[GRASS5] grass++
i compiled grass++. here are a few suggestions/questions:
1. it was not clear from first view that one need to compile grass from source
first (i used precompiled binaries before and was wondering about /dist.
$ARCH). maybe it should be mentioned in the manual for those who are not so
familiar with installing.
2. i compiled the library in /home/sabine/diss/grass++0.2 and moved libgrass+
+.so to /usr/local/lib. is this working as the header files remain in /home/
sabine... ?
3. the GISBASE environment variable need to be set. how can i do that?
thanx, sabine
source first (i used precompiled binaries before and was wondering about
/dist. $ARCH). maybe it should be mentioned in the manual for those who are
not so familiar with installing.
libgrass+ +.so to /usr/local/lib. is this working as the header files
remain in /home/ sabine... ?
GISBASE is path to the directory where grass is installed.
Radim
