I repaired the libgis.dll by using the dllwrapper-tool and renamed
libgis.dll to gis.dll.
Now I obtain an other error when calling G_gisinit:
Usage: java [-options] class [args...]
(to execute a class)
or java -jar [-options] jarfile [args...]
(to execute a jar file)
where options include:
-cp -classpath <directories and zip/jar files separated by ;>
set search path for application classes and resources
-D<name>=<value>
set a system property
-verbose[:class|gc|jni]
enable verbose output
-version print product version and exit
-showversion print product version and continue
-? -help print this help message
-X print help on non-standard options
71 [main] ? 290 sync_with_child: child 371(0x620) died before
initialization with status code 0x1
135 [main] ? 290 sync_with_child: *** child state waiting for
longjmp
-D<name>=<value>
115745 [main] 0æ 290 sync_with_child: child 365(0x66C) died before
115810 [main] 0æ 290 sync_with_child: *** child state waiting for
longjmp
ERROR: LOCATION << e:\cygwin\usr\local\grass5\daten
/spearfish
>> not
available
-D<name>=<value>
232101 [main] ? 290 sync_with_child: child 335(0x6B0) died before
232165 [main] ? 290 sync_with_child: *** child state waiting for
longjmp
This seems to be a heavy problem. Can anybody help me??
Claus
Wir ziehen um - ab April gilt die neue Firmenanschrift:
con terra GmbH
Martin-Luther-King-Weg 24
48155 Münster
Tel. 0251/7474-500
Fax 0251/7474-100
