamch@iitg.ernet.in
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Content-Type: text/html; charset=us-ascii
<DIV>dear sir,</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; i am a new user of GRASS 5.7.0 and a naive in cygwin platform. i have installed the GRASS 5.7.0 in my WINDOWS XP operating system.while setting up the</DIV>
<DIV>cygwin i selected the following packages:</DIV>
<DIV>_update-info-dir</DIV>
<DIV>a2ps&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;cygrunsrv&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ghostscript&nbsp;&nbsp;&nbsp; m4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; regex&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; w32api&nbsp;&nbsp; </DIV>
<DIV>agetty&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; cygutils&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; gnulogo&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;man&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sed&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;which</DIV>
<DIV>antiword&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;cygwin&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; grace&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; minires&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; sh-utils&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;X11</DIV>
<DIV>apache&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;db&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;grep&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; mktemp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;sunrpc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xerces-c</DIV>
<DIV>apr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; diffutils&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; groff&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ncurses&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;tar&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; zip</DIV>
<DIV>apr-util&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;editrights&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;gzip&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;opengl&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; tcsh&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; zlib</DIV>
<DIV>ash&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;expat&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; inetutils&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; openssh&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;termcap</DIV>
<DIV>base-files&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; file&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; jpeg&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;openssl&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; terminfo</DIV>
<DIV>base-passwd&nbsp;&nbsp;&nbsp; fileutils&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; less&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; pcre&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; texinfo</DIV>
<DIV>bash&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; findutils&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; libiconv&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; perl&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; textutils</DIV>
<DIV>bzip2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; gawk&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;libpng&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; popt&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; tiff</DIV>
<DIV>clear&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;gdbm&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; libungif&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;postgresql&nbsp;&nbsp; time</DIV>
<DIV>crypt&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;gettext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; login&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; readline&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; unzip&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV>under the x11 package i have&nbsp;downloaded&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </DIV>
<DIV>&nbsp;&nbsp; cgoban&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; transfig&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-devel&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;xorg-x11-xwin-gl&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</DIV>
<DIV>&nbsp;&nbsp; cygwin-x-doc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; WindowMaker&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-etc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;X-start-menu-icons</DIV>
<DIV>&nbsp;&nbsp; ddd&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; x2x&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-f100&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; X-startup-scripts</DIV>
<DIV>&nbsp;&nbsp;&nbsp;fontconfig&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Xaw3d&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-fcyr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xterm</DIV>
<DIV>&nbsp;&nbsp; freetype2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xfig&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;xorg-x11-fenc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xwinclip</DIV>
<DIV>&nbsp;&nbsp; fvwm&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XFree86-lib-compat&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-fnts&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xwinwm</DIV>
<DIV>&nbsp;&nbsp; gv&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xgraph&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-fscl</DIV>
<DIV>&nbsp;&nbsp; lesstif&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XmHTML&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;xorg-x11-fsrv</DIV>
<DIV>&nbsp;&nbsp; libXft&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-base&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-libs-data</DIV>
<DIV>&nbsp;&nbsp;&nbsp;nedit&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-bin&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-man-pages</DIV>
<DIV>&nbsp;&nbsp; openbox&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-bin-dlls&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-man-pages-html</DIV>
<DIV>&nbsp;&nbsp; tcm&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; xorg-x11-bin-lndir&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;xorg-x11-xwin</DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV>But after installing the grass binaries(cyggdal-1.dll.tar, grass-5.7.0-i686-pc-cygwin-24_06_2004-install.sh, xtcltk-8.3.4-CYGWIN.tar.gz and grass-5.7.0-i686-pc-cygwin-24_06_2004.tar.gz) i was trying to display a raster image (SPOT Vegetation Data).the image is imported successfully, butwhile trying to display it,&nbsp;under the display menu of GUI in the "select monitor" option i am getting only the x0 to x6 windows, but the CELL window option is missing which is a raster display window.from the command mode(d.mon start=CELL-r)&nbsp;also it is showing "unable to find socket to connect monitor".i tried to open the raster image in x0 and x1 window, but it is not coming.actually, the image is a stacked image of 3 bands, GRASS is showing all the three stacks separately in the folder "PERMANENT" after importing is done, but it is not displaying the image in the x-windows.</DIV>
<DIV>I will be very much grateful to you if you kindly help me out of this problem so that i can continue with GRASS 5.7.0. </DIV>
<DIV>With best regards</DIV>
<DIV>&nbsp;</DIV>
<DIV>Arindam Chattopadhyay</DIV>
<DIV>room no.361, hostel kapili,</DIV>
<DIV>M.tech student (water resources),</DIV>
<DIV>Indian Institute of Technology (IIT) Guwahati,</DIV>
<DIV>north Guwahati. Assam,</DIV>
<DIV>PIN-781039</DIV>
<DIV>India</DIV>
<DIV><A href="mailto:arindam_99137@yahoo.co.uk">arindam_99137@yahoo.co.uk</A></DIV>
<DIV><A href="mailto:arindamch@iitg.ernet.in">arindamch@iitg.ernet.in</A></DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </DIV>
<DIV>&nbsp;</DIV><p>__________________________________________________<br>Do You Yahoo!?<br>Tired of spam? Yahoo! Mail has the best spam protection around <br>http://mail.yahoo.com
--0-1628556844-1090155819=:84112--
rom philiphodge@yahoo.com Fri Jul 23 12:06:17 2004
Received: from web50505.mail.yahoo.com (web50505.mail.yahoo.com [206.190.38.81])
  by grass.itc.it (8.11.6/8.11.2) with SMTP id i6NA6GC12182
  for <wingrass@grass.itc.it>; Fri, 23 Jul 2004 12:06:16 +0200
Message-ID: <20040723100610.99048.qmail@web50505.mail.yahoo.com>
Received: from [203.114.134.136] by web50505.mail.yahoo.com via HTTP; Fri, 23 Jul 2004 03:06:10 PDT
Date: Fri, 23 Jul 2004 03:06:10 -0700 (PDT)
Subject: Installing grass5.7 on XP
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="0-2014537928-1090577170=:96422"
--0-2014537928-1090577170=:96422
A real newbie here.... trying to get started for the first time on Grass so I can play with shape files.. am trying to install Grass 5.7 using "Installing Grass 5.7 on Win32 with Cygwin" instructions (dated 2004/03/29) onto Windows XP.
I did the "Cygwin installation" including selected packages via Cygwin mirror site and
downloaded xtclk-8.3.4-CYGWIN.tar.gz
Tried to enter the following into the cygwin shell window as per instructions but nothing happens except the following error message....
bash-2.05b$ tar xvfz xtcltk-8.3.4-CYGWIN.tar.gz
bash: tar: command not found
Something simple is wrong but cant figure it out. Have checked that I have tar.exe in /bin folder Ok.
Any clues as to what I have missed? or is it a grass5.7 thing.
Phil
Do you Yahoo!?
Vote for the stars of Yahoo!'s next ad campaign!
<DIV>
<DIV><FONT face=Arial size=2>A real newbie here.... trying to get started for the first time on Grass so I can play with shape files.. am trying to install Grass 5.7 using "Installing Grass 5.7 on Win32 with Cygwin" instructions (dated 2004/03/29) onto Windows XP.</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>I did the "Cygwin installation" including selected packages via Cygwin mirror site and </FONT></DIV>
<DIV><FONT face=Arial size=2>downloaded&nbsp;&nbsp; xtclk-8.3.4-CYGWIN.tar.gz</FONT><FONT face=Arial size=2><BR>Tried to enter the following into the cygwin shell window as per instructions but nothing happens except the following error message....</FONT></DIV>
<DIV><FONT face=Arial size=2>bash-2.05b$ tar xvfz xtcltk-8.3.4-CYGWIN.tar.gz<BR>bash: tar: command not found</FONT></DIV>
<DIV><FONT face=Arial size=2>Something simple is wrong but cant figure it out.&nbsp; Have checked that I have tar.exe in /bin folder Ok.</FONT></DIV>
<DIV><FONT face=Arial size=2>Any clues as to what I have missed? or is it a grass5.7 thing.</FONT></DIV>
<DIV><FONT face=Arial size=2>Phil</FONT></DIV></DIV><p>
    <hr size=1>Do you Yahoo!?<br>
<a href="http://advision.webevents.yahoo.com/yahoo/votelifeengine/&quot;&gt;Vote for the stars of Yahoo!'s next ad campaign!</a>
--0-2014537928-1090577170=:96422--
rom basu_ibm@yahoo.com Sun Aug 1 20:19:19 2004
Received: from web53506.mail.yahoo.com (web53506.mail.yahoo.com [206.190.37.67])
  by grass.itc.it (8.11.6/8.11.2) with SMTP id i71IJIC19602
  for <wingrass@grass.itc.it>; Sun, 1 Aug 2004 20:19:18 +0200
Message-ID: <20040801181908.720.qmail@web53506.mail.yahoo.com>
Received: from [202.141.80.20] by web53506.mail.yahoo.com via HTTP; Sun, 01 Aug 2004 11:19:08 PDT
Date: Sun, 1 Aug 2004 11:19:08 -0700 (PDT)
Subject: some problems after installation GRASS 5.7
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="0-2031753480-1091384348=:98901"
X-Bogosity: No, tests=bogofilter, spamicity=0.000001, version=0.15.13.1
--0-2031753480-1091384348=:98901
Dear sir,
              I am a student of M.Tech.(Civil Engineering) at Indian Institute of Technology(IIT) Guwahati, India. I have just completed the GRASS 5.7 installaton over Windows XP OS.I have installed the following binaries:
1) xtcltk-8.3.4-CYGWIN.tar.gz
2) cyggdal-1.dll.tar.gz
3) grass-5.7.0-i686-pc-cygwin-24_06_2004-install.sh
4) grass-5.7.0-i686-pc-cygwin-24_06_2004.tar.gz
             But still after the successful installation, it is showing some error messages while i am choosing some options of the GUI windows.Like, in the "ERDAS LAN" option, it is showing that 'the file i.in.erdas not found'.In some of the other options also(database register options and some others) these problems are arising.I am unable to find out why those files are missing and if so, from where i can get those required files and how to install those files. If you please help me out to get rid of these difficulties i will be very much grateful to you.
Yours faithfully,
Room no.204, Hostel Siang,
IIT Guwahati,
North Guwahati,
ASSAM-781039,
INDIA.
e-mail addresses:
1.basu_ibm@yahoo.com
2.arindamch@iitg.ernet.in
3.arindam_99137@yahoo.co.uk
Do you Yahoo!?
Yahoo! Mail is new and improved - Check it out!
<DIV>
<DIV>Dear sir,</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;I am a student of M.Tech.(Civil Engineering) at Indian Institute of Technology(IIT) Guwahati, India. I have just completed the GRASS 5.7 installaton over Windows XP OS.I have installed the following binaries:</DIV>
<DIV>&nbsp;</DIV>
<DIV>1) xtcltk-8.3.4-CYGWIN.tar.gz</DIV>
<DIV>2) cyggdal-1.dll.tar.gz</DIV>
<DIV>3) grass-5.7.0-i686-pc-cygwin-24_06_2004-install.sh </DIV>
<DIV>4) grass-5.7.0-i686-pc-cygwin-24_06_2004.tar.gz</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;But still after the successful installation, it is showing some error messages while i am choosing some options of the GUI windows.Like, in the "ERDAS LAN" option, it is showing that 'the file i.in.erdas not found'.In some of the other options also(database register options and some others) these problems are arising.I am unable to find out why those files are missing and if so, from where i can get those required files and how to install those files. If you please help me out to get rid of these difficulties i will be very much grateful to you.</DIV>
<DIV>Yours faithfully,</DIV>
<DIV>Room no.204, Hostel Siang, </DIV>
<DIV>IIT Guwahati,</DIV>
<DIV>North Guwahati,</DIV>
<DIV>ASSAM-781039,</DIV>
<DIV>INDIA.</DIV>
<DIV>e-mail addresses:</DIV>
<DIV>1.<A href="mailto:1.basu_ibm@yahoo.com">basu_ibm@yahoo.com</A></DIV>
<DIV>2.<A href="mailto:2.arindamch@iitg.ernet.in">arindamch@iitg.ernet.in</A></DIV>
<DIV>3.<A href="mailto:3.arindam_99137@yahoo.co.uk">arindam_99137@yahoo.co.uk</A></DIV>
<DIV>&nbsp;</DIV></DIV><p>
Yahoo! Mail is new and improved - <a href="http://us.rd.yahoo.com/mail_us/taglines/new/*http://promotions.yahoo.com/new_mail&quot;&gt;Check it out!</a>
--0-2031753480-1091384348=:98901--
On Thu, Jul 17, 2003 at 08:48:34PM +0100, Glynn Clements wrote:
Bernhard Reiter wrote:
> It all only makes sense if the 5.3.x cycle is
> compartively very short.
In that case, it might be better to skip the 5.3.x naming, and just
use 5.4.0-pre1, -pre2 etc.
Maybe yes (especially if it helps to get the developers more interested
in the 5.1/5.7 development).
However, the entire proposal only works if all developers agree.
We could,
but having the first one as 5.3.0 release might be okay,
because it really did not have much testing.
It won't help get people interested in 5.7 much im my eyes.
But that doesn't matter I believe.
We do clear naming for our own sake and our users
and working in a structured way over the long term will
attract more developers.
More or less the same in HTML:
http://grass.itc.it/roadmap.html
