[GRASS5] GRASS + Oracle
Dear Developers,
I have successfully used GRASS and oracle-spatial with v.external.
Usually I thought that copying a layer included by v.extrenal with
g.copy copies the whole layer as a grass-vector-layer, which can be
editied by v.digit.
This is not the case when trying to copy a OCI-layer. The resultant
layer cannot be edited with v.digit:
v.digit roads_oci_copy
WARNING: OGR format cannot be updated.
ERROR: Cannot open old vector roads_oci_copy@PERMANENT on level 2
This is the same error when trying v.digit on the v.external-layer.
Is this a bug or a feature?
Thanks
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
It is feature, once g.copy was making copy reading and
writing lines, now it just copy files/tables.
Radim
On 10/10/05, Stephan Holl <holl@gdf-hannover.de> wrote:
Dear Developers,
editied by v.digit.
Thanks
        Stephan
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hello Radim,
On Tue, 11 Oct 2005 10:28:32 +0200 Radim Blazek
Thanks for commenting on this. Since I would like to work with several
read-only v.external ogr-files/dbs which occasionally need some
digitizing inside the geometry. Therefor I thought just copying the
dataset into the native GRASS-FOrmat and edit then with
QGIS-GRASS-Digitize-tool.
I would like to see a switch inside g.copy which forces copying writing
lines in the native format. Would that be a possibility to extent the
current behavoiur with the former behaviour?
This would be usefull for copying ogr-datasets without using v.in.ogr
inside GRASS.
Best
  Stephan
> Dear Developers,
> editied by v.digit.
> Thanks
> Stephan
You should use v.in.ogr, g.copy does not do cleaning of areas.
It is also possible to use any other module doing nothing e.g.
v.category layer=1.
Radim
On 10/11/05, Stephan Holl <holl@gdf-hannover.de> wrote:
Hello Radim,
inside GRASS.
Best
        Stephan
> > Dear Developers,
> > editied by v.digit.
> > Thanks
> > Stephan
Hello Radim,
On Tue, 11 Oct 2005 13:25:39 +0200 Radim Blazek
v.category layer=1.
OK, so v.in.ogr is the way to go. Thanks for clearing.
Best
  Stephan
