[GRASS5] GRASS Monitor
hello ,
i had been download grass5 in linux platform but it can't running completely .it wanna location,mapset and database...what would i do..and how i'm going to do...
Reply-To: grass5@geog.uni-hannover.de
Subject: Re: [GRASS5] GRASS Monitor
Date: Tue, 17 Apr 2001 18:27:53 -0700
On Tue, Apr 17, 2001 at 02:43:22PM -0300, Bob Covill wrote:
> Hello,
> This is probably a question for Eric.
> I have a recent version of GRASS on Linux (RedHat 6.1). The system is
> 300 MHz with 200 MB RAM. Everything works fine on this system.
> I then moved the GRASS build to a faster machine (PIII with 500 MB RAM)
> also running RedHat Linux. Again, everything worked fine with the
> exception of the monitor. The monitor (sockets) would start but complain
> that the socket was unavailable or in use by another program.
> I discovered the source of the problem was that d.mon was trying to
> select the monitor before it had completely started. I was able to work
> around the problem by executing "d.mon -s start=x0" followed by "d.mon
> select=x0".
> Any thoughts on why this might be happening?
Nail on head. Faster machine, executes more code during time slice,
oops socket or server is not ready to accept connections. Anyway, 'bout
the only thing I can think of is to have d.mon sleep() for a little
while before trying to connect or after the first attempt failing. It
may be a little trial an error to decide how many seconds and/or if the
iterations of "try" should be increased. One second after first failure
might be sufficient. I only know that the CELL/PNG drivers are much
slower to start up than the X driver.
If I wanted to get tricky, I would try to find out if the monitor is
running from the process list and try harder to connect if it is, or
just quit right away if it isn't. But I think the sleep() hack should
be sufficient.
grass/src/display/d.mon/cmd/main.c
128 if (select->answer)
129 {
130 oops = run("select", select->answer); /* couldn't select */
131 if (oops && start->answer && strcmp (start->answer,
  select->answer) == 0) /* try once more */
132 {
133 fprintf (stderr, "Problem selecting %s. Will try
    once more\n", select->answer);
+++ sleep(1);
134 oops = run("select", select->answer); /* couldn't
                        select */
135 }
P.S. Sorry, been a bit distracted from GRASS lately...
Eric G. Miller <egm2@jps.net>
subject 'unsubscribe grass5'
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
The best place to look to get started is:
http://www.geog.uni-hannover.de/grass/firsttime.html
This has links to sample data, tutorials and other useful information, plus has
some basic information to get you started.
Enjoy,
Malcolm
ja id wrote:
hello ,
to do...
>From: "Eric G. Miller" <egm2@jps.net>
> > Hello,
> > select=x0".
>be sufficient.
>129 {
>132 {
>+++ sleep(1);
> select */
>135 }
>to:
