[GRASS5] GRASS: make install problems
a user reported that, when installing GRASS with
make install
some permissions are wrong.
He compilied as "root" and installed (make install).
The permissions for
/opt/grass5/tcltkgrass/script/gis_set.tcl
/opt/grass5/bin/tcltkgrass
were not right for the normal users. As I am installing
GRASS as normal user, I cannot verify this.
Does anyone know about this problem? Do we have
to fix a missing "chmod"?
Markus Neteler wrote:
make install
The permissions for
Markus, are you talking here about what I have complained about or is
this
somebody else? We had exactly this problem. Nviz and tcltk does not run,
you have to change the permissions
Helena
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
> Hi,
> make install
> The permissions for
this
Helena
It seems to be exactly that problem. Anyone else ? :slight_smile:
make install
The permissions for
I don't see any problem ("make" as user, "make install" as root).
However, note that "make install" mostly just copies the files to the
installation directory. The installed files will have the same
ownership and permissions as the versions in dist.<platform>.
For files which aren't generated by compilation (e.g. scripts), they
will probably have the ownership and permissions resulting from
installation (i.e. "tar x" or "cvs checkout/update").
If the permissions are wrong, the first thing for the user to check is
his (i.e. root's) umask setting.
I don't see any reliable solution until we have a conventional
"make install" procedure (i.e. a recursive "make install", with the
individual programs using "install" on the appropriate files). And
that's too significant a change for 5.0, IMHO.
> make install
> The permissions for
Markus, are you talking here about what I have complained about or is this
From what, to what?
> make install
> The permissions for
Well, the build procedure for tcltkgrass is:
  make[1]: Entering directory `<SRC>/tcltkgrass'
  if [ ! -d <DST>/tcltkgrass ]; then mkdir <DST>/tcltkgrass; fi
  rm -f <DST>/bin/tcltkgrass
  tar cf - docs/Pro* docs/HIS* main/* module/* script/* | (cd <DST>/tcltkgrass; tar xf -)
  cp main/gis_set.tcl <DST>/tcltkgrass/script
  cp tcltkgrass <DST>/bin/tcltkgrass
  chmod ugo+x <DST>/tcltkgrass/main/tksys.tcl
  chmod ugo+x <DST>/bin/tcltkgrass
  chmod -R u+w <DST>/tcltkgrass
  make[1]: Leaving directory `<SRC>/tcltkgrass'
where <SRC> is the GRASS "src" directory and <DST> is the
dist.<platform> directory.
IOW, "make" simply copies everything into the staging directory, from
where "make install" will copy it to the final $GISBASE directory. So,
the ownership and permissions will be the same as the source files,
minus any permission bits which are cleared by way of the umask
setting.
It would probably suffice to add "chmod -R ugo+rX ${INST_DIR}" to the
end of the "install" target.
> > make install
> > The permissions for
setting.
So,
now "my" user sent me the permissions:
before:
-rw-r----- 1 root root /opt/grass5/tcltkgrass/script/gis_set.tcl
-rwxr-x--x 1 root root /opt/grass5/bin/tcltkgrass
after:
-rw-r----- 1 root users /opt/grass5/tcltkgrass/script/gis_set.tcl
-rwxr-x--x 1 root users /opt/grass5/bin/tcltkgrass
Additionally all files in /opt/grass5/tcltkgrass/script
except gis_set.tcl got the wrong owner.
As this seems to happen on several machines, we should consider to
modify the install script.
before:
after:
My first thought would be that his umask was set to 027 when he
installed the source ("tar x", "cvs checkout/update"). tcltkgrass gets
execute permission added during the "compilation" phase, but a script
also needs read permission to work.
Ownership isn't changed by the install. "tar x" will use the ownership
from the tar file when run as root.
It may suffice to add:
  chown -R root ${INST_DIR} >& /dev/null
to the "install" target (the second command will fail if not run by
root).
