[GRASS5] GRASS test suite update
i have slightly modified the html output of the test suite:
* valgrind memory check information added to the status column
* new known error messages added
I have added 4 additonal tests to the user defined location, to test
the error handling of the test suite (flag -u). I have generated two html outputs
with valgrind memory checks and error handling tests:
AMD machine:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/AMD64-2Ghz/Summary.html
P4 machine:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/P4-2.8Ghz/Summary.html
The test suite with the modification is available here:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/GRASS_Testsuite-0.1.6.0.tar.gz
Have fun,
best regards
Soeren
btw:
there are lots of memory errors detected in some modules!
html outputs with valgrind memory checks and error handling tests:
AMD machine:
P4 machine:
Have fun,
best regards
Soeren
btw:
many modules don't bother free small bits of memory which will be freed
anyway when the module exits. memory leaks in the libraries or in loops
are probably bad though.
Is there a way to link "memory-errors-detected" to the valgrind output
for a quick browse? Maybe figure out how to sort bad memory errors from
just purposefully orphaned memory and promote bad errors to FAIL
section?
How about a count of and link to a module's compiler warnings? (redirect
stderr to a file during make)
How about a link to the actual "validation-failure" or "module-failure"
error?
thanks,
Hamish
On Monday 01 May 2006 13:23, Hamish wrote:
> AMD machine:
> P4 machine:
> Have fun,
> best regards
> Soeren
> btw:
I'm counting only erros, but no leaks, so a valgrind message like:
==2006-04-23 02:07:03.483 32348== LEAK SUMMARY:
==2006-04-23 02:07:03.483 32348== definitely lost: 36 bytes in 1 blocks.
==2006-04-23 02:07:03.483 32348== possibly lost: 0 bytes in 0 blocks.
==2006-04-23 02:07:03.483 32348== still reachable: 224 bytes in 17 blocks.
==2006-04-23 02:07:03.483 32348== suppressed: 0 bytes in 0 blocks.
==2006-04-23 02:07:03.483 32348== Reachable blocks (those to which a pointer was found) are not shown.
==2006-04-23 02:07:03.483 32348== To see them, rerun with: --show-reachable=yes
will not be listed as an memory error, only entries like:
ERROR SUMMARY: 95 errors from 1 contexts (suppressed: 36 from 4)
with ERROR SUMMARY > 0 will be counted as an memory error.
section?
There are already links (in the htmlfile) to the valgrind logfiles, which lists all the memory errors and leaks.
This link is called "memlog->" and is located on the left side in the htmlfile for every tested module.
Hmmm, this can only be made while the build process of grass, which is
not linked to the test suite. If compiler warnings occure, they should be written into
a logfile and copied to the grass install directory. In this case the test suite will be
able to process this file (like the BUILD file in the etc directory of GRASS)
error?
I hope i understood this in the right way.
The link on the left side of the htmlfile called "log->" points directly to the error in the logfile (there is a anker defined).
Links to valgrind log-files and the test suite log-file are made for every module,
even if no error occured. The links are based on test scripts PID's for every test and module.
Example, a logfile and memory error link for the first "r.to.rast3 error detection test (unit)" test:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/AMD64-2Ghz/Logfile.html#32396.0
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/AMD64-2Ghz//r.mapcalc-MemCheckLog32396.0.txt
Best regards
Soeren
thanks,
Hamish
