Good news and bad news…
GOOD (for WinNT users):
Looks like I’m over the major hurdles in the IPC code. I have several changes to send to the maintainer, but I am able to get the IPC Message Queues to connect/send/receive/disconnect. (Still more to do: clean up code a bit, increase the number of queues and increase message buffer sizes look like the first priority, but these should be simple changes.)
d.mon programs (start, select, stop) are working for me, as well as a VERY limited set of display commands on WinNT. I still have some minor clean up and testing to do to make sure they are ready for testing by others.
d.erase and d.zoom seem to work. d.erase erased the little that drew with d.rast, and d.zoom did a proper zoom for the little band of pixels that d.rast created (see below), with a cursor, the zoom “rubber band” box and the coordinates and prompts in the command window were in sync with the graphics window operations. Probably a number of other commands will work as well.
In order to run “d.mon select” without code changes, I had to remove the “#ifndef CYGWIN” and “#endif” statements that were in the switch statement in src/display/devices/XDRIVER/XDRIVER24/ipc.new/switcher.c , i.e. sandwiching the FONT and TEXT case blocks. Does anyone know why these cases were being excluded? Is this a relic from the old XFree port? These blocks of code seem to compile fine, and the “case FONT” code block works with the recent XFree release for Cygwin. I think this should be changed for both the original (fifo) version and the ipc version.
BAD:
- Limited success with the d.rast command. It only seems to draw the NULL’s. Using the Spearfish sample data, I did:
d.rast soils bg=yellow - it draws a yellow band near the bottom of the X0 monitor window (several pixels wide and the width of the window).
d.rast soils bg=white - it draws a white band where the yellow band was.
d.rast streams bg=red - it draws a red band over the bottom part of the white bandFrom these and additional tests I am guessing that just the NULL pixels are being drawn. Does this sound right?
BTW: It was based on this limited result that I was able to test d.erase and d.zoom
d.vect, d.sites and d.legend all hang up. They had to be killed from a separate window.
Win98 did not work. The IPC code by itself tested OK, but the d.mon commands were hanging up. WinNT was used for the limited successes above.
I will keep looking at the IPC code and do the minor changes I mentioned above. I also plan to keep on looking into the d.rast problems to see if I can get this working. Suggestions are welcome.
Malcolm
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to: minordomo@geog.uni-hannover.de with subject ‘unsubscribe grass5’
